Sibuna's - Sealed SI24 Build - Page 5 - AVS Forum | Home Theater Discussions And Reviews
 105Likes
post #121 of 249 Old 08-09-2014, 06:51 PM
WereWolf84's Avatar
Quoted: 304 Post(s)
Liked: 114
Adam,
looks great, what colour of stain are you using? are you using Minwax brand?
WereWolf84 is online now
post #122 of 249 Old 08-09-2014, 07:21 PM - Thread Starter
Sibuna's Avatar
Quoted: 381 Post(s)
Liked: 449
Sibuna is offline
post #123 of 249 Old 08-09-2014, 11:14 PM
WereWolf84's Avatar
Quoted: 304 Post(s)
Liked: 114
if I want dark walnut colour as below picture, which colour of stain should I choose?
http://www.kef.com/uploads/images/en.../q_image_2.jpg
post #124 of 249 Old 08-10-2014, 05:14 AM - Thread Starter
Sibuna's Avatar
Quoted: 381 Post(s)
Liked: 449
id do a test part with "Dark Walnut" to see if its what you want, hard to tell from that pic, something like "Jocabean" might be closer but is hard to say. Could also be close to "walnut" which minwax has as a gel stain, which i believe is what our stairs are
Sibuna is offline
post #125 of 249 Old 08-11-2014, 09:03 AM - Thread Starter
Sibuna's Avatar
Quoted: 381 Post(s)
Liked: 449
Poly should start today when I get home
I need to swing by Home Depot and grab some things today and want to know if I can just use weather stripping to seal the driver in? I normally use the stuff from PE but I don't have enough of it nor is what I have wide enough
Sibuna is offline
post #126 of 249 Old 08-11-2014, 09:18 AM
dtsdig's Avatar
Quoted: 912 Post(s)
Liked: 1038
I've used the gray colored (closed cell type) weather stripping from HD and it works just like the PE stuff.
dtsdig is offline
post #127 of 249 Old 08-11-2014, 09:27 AM - Thread Starter
Sibuna's Avatar
Quoted: 381 Post(s)
Liked: 449
Sibuna is offline
post #128 of 249 Old 08-11-2014, 09:39 AM
dtsdig's Avatar
Quoted: 912 Post(s)
Liked: 1038
gotta link to the closed cell stuff?
This is the stuff. They have different widths and thicknesses.
dtsdig is offline
post #129 of 249 Old 08-11-2014, 11:04 AM - Thread Starter
Sibuna's Avatar
Quoted: 381 Post(s)
Liked: 449
Sibuna is offline
post #130 of 249 Old 08-11-2014, 02:22 PM
beastaudio's Avatar
Quoted: 4159 Post(s)
Liked: 3516
It also really depends on your wood. With Birch, the lighter start to the wood will create a different end product than with something like an oak. which will naturally be darker.
beastaudio is offline
post #131 of 249 Old 08-11-2014, 03:45 PM - Thread Starter
Sibuna's Avatar
Quoted: 381 Post(s)
Liked: 449
First of many poly coats
Sent from my LG G3 using Tapatalk
Gorilla83 likes this.
Sibuna is offline
post #132 of 249 Old 08-11-2014, 05:17 PM
Deep Sea Sound
dgage's Avatar
Quoted: 1670 Post(s)
Liked: 1496
Sibuna,
I'm a hobbyist woodworker and still have a ton to learn but one thing I learned, especially when using poplar or maple is that you need to condition the wood or you get splotches or uneven stain penetration. It may be the picture but in the last one you posted, it looks like there is some splotchiness that conditioning might have addressed. Or it could be the camera/lighting. Anyway, this is what I use for conditioning although I know Minwax has some at the big box stores.
http://www.cn-woodworking.com/cn-pre-color-conditioner/
Great job. As good as it looks, I know its going to sound even better.
David
ambesolman likes this.
dgage is offline
post #133 of 249 Old 08-11-2014, 05:20 PM - Thread Starter
Sibuna's Avatar
Quoted: 381 Post(s)
Liked: 449
what you see in that pic is what will be the bottom, i didn't put the prestain conditioner on it like everything else as it was the down side when i did everything else. also it looks worse then it really is due to the lighting
i just use the minwax stuff
Sibuna is offline
post #134 of 249 Old 08-11-2014, 05:30 PM
Deep Sea Sound
dgage's Avatar
Liked: 1496
Makes sense. Glad to know the Minwax prestain conditioner works too. Thanks.
dgage is offline
post #135 of 249 Old 08-11-2014, 05:32 PM - Thread Starter
Sibuna's Avatar
Quoted: 381 Post(s)
Liked: 449
yea i used the minwax stuff on all the other things (fusions, volts, anarchys, TV stand)
Sibuna is offline
post #136 of 249 Old 08-12-2014, 12:56 AM
popalock's Avatar
Quoted: 1319 Post(s)
Liked: 1820
You going for a mirror finish this go around, or same high gloss as the rest of your boxes?
Might have just answered my own question^...lol
popalock is offline
post #137 of 249 Old 08-12-2014, 04:58 AM - Thread Starter
Sibuna's Avatar
Quoted: 381 Post(s)
Liked: 449
same as everything else
doing mirror gloss is a PITA and I don't have the patients for it
Sibuna is offline
post #138 of 249 Old 08-12-2014, 06:44 AM
beastaudio's Avatar
Liked: 3516
Maybe you are just looking at the wrong hospital?
post #139 of 249 Old 08-12-2014, 06:45 AM - Thread Starter
Sibuna's Avatar
Quoted: 381 Post(s)
Liked: 449
i was told in college I had a spelling disability so.....
Sibuna is offline
post #140 of 249 Old 08-12-2014, 07:23 AM
beastaudio's Avatar
Liked: 3516
I'm just messin man So lemme guess, you sanded down to 600 with the orbital first. Then applied conditioner, two coats of stain, and now a single coat of poly. You will now go back and orbital sand at 600 again for a little bit and hit it with another coat?
post #141 of 249 Old 08-12-2014, 07:29 AM - Thread Starter
Sibuna's Avatar
Quoted: 381 Post(s)
Liked: 449
close
I used the orbital to 600 and then blocked with 800 before used the pre stain conditioner - that blocking prob isn't needed but I always do it
let that sit for a cpl hours and then did 2 coats of stain with 6 or so hours in between coats, after the 2nd coat I let it dry for a day before the poly.
I don't used the orbital between poly coats, unless something is very wrong, normally I just block 600 to knock down any bubbles/dust and give the next coat something to stick to
Sibuna is offline
post #142 of 249 Old 08-12-2014, 09:02 AM
Reefdvr27's Avatar
Quoted: 1579 Post(s)
Liked: 1064
Reefdvr27 is offline
post #143 of 249 Old 08-12-2014, 03:34 PM - Thread Starter
Sibuna's Avatar
Quoted: 381 Post(s)
Liked: 449
Sibuna is offline
post #144 of 249 Old 08-12-2014, 09:25 PM
Electrodynamic's Avatar
Quoted: 464 Post(s)
Liked: 694
Thumbs up
Wow! Looking good!
SXRDISBEST likes this.
Electrodynamic is offline
post #145 of 249 Old 08-13-2014, 03:18 AM
Gorilla83's Avatar
Quoted: 378 Post(s)
Liked: 524
Nice' Adam! Driver install and testing this weekend?
Gorilla83 is offline
post #146 of 249 Old 08-13-2014, 03:24 AM - Thread Starter
Sibuna's Avatar
Quoted: 381 Post(s)
Liked: 449
that is the plan
Sibuna is offline
post #147 of 249 Old 08-13-2014, 06:12 AM
beastaudio's Avatar
Liked: 3516
Is that just second coat? Wow!
post #148 of 249 Old 08-13-2014, 06:30 AM - Thread Starter
Sibuna's Avatar
Quoted: 381 Post(s)
Liked: 449
Yea 2nd coat. It was wet in that pic but looked good this morning when dry
Sibuna is offline
post #149 of 249 Old 08-13-2014, 03:20 PM
NWCgrad's Avatar
Quoted: 1272 Post(s)
Liked: 1311
Nice work...I bet it will be awesome when completed. Some motorhead over the weekend?
______________________________________
Home Theater:
http://www.avsforum.com/forum/15-gen...sement-ht.html
NWCgrad is offline
post #150 of 249 Old 08-13-2014, 06:59 PM - Thread Starter
Sibuna's Avatar
Quoted: 381 Post(s)
Liked: 449
put a 3rd coat on today, which will prob be where i stop, have to rotate and do the front. which will prob get finished early sat
need to buy walmart out of pillows or just use insulation for stuffing not sure yet
on another note i think i need more amps
popalock likes this.
Sibuna is offline
