Beyma 8CX300ND/N for ATMOS Surround use? - AVS Forum | Home Theater Discussions And Reviews
 2Likes
  • 2 Post By mtg90
post #1 of 14 Old 07-26-2014, 02:13 AM - Thread Starter
Elill's Avatar
Quoted: 98 Post(s)
Liked: 89
Hi all,
ATMOS has thrown a massive spanner in the works for me, so I am looking at cheaper alternatives for surround duty (I'll need 10 in total so its not a small exercise).
I keep coming back to this driver from Beyma. Thoughts?
http://www.usspeaker.com/beyma%208cx300ndn-1.htm
It seems fairly well behaved off axis and can go in a small box.
Peter the Greek
Downunder Theatre MkII
List of Pro Designers
Elill is offline
post #2 of 14 Old 07-26-2014, 02:57 AM
A9X-308's Avatar
Quoted: 1280 Post(s)
Liked: 951
I'm sure it will be fine. Very expensive though, once you factor in the $95ea for the xovers. Something like the B&C 8CX21 would do just as well and be considerably cheaper and it's an excellent driver.
The Volt 8 would probably be fine and is cheaper still.
A9X-308 is offline
post #3 of 14 Old 07-26-2014, 03:56 AM - Thread Starter
Elill's Avatar
Quoted: 98 Post(s)
Liked: 89
I can land those for AUD230 each with crossover so not too bad
Peter the Greek
Elill is offline
post #4 of 14 Old 07-26-2014, 08:25 AM
pgwalsh's Avatar
Quoted: 392 Post(s)
Liked: 284
Hi all,
Looks nice for the in ceiling channels.
Have you seen the final spec for Atmos at home? I've see write-ups, but not the final spec with placement etc.
Diy Sound Group - Information & Tips
Builds: Maelstrom 21 Ottoman Build, Dual Opposed MFW's x 2, Statements, SEOS-12/TD12M x 5.
pgwalsh is offline
post #5 of 14 Old 07-26-2014, 12:09 PM
Quoted: 911 Post(s)
Liked: 489
I would not use any coax with an unterminated horn mouth jutting out of the woofer cone for any application where sound quality was remotely an issue.
"In many cases there aren’t two sides unless one side is 'reality' and the other is 'nonsense.'" - Phil Plait
Serious Audio Blog
DS-21 is offline
post #6 of 14 Old 07-26-2014, 12:17 PM
splotten's Avatar
Quoted: 268 Post(s)
Liked: 108
How about something like a KEF Q300. As far as i have seen the measure very well and is said to have a very nice SQ. Are they not loud enough? Seems to me like a speaker well suited for surround applications.
splotten is offline
post #7 of 14 Old 07-26-2014, 04:36 PM
mtg90's Avatar
Quoted: 412 Post(s)
Liked: 778
I have one of these lent to me by beastaudio for which I am going to design a custom crossover for. I expect the crossover parts will cost far less then $95 and tuned more appropriately for home use.
I have done some preliminary measurements and I agree that horn termination does cause some diffraction/off axis problems at the low end of its range however the top end >6khz is smoother both on and off axis then most that use the woofer cone as the waveguide.
My woofer tester broke about a month ago so I could not impedance measurements to start crossover work but I've managed to get some using a friends so the crossover work should start this weekend if all goes well with the other designs I am wrapping up (Karma-15, Fusion-15 v2.0 and Alpha-8 v1.3).
HopefulFred and Elill like this.
mtg90 is offline
post #8 of 14 Old 07-26-2014, 10:29 PM - Thread Starter
Elill's Avatar
Quoted: 98 Post(s)
Liked: 89
Excellent, I look forward to the results! thanks for the input
Peter the Greek
Elill is offline
post #9 of 14 Old 07-27-2014, 01:51 PM
Quoted: 911 Post(s)
Liked: 489
The Q300 has poor polars and cone break up issues. The smaller, cheaper Q100 is a considerably better speaker.
Serious Audio Blog
DS-21 is offline
post #10 of 14 Old 07-27-2014, 02:53 PM
splotten's Avatar
Quoted: 268 Post(s)
Liked: 108
OK? Thats a little surprising to me. Can you provide a link or something? I have seen somewhere that the bigger Q900 had some breakup, but not the Q300.
splotten is offline
post #11 of 14 Old 07-28-2014, 06:02 PM
noah katz's Avatar
Quoted: 878 Post(s)
Liked: 304
surprised no one has mentioned this
Design Challenge - Ceiling speakers for Dolby Atmos
Noah
noah katz is offline
post #12 of 14 Old 07-28-2014, 10:23 PM
Quoted: 911 Post(s)
Liked: 489
There are off-axis measurements posted on the KEF forum that clearly show the "midrange mushroom cloud" effect of mismatched directivity.
As for breakup, it's less of a concern than the poor polars (compared to Q100 or Q900) but still...largish metal cone, highish crossover, 1st order electric filter with no notch. There's a reason the R100 and LS50 build on the 5" variant of the current Uni-Q and not the 6.5.
Serious Audio Blog
DS-21 is offline
post #13 of 14 Old 07-29-2014, 02:21 AM
splotten's Avatar
Quoted: 268 Post(s)
Liked: 108
Ok. Im at a loss here. It may be that the Q100 has better matched directivity than the Q300 but on the other hand I really cant find anything suggesting that Q300 should have "poor polars and cone break up issues" as you stated in you other post. I tried finding the measurements you are referencing but came up empty. Can you please provide a link?
splotten is offline
post #14 of 14 Old 07-30-2014, 07:50 PM
Quoted: 911 Post(s)
Liked: 489
Search through my comments on the KEF owner's thread in the speaker's section and you'll find an analysis of someone else's 3d party measurements.
Serious Audio Blog
DS-21 is offline
