Possible to Install SI HT 18" in Erich's 4 cuft Flatpack for Dayton-18"? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 07-25-2014, 03:50 PM - Thread Starter
Axel's Avatar
Quoted: 73 Post(s)
Liked: 24
I was wondering how difficult it is to install a SI HT 18" driver in one Erich's 4 cuft flat pack with cut out for a Dayton-18" driver.
Has anyone tried it? If so, with what level of success? What specifically needs to be modified?
____
Axel
Axel is offline
post #2 of 5 Old 08-14-2014, 12:37 AM
hondakilla98's Avatar
Quoted: 22 Post(s)
His website says
Woofer cut out for Dayton Audio RSS460HO-4 18": 18 3/16"
Woofer cut out for Stereo Integrity 18": 18 1/2"
So I'm guessing he sells one for each sub? If you already have the flatpack for the dayton, you'll have a lot of sanding in your future. I'd just ask him how much for a new baffle cut for the SI. Another option would be to remove the rubber surround and use a gasket.
hondakilla98 is offline
post #3 of 5 Old 08-14-2014, 08:34 AM - Thread Starter
Axel's Avatar
Quoted: 73 Post(s)
Liked: 24
Originally Posted by hondakilla98 View Post
His website says
He used to sell for the SI.
Currently, I am exploring the rabbet bit router route to make the cut out fit. If this falls through, I will probably go with a gasket.
____
Axel
Axel is offline
post #4 of 5 Old 08-14-2014, 09:05 AM
rhodesj's Avatar
Quoted: 852 Post(s)
Liked: 471
A rabbet bit with the right size bearing can control the depth of the cut. I've also used a chamfer bit to widen the top of a driver cutout that was slightly small. A roundover bit at partial cutting depth might work as well.
rhodesj is offline
post #5 of 5 Old 08-14-2014, 02:10 PM - Thread Starter
Axel's Avatar
Quoted: 73 Post(s)
Liked: 24
Thanks for the tips.
____
Axel
Axel is offline
