Basic Question About SEOS Speakers - AVS Forum | Home Theater Discussions And Reviews
post #1 of 12 Old 07-19-2014, 09:07 PM - Thread Starter
J_P_A's Avatar
Quoted: 591 Post(s)
Liked: 443
I asked this in the "rallying" thread, but I thought it might be worth its own thread.
Can someone explain to me what the advantages and disadvantages of using an MTM (or 1099) vs a Fusion or Karma 15 for a dedicated home theater? All the speakers will be oriented in the same direction, so I don't need a horizontal center.
I understand vertical pattern control is an issue, but I'm not clear if the MTM or the Fusion has the advantage there.
The Plains Theater Has Begun
J_P_A is offline
post #2 of 12 Old 07-19-2014, 09:40 PM
LTD02's Avatar
Quoted: 2341 Post(s)
Liked: 2578
with mtm the forward lobe is a little narrower than tm, so it becomes a little more important to be pretty much on axis (vertically). in a tm the beam can be tilted up a bit too giving a little bit better sound when you "stand up". not huge differences though, ideally outside (or at least at the boundaries) of the horn anyway.
I don't know what to make of the latest karma 15 that uses a guitar speaker with no overhang (no xmax) if I read the sheet right. seems like it could work well if the bass is really kept out it, so the cone isn't moving very much.
Listen. It's All Good.
LTD02 is offline
post #3 of 12 Old 07-19-2014, 09:44 PM - Thread Starter
J_P_A's Avatar
Quoted: 591 Post(s)
Liked: 443
So in a dedicated space with a second row on a riser, will the forward lobe tend to be broad enough to cover both rows, or is that a consideration?
J_P_A is offline
post #4 of 12 Old 07-19-2014, 10:52 PM
BassThatHz's Avatar
Quoted: 2034 Post(s)
Liked: 1566
If the speaker is up a few degrees above the first rows head and a few degrees below the second rows head; another words mid-section of the two, I don't think it will be a huge deal.
You'd have to be a Obessesive-Compulsive-Sound-Quality-nut to be overly concerned with it in actual use I'd think.
It's not like you won't be able to hear what the actor or singer is saying.
I don't think it would be that BAD! (At least I sure hope not!!! Is it??? )
BassThatHz is offline
post #5 of 12 Old 07-19-2014, 11:09 PM
chalugadp's Avatar
Quoted: 1672 Post(s)
Liked: 1505
I listened today to the jtrs 228,and the 1099. both had similar vertical coverage. I listened sitting and stood up several times. couldn't hear a difference between two on axis
I was mostly on second riser.
chalugadp is offline
post #6 of 12 Old 07-19-2014, 11:31 PM
LTD02's Avatar
Liked: 2578
at 12 feet back, the +/- 10 degree vertical window is +/- 2.11 feet, so about 4.25 feet total. if folks heads are generally in that window (and the speaker has a straight forward firing lobe) all should be fine.
LTD02 is offline
post #7 of 12 Old 07-19-2014, 11:37 PM
chalugadp's Avatar
Liked: 1505
yup I moved a total of 3-4' up and down.
post #8 of 12 Old 07-20-2014, 06:45 AM - Thread Starter
J_P_A's Avatar
Quoted: 591 Post(s)
Liked: 443
So is there any advantage to vertical MTMs vs Fusion 15s?
J_P_A is offline
post #9 of 12 Old 07-20-2014, 07:00 AM
tuxedocivic's Avatar
Quoted: 1910 Post(s)
Liked: 1730
Yes, keeps sound off the floor and ceiling.
tuxedocivic is online now
post #10 of 12 Old 07-20-2014, 07:28 AM
atabea's Avatar
Quoted: 558 Post(s)
Liked: 360
Hey Chal, where will you (and the other attendees) be posting your impressions of the speakers being auditioned at JBrown's GTG? I want to make sure I subscribe to that thread.
Rick
atabea is offline
post #11 of 12 Old 07-20-2014, 07:31 AM
chalugadp's Avatar
Liked: 1505
Rick
the Vancouver summertime gtg results. let me know what you think.
post #12 of 12 Old 07-20-2014, 07:34 AM
atabea's Avatar
Quoted: 558 Post(s)
Liked: 360
Thanks, Chal, I will look for that thread.
atabea is offline
