I have to many people to thank! I have been blessed with such amazing help on AVS!! Thank you all, again too many to thank!
This is what I have decided, and a HUGE thanks goes to Bassment, Lot, Donny, erich, marty, MANY MORE!!
Four pieces of 24 " x 48 " (top, bottom, side, side)
Two pieces of 24 " x 19.5 " (double baffle front)
One piece of 24" x 22.5 " (back)
One piece of 24 " x 44 " (port)
Two pieces of 3 " x 44 " ( port braces)
Various 24" x 2", 19.5" x 2" and 22.5" x 2" strips for internal bracing.
This box would be 24" tall, 25.5" wide, 48" long
I would just like a few other peoples opinions on this box size (making sure it makes sense) and tuning point (if someone could tell me the tuning point that would be awesome too lol)
My goal is to have MASSIVE clean bass output.
I will be making 2 of these, and hopefully using them as speaker stands, if not they will be placed behind my TV.
I have my INUKE3000DSP, and pre ordered 2 SI D4 18" subwoofers.
I will also order 2 Neutrik NL4MPR Speakon Connector 4 Pole Round Chassis Mount
I need to know what else I am missing, so I can make the rest of my order ASAP.
Next weekend I will make all the cuts, and hopefully full assembly. Where should I put the speakon connector? I was thinking right at the back middle of the subwoofer. Also how do I connect that to the woofer? What wire do I use? Do I need to solder it? Please let me know
Also when I do get the woofers in and subwoofer completed I will need a bit of assistance hooking the amp up to it, however that part I do not see being difficult for me.
Also when the si woofers are in stock I will be ordering the fusion10s and a quad4. I will contact erich directly for the cutsheets, and I can not see it being to difficult.
Again, I thank you ALL so much!! I will be calling it as the title stats -> The Island shaker -> someone gave me the idea and I feel bad for not remembering who. Anyways, you know who you are, and don't be shy, you deserve credit! Thanks for the awesome name!
