Just curious, but is there anyone making a DIY Paradigm Sub 2 type sub? - AVS Forum
Old 07-22-2014, 08:25 AM - Thread Starter
04rex's Avatar
Quoted: 44 Post(s)
Was looking at their site, and the Sub 1 and Sub 2 are beautiful and absolutely beastly. Just wondering if anyone has ever done or is planning on doing a sub like that? Maybe a flat pack?
Maybe 3 8", or 3 10" or 3 12"?? Or more who knows. Could be interesting. Or even 6 12" or 15"??
04rex is offline
Old 07-22-2014, 08:53 AM
Bassment's Avatar
Quoted: 425 Post(s)
Liked: 171
Ya someone did one with 6 10" drivers Paradigm Sub 2 Clone?
There is nothing special about using 6 smaller drivers, it's a better value and quality just going 18" subs. Especially if you can place them in different locations instead of all in one spot. I think it would be a pretty cool project to make one that has 6 of the infinity 1262 drivers - it would be inexpensive and would be quite good.
Bassment is online now
Old 07-22-2014, 10:27 AM - Thread Starter
04rex's Avatar
Quoted: 44 Post(s)
Well, thats why i was asking. IT would be cheap and if you only have one place to put it, multiples, in a small enclosure, in one spot isn't too shabby.
04rex is offline
Old 07-23-2014, 11:48 AM
Quoted: 76 Post(s)
Liked: 24
Using multiples of drivers is always a good idea.
On this forum you are going to find the norm is to use 18's as they are the best value in getting bass for your dollar.
I say model a box with 6 12's and a big pro amp behind it and see what you think. I bet it would be a real conversation starter.
The infinty 1262 driver is cheap and many have used the driver and can vouch for it. They go for sixty bucks each online.
$360 for 6 12's - 400 for a inuke 6000dsp equals about 760. You build the box and finish it all for under a grand.
I would think the Paradigm box uses a good amount of eq to get down to 20hz flat and keep the cabinet relatively small.
Since you are building the cabinet yourself maybe adding some volume to flatten things out would be a good way to having to add a bunch of eq after you are finished. Good Luck!
LTD02 likes this.
jake515 is offline
Old 07-23-2014, 08:18 PM
Martycool007's Avatar
Quoted: 280 Post(s)
Liked: 174
Is the original Paradigm Sub design a sealed enclosure using six drivers? I wonder how the Infinities could be wired for a typical amp to drive all 6?
Martycool007 is offline
Old 07-23-2014, 08:28 PM
LTD02's Avatar
Quoted: 657 Post(s)
Liked: 1252
depends which version of the driver and which amp you want to run.
a series / parallel configuration is probably what most folks would do to net something in the 4-6 ohms ballpark depending, again, on amp and voice coil options.
Listen. It's All Good.
LTD02 is offline
