Dual 18" SI enclosure for nearfield use - Page 3 - AVS Forum | Home Theater Discussions And Reviews
 17Likes
post #61 of 73 Old 07-29-2014, 12:33 PM
klipsch's Avatar
Quoted: 183 Post(s)
Liked: 94
With enough subs and power, we should be able to get to the 4D experience ... 4th D being wind and air moving past your face just like a real helicopter was in the room
klipsch is offline
post #62 of 73 Old 07-29-2014, 01:33 PM - Thread Starter
Gorilla83's Avatar
Quoted: 373 Post(s)
Liked: 513
Originally Posted by klipsch View Post
Nice work!
How's F'in Irene feel with the new near fields?
Didnt get a chance to play any of the demo disc just yet. We are away for the week and will be back Friday to continue playing. I did get a chance to crank up bass I love you which sounded fantastic though.
Gorilla83 is online now
post #63 of 73 Old 07-29-2014, 01:40 PM
carp's Avatar
Quoted: 2495 Post(s)
Liked: 1757
Did that long drawn out 17hz note shake the crap out of you? I found that when messing with sub locations around the room and using 2 of the SI's as end tables they did not give near the shake with the low stuff that the Crowson's did, that 17hz note from Bass I Love you is a great test for that.
However, your back row is on a riser and since the subs are right behind you I'm betting it's a lot more impressive than on concrete with the SI's as end tables.
carp is online now
post #64 of 73 Old 07-29-2014, 02:10 PM - Thread Starter
Gorilla83's Avatar
Quoted: 373 Post(s)
Liked: 513
The shake on the low notes was much more potent than I would have expected. From the quick sweep I did I appear to be getting a bit of room gain as well. Not as much as up front, but still decent and when felt on the riser its a really cool effect. Now on to experiment with what to do for the first row.
post #65 of 73 Old 07-29-2014, 02:21 PM
carp's Avatar
Liked: 1757
I'll be VERY interested to see what you come up with for that.
carp is online now
post #66 of 73 Old 08-04-2014, 08:44 AM - Thread Starter
Gorilla83's Avatar
Quoted: 373 Post(s)
Liked: 513
Got a chance to dial these in a bit and crank them up for some guests this weekend. I've concluded that for normal music/movie watching I like them crossed at 80hz and run -6DB compared to the front sub array. For spirited demos I bumped up that level a bit, but the normal level I found to be most natural and less distracting from the content being displayed/heard. Also received a bunch of feedback - almost everyone seemed to enjoy the new setup. I'm glad I took this on.
The nice part was that even with the box behind the second row, it still seems to add quite a bit of punch to the first row as well. I'm debating as to if it's worth adding any more enclosures to the room to support the first row. Honestly, if I didn't already have extra SI drivers around I wouldn't be considering anything. However, since I do I may churn out a box or two just to play with. Quite possibly maybe I could sneak something narrow onto the "step" of my riser that would fire into the first row? Besides, what else can I do at this point for LFE? AS far as output I am DONE. The demos we did on Saturday gave me bass like I never heard bass in my room like that before.
Also - I posted some measurements in my basement hangout thread and wanted to share here:
Some quick/dirty sweeps before EQ/distance settings/phase:
Rear subs only:
Front subs only
All subs
All subs after distances set and 4DB shelf applied at 20hz - NO smoothing used
Full range sweep, back row (used to have big nulls before all treatments and new subs added) 1/24 smoothing, no other EQ applied
post #67 of 73 Old 08-04-2014, 09:03 AM
randyc1's Avatar
Quoted: 238 Post(s)
Liked: 40
Just wondering when using Nearfield subs if any Delay has to be applied to the further subs ?
randyc1 is offline
post #68 of 73 Old 08-04-2014, 09:13 AM - Thread Starter
Gorilla83's Avatar
Quoted: 373 Post(s)
Liked: 513
In most rooms (including mine) there will be some type of phase adjustment/delay/distance calculation to get everything to integrate properly. With all of my subs being sealed, this was a 20 minute effort with some trial and effort to get it set up. This would be very difficult to get correct without measurement gear as I had to tweak quite a bit after Audyssey set distances.
randyc1 likes this.
post #69 of 73 Old 08-04-2014, 01:30 PM
carp's Avatar
Liked: 1757
Where was the mic for the measurements? Do both rows measure well?
Good stuff!
carp is online now
post #70 of 73 Old 08-04-2014, 01:33 PM - Thread Starter
Gorilla83's Avatar
Quoted: 373 Post(s)
Liked: 513
Good stuff!
Mic was in the second row, left seat for these sweeps. This is usually where I listen when watching with the wife. Front row center seat had a bit of a dip at 50hz but otherwise most seats were similarly and smooth. I was surprised how much the new box smoothed out the back row. Sorry I should have clarified that, thanks for asking!
carp likes this.
post #71 of 73 Old Yesterday, 11:37 PM
jlpowell84's Avatar
Quoted: 1616 Post(s)
Liked: 712
Came across this by looking at your HTOM thread via Carp's thread lol! I have 4 SI18HT's new in box, a 2nd Crest PL 7.5, Duratex, Speakon connectors, Nuetrik connector's all laying around...Was going to wait for dedicated room to build nearfields but I could slip an enclosure behind the couch Think my Open DRC may be dead so I would need another unit of some sort unless I ran splitters and XT32...
jlpowell84 is offline
post #72 of 73 Old Today, 06:38 AM
Raylon's Avatar
Quoted: 205 Post(s)
Liked: 158
Sounds like you may be interested in what I just built too...
Couch Kicker v2 Build Thread
Raylon is online now
post #73 of 73 Old Today, 08:31 AM - Thread Starter
Gorilla83's Avatar
Quoted: 373 Post(s)
Liked: 513
Do it! You won't regret the nearfield setup. I even have 2 nearfields in my living room setup now, haha.
