DIY SEOS 1099 Build - AVS Forum | Home Theater Discussions And Reviews
 7Likes
post #1 of 32 Old 07-26-2014, 06:10 PM - Thread Starter
mikehenya's Avatar
DIY SEOS 1099 Build
I want to thank everyone for posting their DIY builds Just a little history.... I just wanted to tell everyone how my build goes, hopefully to inspire more folks to stop wasting money on mass produced sound. This is my 3rd DIY speaker, but my first with a crossover. I have built 2 DIY subs using RE XXX Driver and they DESTROY any of my previous subs. I have an 18" sealed and a 15" ported, both in home made enclosures. The 18" is in a sealed box and the 15" is slot ported. I love it, before the build I was running a Velodyne HGS 15 and 2 12" infinity subs. I am powering the subs with an iNuke6000 and they blow away anything else I have ever seen. I have a hard room to balance for HT. It is 30x24 with 8' ceilings, however both ends are open to the kitchen/entry way. The RE XXX subs work awesome! I realize others have better HT systems, but this is what I made withing my budget, and it is better than the local cinema! I was lacking a little in the "woofer" range, but otherwise I have been very happy. I have 2 JBL old school towers as my "front wide" channel, 2 B&W CDM SE mains, 2 B&W rears and 2 Definitive wide side channels. I am running a big AV123 center currently with the Ninja upgrade kit. I have burnt a cap in this unit twice running an Emotiva amp on my front LCR.
After much reading I decided to try the "Elusive 1099" from DIYSoundGroup as my new Center channels. I was impressed with the quick responses from Erich. I bought the 1099, the flat pack and the crossover kit.
The pieces were all packaged great and arrived safely. The initial fit was great.
This is my first attempt at a crossover, so I welcome any constructive criticism. I will update as the project progresses....
ID:	181546   Click image for larger version
ID:	181554   Click image for larger version
skipford likes this.
mikehenya is offline
post #2 of 32 Old 07-26-2014, 06:16 PM - Thread Starter
mikehenya's Avatar
This is my first attempt at a crossover, so I welcome any constructive criticism. I will update as the project progresses....[/quote]
Finished initial layout on the crossover, per another user schematic'....
post #3 of 32 Old 07-26-2014, 06:46 PM
chalugadp's Avatar
Quoted: 1670 Post(s)
Liked: 1505
Just sold my current center channel and as soon as elusive is available I will be ordering one.
Going to do a curved build like dtsdig. Using this veneer
Black adder likes this.
chalugadp is offline
post #4 of 32 Old 07-26-2014, 07:25 PM - Thread Starter
mikehenya's Avatar
Very nice! I am going to go with the standard Duratex...... The grey in my interior is the Duratex sound dampening. Goes on like drywall mud. Not sure if it will make a difference or not, but it is supposed to make the cabinet sound more "solid".
post #5 of 32 Old 07-26-2014, 07:42 PM
Robert Jones II's Avatar
Quoted: 113 Post(s)
Liked: 64
Got my 1099s this past week and will be beginning my build soon also. I didn't order the flat packs... time will tell if that was a mistake . I will be following along with great interest! Good luck and have fun!
Robert Jones II is offline
post #6 of 32 Old 07-26-2014, 08:20 PM - Thread Starter
mikehenya's Avatar
I don't have a table saw, so the flat packs were a no brainer. They fit near perfect fit, glued easily and look great.
post #7 of 32 Old 07-26-2014, 08:42 PM
frankie2075's Avatar
Quoted: 453 Post(s)
Liked: 108
how do the 1099S compare to the Fusion 15? is it a step up? will they come back to the DIYsoundgroup?
frankie2075 is offline
post #8 of 32 Old 07-26-2014, 08:48 PM
chalugadp's Avatar
Liked: 1505
What's the exterior measurements ?
post #9 of 32 Old 07-26-2014, 11:12 PM
Quoted: 113 Post(s)
Liked: 64
Unless the flat packs are different, I believe the exterior measurements should be 12.5" wide x 36.25" tall x 14.5" deep.
post #10 of 32 Old 07-26-2014, 11:27 PM
chalugadp's Avatar
Liked: 1505
I have seen a couple different sizes in builds.
post #11 of 32 Old 07-27-2014, 02:29 AM
mbyrnes's Avatar
Quoted: 93 Post(s)
Liked: 186
Mine are only 12.5" deep. Fatshaft made his 14.5" deep. I did a single baffle, think he did a double. Double really isn't necessary for these.
mbyrnes is offline
post #12 of 32 Old 07-27-2014, 05:21 AM
Quoted: 113 Post(s)
Liked: 64
Frankie I don't have a direct answer to your question, but since most folks are interested in comparing the 1099s to the Fusion Tempests it might be worth reading the impressions from this get together (GTG): Vancouver Summertime GTG Results
post #13 of 32 Old 07-27-2014, 05:33 AM
Quoted: 113 Post(s)
Liked: 64
The most recently listed dimensions on DIY Sound Group's page (screenshot attached) were what I posted above (14.5" deep), but I am not sure it matters all that much. The crossover has gone through several design iterations, so it's possible that the box dimensions may have done the same. Several people have gone with slightly different variations in dimension and bracing and nobody seems to be complaining
chalugadp and Boxozaxu like this.
post #14 of 32 Old 07-27-2014, 06:41 AM
chalugadp's Avatar
Liked: 1505
I was at the gtg and I much preferred the 1099 to the tempest. More snap,dynamic, and better midrange. Only thing tempest did better was midbass.
post #15 of 32 Old 07-27-2014, 07:04 AM - Thread Starter
mikehenya's Avatar
You are correct....those are my dimensions as well.
post #16 of 32 Old 07-27-2014, 07:10 AM - Thread Starter
mikehenya's Avatar
Can someone give my crossover assembly a quick look over. I know it is hard to tell from the pic, but I just want to be sure my coil placement looks good and nothing is backwards.
Thanks to Fatshaft's tux 1099 build for the layout !
ID:	182306   Click image for larger version
ID:	182314   Click image for larger version
ID:	182322   Click image for larger version
post #17 of 32 Old 07-28-2014, 05:36 PM - Thread Starter
mikehenya's Avatar
Trying out some of the Duratex dampener. Figured I would give it a try since I had to order the Duratex anyhow......reminds me of drywall mud.
No comments on the crossover?
ID:	184554   Click image for larger version
post #18 of 32 Old 07-28-2014, 05:53 PM
mbyrnes's Avatar
Quoted: 93 Post(s)
Liked: 186
The inductor without the core I would turn and lay flat. All else looks good from what I can see. Good job soldering!
mbyrnes is offline
post #19 of 32 Old 07-28-2014, 09:36 PM - Thread Starter
mikehenya's Avatar
Thanks for the tip, I haven't had a ton of time to read up on crossovers. I'll lay it down this weekend.
post #20 of 32 Old 07-29-2014, 09:35 AM
mbyrnes's Avatar
Quoted: 93 Post(s)
Liked: 186
I am sure you can find pictures of the magnetic field inductors create. Someone posted it before but I have no idea where, lol.
mbyrnes is offline
post #21 of 32 Old 07-29-2014, 09:57 AM
dtsdig's Avatar
Quoted: 814 Post(s)
Liked: 900
This one?
dtsdig is offline
post #22 of 32 Old 07-29-2014, 10:14 AM - Thread Starter
mikehenya's Avatar
You guys are awesome! Thanks!
post #23 of 32 Old 07-29-2014, 10:15 AM
mbyrnes's Avatar
Quoted: 93 Post(s)
Liked: 186
Originally Posted by dtsdig View Post
This one?
Yep! Thanks!
mbyrnes is offline
post #24 of 32 Old 08-02-2014, 06:01 PM - Thread Starter
mikehenya's Avatar
Ok, so I just finished the test fit for everything, so far so good:
post #25 of 32 Old 08-02-2014, 06:03 PM
chalugadp's Avatar
Liked: 1505
Nice, envious.... Still waiting for its shipped email.
post #26 of 32 Old 08-02-2014, 06:06 PM - Thread Starter
mikehenya's Avatar
Just applied the first coat of Duratex....I am impressed, the coverage and texture is fantastic! I used a foam 4" roller for the first coat, I am going to do 2 additional coats with a wider roller.
post #27 of 32 Old 08-02-2014, 06:12 PM - Thread Starter
mikehenya's Avatar
I did a quick listen to make sure my crossover was ready.....even without any adjustments, it sounded fantastic!
post #28 of 32 Old 08-02-2014, 06:48 PM
chalugadp's Avatar
Liked: 1505
Its a great speaker
post #29 of 32 Old 08-03-2014, 08:03 PM - Thread Starter
mikehenya's Avatar
Ok, so it is done, and it is AWESOME!! Can't wait to Duratex my subs next! I guess I will have to sell of some stuff and build 2 more for the front!
Ignore the mess, did most of this in the living room, lol.
ID:	195665   Click image for larger version
post #30 of 32 Old 08-03-2014, 08:10 PM
chalugadp's Avatar
Liked: 1505
Are those b&w mains ? Is the 1099 tilting down a bit ?
Looks good
