ok so I ordered 2 of these for my car to use as midrange/midbass.
I was reading the specs and saw the voice coil wire is copper clad aluminum.
I know in at least the car audio world CCA is junk as power wire.
the reason is because aluminum has 3 times the resistance than OCF.
making it generate heat.
if a vc is made with CCA would this not affect the performance of the drive during a long periods of play. if the resistance of the driver goes up power from the amp goes down.
so if my understandings hold true than this drive is a pore choice.
