I started this project a few weeks ago, but don't get much time to work on them. (not building them in my garage)
I thought I knew what I was doing , but I'm starting to second guess myself on what they should be tuned to.
I want to blend them with my existing sonosub, a 12cuft dual 15" Adire Tempest tuned to 21.5hz, power by a bridged inuke 3000dsp
The boxes are 49.75"h x 18.5"w x 21"d
My first thought was a 17.5hz tune (7.5cuft after bracing and 2.5" x 15.5" x 40" port)
Then after more lurking around here I read that I should tune all subs the same?
21.5hz tune (7.9cuft after bracing and 2.5" x 15.5" x 23" port)
Powered by another inuke 3000dsp one per channel
They will sit behind my second row on each side almost half ways down the longest part of my large 7500cuft L shaped room.
The sonosub sub sits in the front corner.
I'm not sure if winisd can model a sonosub but I input the numbers just to see?
The black line is the sonosub, green 1 21.5hz Infinity, pink 1 17.5hz Infinity
Let me know what you guys think
Garth
Garth
