I've been wanting to build out a nice nearfield enclosure since I moved my other 8 SIs D4s up front behind my screen wall. This box, which will be placed directly behind my second row, will be coupled to my riser. This will be the first 'nearfield experimentation' phase, and next will be building out a few side enclosures for the first row. Pretty basic sealed enclosure, I made it plenty narrow as to not get in the way and tall enough to fire directly into my back seats. I'll be powering with one channel with either my Peavey IPR7500 or Inuke6000 DSP.
Google sketchup, including dimensions:
Cuts and dry fitment:
Should be gluing her up in the next few days. Finishing will be duratex to match my other gear - I love that stuff!
I will be hooking up a nearfield 15" sub next week to go with my two up front. Trying to get better feel at lower volumes. Will be seeing how it works for you.
Oh that should be a nice contribution. Once you feel it there's no going back and you've got one of the big issues covered out the gate. A lot of times it's hard to eliminate the feel that the bass is originating behind you depending on how close the subs are up on you. You're stacked up front so that's a huge first step. The only other factor might depend on how high you xover. Good times await Btw, I can see you're having fun with the CNC. NICE!
I'm looking forward to this experiment for sure. I used to have one of my DO enclosures right behind the riser as well and I miss the feeling. Even with the 100hz Xover I didn't recall having issues before but we'll see.
IIRC Gorilla has a 10x10HD so he can set a few different curves for some quick switching/comparison. I'm assuming this will be complete and integrated before Aug 2nd?
Oh yeah, still have the 10x10 and it does come in handy. I am certainly hoping to have the enclosure ready soon since we go on vacation next week. Might even get some time tonight to work on it if I'm lucky. It should go together quickly with the nailer.
If anyone out there is down to expriment with xover and integration, it's G-rillz...
Thanks Scott! I'm looking forward to getting it together soon. I may have some work piling up here shortly for a few of our AVS boys so it may be slightly delayed, but it will get done soon.
Started assembly tonight - didn't get a ton of time but I managed get the base/frame built. Bottom/bracing/sides are now drying. Glue and brad nail makes for a quickie assembly.
Im looking at your yard in one of your pictures and Im seriously jealous. Look at all that grass! Whatcha got over there, about an acre?
Also, the sub is looking great. With bracing like that, you and your family could crawl into that thing and be safe if the north koreans ever attack us: )
I plan on getting filling and sanding done shortly, so they will be painted soon. They should be ready in no time! We had some family over last night and now this morning, but as soon as I get a chance I will take another crack at it. And yes, I owe you a call back today.
Right now I have zilch's old eminence 10" coaxial design for sides, and I had the two beyma 8's as rears, but MTG90 has one of the beymas in box right now to work on a crossover, so I have had to disconnect the rear surrounds until it comes back. Well, I want 7.1 back, so I thought I would try out a new design that angles the side surrounds down a little (a lot) more and improve on their aesthetics. This will take the place of the left surround and I will use the previous box (that is identical to the rears) for the rear surround that is missing right now and pop the emmy's back in until I get something with the Beyma. Lotta work for a temporary box, but with this 45 degree angle and the box mounted at the ceiling, it shoots the driver perfectly to the middle of the theater. Pretty gratuitous angle that usually isn't necessary, but with a 12 foot wide space and ceiling mounting, it works out perfect.
I'll have a thread up with pics and such. Before and afters as well. This front baffle is BIG for a 10, but I think overall it will be a huge improvement to where I will end up doing the other side surround the same.
When you have a hankering to do some woodworking, it is impossible to satiate it with anything else
Well, got her fired up! Got about 10 minutes to listen so far, but it's certainly a drastic difference. The tactile feeling on the rear seats on the riser increases exponentially with this box playing. I did feel at first that it is somewhat localizeable, but a lot of that may be due to the levels which I have not 100% optimized yet of course. I played with a few different crossover points and the 80hz cross with the front +2 hotter sounded really good. Going to watch a movie tonight to get a better feel!
Try a 40Hz cross and give that bottom end a ULFtacular boost...
That's pretty much what I did for watching movies (didn't like hearing voices in my back).
For music, I would run the same curve for front and back, +2-3db louder in front and I would HPF with a 24db slope @ 20Hz... that would give me headroom for dayz!
Nice build! Love the nearfield play...dramatically adds tactile feedback as you've experienced. Also, depending on your HT seating, can give you a similar transducer shake, but also add tactile feedback not only to the base of your seating, but directly on your back and also affect the chest cavity as well. Transducers cannot do this...
Are you nearfield subs 1M or less away from the LP? From my brief reading of this thread, it sounds like they are; which is a good thing from a tactile feedback standpoint. Can measure what your FR is from just those subs? Being that close, they'll likely resemble their native nearfield response. I would play around with their FR and see what gives you the best tactile feedback you're looking for. Personally, I would try and make them extend as deep as possible on their own to the point where they don't limit your front subs and your max listening level. In my room, I find the 10-20hz tactile feedback most impressive...truth be told though, it's all good.
My main LP in the second row is right on top of these guys. I did a few quick sweeps with fronts only, rears only, and combined and the native response looked pretty good. It does appear to be adding some room gain as the rears weren't rolling off until 18hz or so IIRC. The sweeps are on my netbook so will have to grab and post them. Lots more testing and playing to do but the tactile response they provide I think would be nearly impossible to achieve in any other way. no transducers needed here!
I think that near field subs may turn into the next popular build on the forum. Lots of good feedback lately, and soon I'll be posting a little build thread for my latest sub.
Ps - gorilla, great idea recessing the speakon connector. I'm definitely gonna do that next time.
My one 15" is about 18" away and you can feel it in your seat, back,chest, etc. It has made a huge tactile difference. I love it.
Related Threads
AVS Forum
34M posts
1.5M members
Since 1999
