Cinema 1 Special 88 build thread - AVS Forum | Home Theater Discussions And Reviews
 3Likes
post #1 of 33 Old 07-24-2014, 12:48 PM - Thread Starter
clausdk's Avatar
Quoted: 205 Post(s)
Liked: 78
Greetings.
After much research I decided to order the Cinema 1 Special 88. I recieved the kit yesterday on the 23th of july.
I wanted to thank everyone for their input and patience along the way while I was going from SEOS-24 Radian BE all the way to Fusion 6 back to Tux 1099 and then back here.....
Anyways I wanted to share my build.
I've just glued up the cabinet, it's drying now and I wanted to get startet on the crossover.
I wasn't expecting the XO layout looking like it did on the guide. Basicly there are 2 sets of + -, one for the woofers and one for the tweeter. I can identify the parts and I've layed them out on a piece of paper, however I don't know how to connect it all I've looked at various pictures of the XO layout and it doesn't corrospond to the guide I have - or atleast I don't understand how to combine the 2 sets of +- into 1 set for the amp to hook up to.
I'll add pictures later, just wanted to maybe get some help with the XO
Regards
Claus
clausdk is offline
post #2 of 33 Old 07-24-2014, 02:35 PM - Thread Starter
clausdk's Avatar
Quoted: 205 Post(s)
Liked: 78
I think I may have figured it out:
Does this look right to those of you who have made this speaker ?
https://dl.dropboxusercontent.com/u/...ver%20help.jpg
Here's the cabinet. I ordered the flat pack. I'm adding some small pieces of wood so the screws have some more grip.
https://dl.dropboxusercontent.com/u/...ld/cabinet.jpg
clausdk is offline
post #3 of 33 Old 07-24-2014, 02:58 PM
dtsdig's Avatar
Quoted: 828 Post(s)
Liked: 914
No photos are showing up for me at all. Not even any markers or placeholders.
dtsdig is online now
post #4 of 33 Old 07-24-2014, 02:59 PM - Thread Starter
clausdk's Avatar
Quoted: 205 Post(s)
Liked: 78
That is strange? it's linked to dropbox on my public folder with full access? hmm.
I added the links to them now.
clausdk is offline
post #5 of 33 Old 07-24-2014, 04:31 PM
joebuddyguy's Avatar
Quoted: 50 Post(s)
Liked: 92
Looks good man, you are making some quick progress already. For the common ground on the crossover, I usually use 1 wire that all the negative points in the crossover can link to so you don't need to make too many jumper wires...you can certainly avoid that by getting all of the cross over parts as close as possible to each other, just watch out for inductor coupling, but your looks good. Are you building three of them then? I look forward to your impressions! Also, have you chosen a finish yet?
joebuddyguy is online now
post #6 of 33 Old 07-24-2014, 05:30 PM
Quoted: 109 Post(s)
Liked: 30
Everything is looking good so far from what I can see.
I built three early this year and am a big fan. Your going to love these when you get them finished.
Allow some break in time for the woofers they start off pretty stiff and go light on the stuffing. Mine sound best with about 6-8 ounces in each. Started with over a pound in there and it sounded pretty dead to my ears removing some of the poly fill cleared that right up.
Erich H likes this.
jake515 is offline
post #7 of 33 Old 07-25-2014, 06:29 AM
dtsdig's Avatar
Quoted: 828 Post(s)
Liked: 914
Sorry, man. Turns out it's my issue, not yours. On my work computer, dropbox and all links to it are blocked. I don't even see the links.
I did check out your build on my phone! Nice job. Carry on!
post #8 of 33 Old 07-25-2014, 07:47 AM
kgveteran's Avatar
Quoted: 363 Post(s)
Liked: 130
I so have my eye on this build thread !!! Did you get the flat pack too ? Subscribed !
As of Jan 2017, im still looking for (1) Outlaw M-200 mono amp, and a used Marantz 7010
kgveteran is offline
post #9 of 33 Old 07-25-2014, 12:07 PM - Thread Starter
clausdk's Avatar
Quoted: 205 Post(s)
Liked: 78
Thanks for taking a look at it.
Regarding finish - it will be mounted on the wall with fabric infront of it so it wont be visible but I will try out some paint and aiming for flat black.
clausdk is offline
post #10 of 33 Old 07-25-2014, 12:10 PM - Thread Starter
clausdk's Avatar
Quoted: 205 Post(s)
Liked: 78
Ok. I lined all the interior with felt and will add 6-8 ounces of poly then!
Pretty excited yea.
I will solder the XO tonight when the kids sleep.
clausdk is offline
post #11 of 33 Old 07-25-2014, 12:14 PM - Thread Starter
clausdk's Avatar
Quoted: 205 Post(s)
Liked: 78
Yes I got the flat pack as well. I dont mind building cabinets but I have precious little time lately with two toddlers.
clausdk is offline
post #12 of 33 Old 07-27-2014, 03:17 PM - Thread Starter
clausdk's Avatar
Quoted: 205 Post(s)
Liked: 78
Made some progress, in fact I'm finished with the build
I had help from my nearly 3 year old son, so it was a bit hectic, as he wanted to fiddle with just about everything ALL the time...talk about stress. I managed to do make the XO pictures below and it seems to work. The speaker sounds about right so I suppose the XO is working correctly.
Here are some pictures:
Now don't laugh:-)
This was my first attempt at spraypainting. It worked ok, but it smelled horribly. I actually ended up sanding it all away again and using a grey paint that is very good on your health instead. Since this speaker will go behind fabric it wouldn't matter all the much, but I still like a clean looking speaker just the same.
Before putting everything together I tested the XO. Was quite stressful as my son kept wanting to touch the woofers. His silly dad showed him how the woofers vibrated in a feeble attempt to explain to him how everything worked
Upon nightfall I managed to get our kids sleeping and daddy went back to his late night activities assembling crossovers and mounting drivers!
Voila, the result, sorry for the dark picture:
It was just a quick hook up to the right channel and I listened to some stereo just to check if everything still worked.
Just a very rough initial impression is that it sounds good. Quite similar to the Dynaudio's in fact, but perhaps a bit clearer sounding. I'll refrain from commenting too hard at this point since it's been a long day. This speaker will function as a center speaker by the way and it was a "test" for me into DIY speakers and possibly ordering more SEOS DIY kits.
clausdk is offline
post #13 of 33 Old 07-27-2014, 05:27 PM
Robert Jones II's Avatar
Quoted: 113 Post(s)
Liked: 64
I show my 3-year old son how things work all the time in an attempt to take away any mystery about playing with them... I regret it in nearly 100% of the cases almost immediately. Congratulations on making any progress at all in light of the circumstances.
Robert Jones II is offline
post #14 of 33 Old 07-28-2014, 06:51 AM
kgveteran's Avatar
Quoted: 363 Post(s)
Liked: 130
Looking forward to your impressions as a center channel. There are so many applications that this speaker will fit, mains, surrounds ect
post #15 of 33 Old 07-31-2014, 12:16 AM
Cam Man's Avatar
Location: Tucson, AZ, Telluride, CO, & Los Angeles,CA, USA
Quoted: 364 Post(s)
Liked: 355
I'm considering the same ... with the same motivation; test drive performance before adding more/others.
Standing by to hear your impressions.
Cam Man is online now
post #16 of 33 Old 07-31-2014, 10:24 AM - Thread Starter
clausdk's Avatar
Quoted: 205 Post(s)
Liked: 78
I've only listened to it for a few hours. I managed to measure it as well and create a set of EQ filters for Jriver. There wasn't much to EQ, but some room modes were present and some fine tuning of an 80hx XO slope. I don't have the measurements on this computer, but can post them another time.
Since it's so new I'm reluctant to come out too quickly with a verdict. I am/was using a Dynaudio Confidence center which is quite expensive, so I wasn't expecting the Special 88 to wipe the floor with it. Considering the almost ridiculous price difference between the two the Special 88 held it's own favorably. On the first day of testing I simply put the Special 88 on top of the rack/cabinet where the Dyn Center sits. I ran it without EQ first then some quick filters. I immediately noticed a more clear and open sound. To level the playing field I actually removed the rack and positioned the Special 88 where my Dynaudio resides and put some pillows around it. Not an optimal position, which is exactly the problem with the Dynaudio setup right now, it is simply not able to perform as intended as I've installed it. To compare the two I felt it best to position it where I have the Dynaudio center. I should note, than once I'm settled on the Special 88, it will go onto the wall and behind some fabric and an AT screen infront of it. All the racks in the pictures will be removed.
In depth review will have to wait until it has more playtime, but the following clips I will leave some short comments on some scenes that incorperate center speaker action.
Hurt Locker - Barret scene. Compared to the Dynaudio in this scene, the dynamic impact of the shots are alot more impressive and they sound good, not just loud.
Transformers 3 - Optimus Prime voice is really awesome sounding. I had a friend over on testday two and we immediately noticed that Optimus' voice just sounded superb.
Avatar - Intro - first voice was quite "present" a bit overwhelming, did not sound natural. Once you switch to the scene in the cryotube, it sounded better. I found it odd, maybe the mix is like that?
Tron - Race - Very dynamic sounding, more ease to the sound and I could play this really loud without harshness. I was getting the kind of midbas impact I am searching for.
(Remind me to take notes, because I watched ALOT of clips but can't reminder
I though it to be generally neutral sounding, which the Dynaudio are as well, so it seemed pretty seamless with the Special 88 as center and Dyn left/right.
I won't be able to continue listening tests until a week from now, since I'm abroad working right now, which is a shame because I would rather be home watching movies!
My gut right now is, I'll be sorry that I didn't buy 3 right away!
PS: I had to to turn down the center channel 9dB to match the other speakers.
clausdk is offline
post #17 of 33 Old 10-11-2014, 05:25 AM - Thread Starter
clausdk's Avatar
Quoted: 205 Post(s)
Liked: 78
Just a small update. I havent had a real chance to fully evaluate it yet but it's installed in its resting place now.
I have remodelled my frontwall a bit and waiting for an AT screen. Right next to it to the left I will move two of my four rear 10" subs to complete the "baffle". The measurement below are with a quasi baffle that is just some absorbtion to. It's 9" deep and the dip around 373hz on the MLP response is SBIR I think? With the baffle it should be even better although not bad right now in terms of frequency respons. The MLP is 1/6 smoothed and then the other is average across the listening area.
clausdk is offline
post #18 of 33 Old 10-11-2014, 06:55 AM
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2682
AT screen is going over the speaker ?
Mfusick is offline
post #19 of 33 Old 10-11-2014, 07:03 AM - Thread Starter
clausdk's Avatar
Quoted: 205 Post(s)
Liked: 78
In front of, yes. There's also some fabric panels covering the acoustic "baffle" wall as well.
clausdk is offline
post #20 of 33 Old 10-11-2014, 12:44 PM
chrisslone's Avatar
Quoted: 72 Post(s)
Liked: 29
As much as I love the 88. I can't help but wonder what a 1010 or 1212 would do. SEOS-24 with dual tens or twelves?
chrisslone is offline
post #21 of 33 Old 10-11-2014, 01:56 PM
Erich H's Avatar
Quoted: 1406 Post(s)
Liked: 1771
It would be nice....and huge. About 28" wide, 30" tall and cost about $1300 in parts.
Mfusick likes this.
_______________________
The SEOS Waveguide Project
Erich H is offline
post #22 of 33 Old 10-11-2014, 02:26 PM
Samps's Avatar
Quoted: 789 Post(s)
Liked: 416
Could an 88 be made with the 8s on either side of the WG for a center?
Samps is online now
post #23 of 33 Old 10-11-2014, 02:48 PM
brian6751's Avatar
Quoted: 879 Post(s)
Liked: 675
Would need a Totally different design. You would be better off with the Alchemy Center Channel
Mfusick likes this.
brian6751 is offline
post #24 of 33 Old 10-12-2014, 11:34 AM
kgveteran's Avatar
Quoted: 363 Post(s)
Liked: 130
For some reason it reminds me of the M&K150 THX, but so much more... High efficiency, more focused at the listening position, and less expensive, a Win-Win !
post #25 of 33 Old 09-25-2015, 08:13 PM
Dbaudo1's Avatar
Quoted: 13 Post(s)
Liked: 2
I'm digging the grey even though they are being covered .
Dbaudo1 is offline
post #26 of 33 Old 09-26-2015, 03:05 AM - Thread Starter
clausdk's Avatar
Quoted: 205 Post(s)
Liked: 78
Hehe thanks. It turned out OK but close up it's lacking a bit.
clausdk is offline
post #27 of 33 Old 09-26-2015, 08:32 PM
kgveteran's Avatar
Quoted: 363 Post(s)
Liked: 130
Still the same opinion of the sound ?
post #28 of 33 Old 09-27-2015, 07:39 AM - Thread Starter
clausdk's Avatar
Quoted: 205 Post(s)
Liked: 78
Basicly yes.
In my room - some EQ is required. It could be placement, acoustical room issues etc. Lately I have used Dirac and the help of that is sounds absolutely wonderful. Voices are natural and everything sounds smooth.
clausdk is offline
post #29 of 33 Old 09-27-2015, 08:31 AM
corradizo's Avatar
Quoted: 1039 Post(s)
Liked: 695
corradizo is offline
post #30 of 33 Old 09-27-2015, 10:56 AM - Thread Starter
clausdk's Avatar
Quoted: 205 Post(s)
Liked: 78
Originally Posted by corradizo View Post
Some bloom in the 100-250hz range? (Guessing).
Not far off. I've had to work a little with it around 250-350hz. Took some harshness out of voices bringing that area down a bit. Could be my room and gear but that works for me.
What made you come up with those numbers?:-)
clausdk is offline
