Need help designing serious bass solution for a big theater..horns vs ported or both? - Page 8 - AVS Forum | Home Theater Discussions And Reviews
 98Likes
post #211 of 505 Old 07-31-2014, 05:54 PM - Thread Starter
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2697
OK really quick... The space thing keeps coming up but I am not looking for the most bass per space, I am looking for the best bass possible in unlimited space. 90 cubic foot cabinets and multiples of them is fine.
I can't simply double up the drivers of say an LMS Ultra and get the same output per space because my wife will leave me if I charge all those drivers on our credit card, and I'll end up paying child support, never seeing my kids while my wife runs off with another guy who has bigger subwoofers than me. That would suck a lot. Nope. Can't do that.
So LMS is fine but $2000 means I can get 2 of them. That's it. Only 2 is going to get pounded by $2000 of APLINE drivers in big folded horns, or 8 SI18's in big ported boxes. The bass per space might be important for some, but it's irrelevant here. I'm looking for the absolute best bass solution for $2000 in drivers and a reasonable amount in amps and other stuff. Best means a lot of things, headroom, dynamics, distortion, smoothness at the LP, SPL, extension etc... I WANT IT ALL. Too much is almost enough. Winning designer gets to be proclaimed a genius and see their creation built by me !
This will never be a pussified WAF factor build here. Embrace the crazy. It doesn't come too often.
Mfusick is offline
post #212 of 505 Old 07-31-2014, 05:58 PM
Decadent_Spectre's Avatar
Quoted: 379 Post(s)
Liked: 179
Originally Posted by notnyt View Post
Mostly in agreement, but OP mentioned he wanted extension to 14 or 15hz. There's not going to be a horn that will adequately provide that. Mixing and matching, you still won't keep up on the bottom end, so it ends up being an exercise in futility. By the time you can keep up on the bottom end, you might as well run everything full range and then there's no real need for horns at all in this scenario. I won't argue at all that horns will be more efficient and provide more output above certain frequencies, however I personally feel they don't provide adequate output down low, especially for an HT application.
For music, it's not much of a competition. If you have the space, horns will kick ported ass since you can get away with running only 35hz and up.
When my lab15s get here, I'd build a horn if I could fit one under my bench. Unfortunately, ported box tuned to ~34hz it is in ~5cufft.
This is partly why I was suggesting a dual approach, a dual approach allows him to get the raw power of a horn in the higher frequencies with a 30-40Hz tune and he can build a ULF solution for the low end.
I disagree about the horn not providing enough low end, he has the space to make it large enough I think. Large low tuned FLHs are uncharted territory for this very reason, because no one ever has the space nor wants to take the risk. Everyone just wants to follow the leader. Have you noticed how ported subs started gaining in popularity after you switched?
Joking aside, I do think he can make a large low tuned low bass horn and a bass/mid bass horn work with a few caveats, one is getting the right design. I will be the first one to say that with poor design the FLH looses its greatness. Second, integration. If he can cross these two bridges then hes got it all in the bag.
The type of bass one likes should factor into their decision for a system in my view, you may have a mismatch of output with horns but EQ is available, at worst its extra unused headroom keeping the system especially linear in the more audible and impactful frequencies, I don't see a downside to that. You mention theres no reason to build a horn for full range, what I have been trying to explain is that for people who like horns it is more about their sound and feel, not about measured SPL.
Decadent_Spectre is offline
post #213 of 505 Old 07-31-2014, 05:58 PM
Cortga's Avatar
A horn can do 14 or 15 Hz no problem, but it doesn't fit under a workbench
Mfusick likes this.
Cortga is offline
post #214 of 505 Old 07-31-2014, 05:59 PM
notnyt's Avatar
Quoted: 2772 Post(s)
Liked: 2556
I wasn't suggesting that for you. look at what I suggested and modeled for you. namely the um18-22 and zv4 18 which you can get cheaper than uxl18.
notnyt is offline
post #215 of 505 Old 07-31-2014, 06:01 PM - Thread Starter
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2697
What is this:
That's got a nice fat bottom
Mfusick is offline
post #216 of 505 Old 07-31-2014, 06:03 PM - Thread Starter
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2697
I saw quickly but I have not had the time to digest it fully, but rest assured I am appreciative and shall respond!
Kids are crying.. it bed time for them. I'll be back.
Mfusick is offline
post #217 of 505 Old 07-31-2014, 06:03 PM
notnyt's Avatar
Liked: 2556
don't want that low for my garage, just for music. frequency is fine, just no room for horn
notnyt is offline
post #218 of 505 Old 07-31-2014, 06:07 PM
notnyt's Avatar
Liked: 2556
What is this:
must be th if horn
notnyt is offline
post #219 of 505 Old 07-31-2014, 06:15 PM
Cortga's Avatar
must be th if horn
Sorry, That is the measurement of the horn I built
The Crawler, A Floor joist horn build
Cortga is offline
post #220 of 505 Old 07-31-2014, 06:20 PM - Thread Starter
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2697
Such a great idea ^
lol.
I could do something like this and park it in the garage below, feeding up from the floor?
or like this:
I think indoors and near field those might kick ass ^
Mfusick is offline
post #221 of 505 Old 07-31-2014, 06:50 PM
Quoted: 379 Post(s)
Liked: 179
Where is that homer drooling pic...
If you build that, I am going to be tempted to fly to the US to listen to your system...
Your comment about near field is a good one, you want near field for insanity.
post #222 of 505 Old 07-31-2014, 07:42 PM
michael hurd's Avatar
Quoted: 112 Post(s)
Liked: 107
First before anything else, I would want you to acquire and learn to use a microphone and a measurement system. For $ 150ish ( or less depending on what you buy ) and a laptop you can learn a quite a bit measuring.
Go to GTG's, listen to other people's stuff and measure it.
Spoon feeding with a 9 yd bucket.
michael hurd is offline
post #223 of 505 Old 07-31-2014, 07:52 PM
lilmike's Avatar
Quoted: 70 Post(s)
Liked: 178
+1
Proper measurements are the only way to "know".
If you're serious about design, you really need to measure impedance too.
lilmike is offline
post #224 of 505 Old 07-31-2014, 07:55 PM
lilmike's Avatar
Quoted: 70 Post(s)
Liked: 178
...snip...
Hmmm.....
Mfusick likes this.
lilmike is offline
post #225 of 505 Old 07-31-2014, 08:00 PM
maxmercy's Avatar
Quoted: 63 Post(s)
Liked: 168
I don't get this.
You say that this theatre will be huge, decked out, star ceiling, custom floor plan, bar, and the subwoofers get the K-Mart budget? WTF.
You are talking about spending HUNDREDS of hours designing, building, testing, scrapping, redesigning a horn that will only get you 3Hz more extension than existing designs that have been tested and proven. WTF.
You want to spend all this time doing this as a new father of twins. WTF.
You have probably never experienced clean reference level, but want 10dB more. Notnyt makes a TREMENDOUS point. Go to NY, experience his system and determine whether or not you need that kind of SPL. Then go to popalock's house and see if you want stuff below 12-15Hz. You just might.
You will build a multi-thousand dollar theater and you want to crack the drywall and break the room you spent thousands (if not tens of thousands) on with the sound system? WTF.
Seriously. This thread has just jumped a freakin' school of sharks.
Oh, and to all the folks who claim the superiority inherent in horns:
Set up a blinded test in an open field (no room effects) in which WELL DESIGNED sealed, ported and horn loaded enclosures have identical freq response, identical distortion curves (or as close as you can get), and identical headroom with proper time and phase alignment to the mains and play them at identical SPL and see who can pick which one is which and which is best. I will then believe one enclosure type is superior. Otherwise, just saying one type is 'best' is smoke-filled, coffee house crap.
JSS
Willie, LTD02, notnyt and 1 others like this.
maxmercy is offline
post #226 of 505 Old 07-31-2014, 08:33 PM - Thread Starter
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2697
I think you are over reacting just a tad have some fun with this, and don't be upset about stuff that hasn't happened yet, it might never. I'm just trying to find the best solution for me, and I don't consider $2000 in drivers to start "cheap" because it's a lot of money to me and my family. I also said I'd like to upgrade or an upgrade path. My goal is to get the best possible theater I can for my allotted budget and to create an awesome space to chase my hobby and passion for many years to come. I'm well aware of the financial and time constraints. If I did not enjoy this stuff I wouldn't be here.
Mfusick is offline
post #227 of 505 Old 07-31-2014, 08:36 PM - Thread Starter
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2697
Originally Posted by lilmike View Post
+1
+2 . I'm on board 100% with this.
Mfusick is offline
post #228 of 505 Old 07-31-2014, 08:37 PM
notnyt's Avatar
Liked: 2556
The problem with getting that extra extension with a horn is that the size requirements expand exponentially. Furthermore, a FLH has a rising response, and down at low frequencies, they lose their advantage. Perhaps a tapped horn properly designed could dig low enough. Something else to consider is a 6th order bandpass setup.
notnyt is offline
post #229 of 505 Old 07-31-2014, 08:43 PM - Thread Starter
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2697
Can we rewind a second and touch back on tapped horn vs front or offset again ?
I've read a couple conflicting things; I've read that offset or front loaded was better but took more space or that in other words tapped could hit lower extension in the same space. True ?
I thought I read Lilmike said earlier he liked his tapped horns better and thought they sounded better. (True?)
Mike could you quickly answer:
Of all your designs which is your favorite and why?
Of all your designs which is loudest ?
Of all your designs which is lowest?
I'd really appreciate your opinion and feedback.
Mfusick is offline
post #230 of 505 Old 07-31-2014, 08:48 PM
notnyt's Avatar
Liked: 2556
I've read a couple conflicting things; I've read that offset of front loaded was better but took more space or in other words tapped could hit lower extension I. The same space. True ?
Tapped horns are more efficient. You utilize the back wave to increase efficiency. They do not do as well at higher frequencies as a front loaded horn, but they do not roll off as far down low. The Gjallerhorn is a tapped horn.
I still think that for your requirements, 2k in drivers, 1k in amps, the solution I outlined earlier will be the most robust with the greatest extension. SPL levels higher than you can probably stand. You say you want an upgrade path, but I can't really imagine needing or wanting to upgrade from there. Maybe get some Crowsons or something down the road
If someone thinks otherwise, post up a model with whatever you have. This is what I posted earlier.
Here's some modeling for you real quick, sticking to your budget. Bottom line is 2x um18-22 in a 30 cubic foot ported enclosure tuned to 16hz. Next is 4 woofers, then 8 woofers. That runs a few dollars over 2k, but you can probably get a discount if you call them directly. They're modeled with 1kw per driver.. so 8kw for 8 drivers. System stays below xmax and port air velocity isn't a problem. FP14000 will power the entire system, or you can get a pair of nu6000dsp, or whatever else floats your boat. Wood will run ~400. That's insanely loud.
This is with 1000 watts per driver, highpassed to control excursion below tuning.
ID:	191018   Click image for larger version
Mfusick likes this.
notnyt is offline
post #231 of 505 Old 07-31-2014, 08:54 PM
notnyt's Avatar
Liked: 2556
Just updated above post after you read it, just letting you know.
notnyt is offline
post #232 of 505 Old 07-31-2014, 09:02 PM
notnyt's Avatar
Liked: 2556
Interesting, do you have a model or drawing of it? Hard to get a good idea how it went together from the pics.
notnyt is offline
post #233 of 505 Old 07-31-2014, 09:03 PM - Thread Starter
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2697
First question is I'm not as familiar with the um18-22. Can you link me up?
Better or worse than uxl18?
Mfusick is offline
post #234 of 505 Old 07-31-2014, 09:09 PM
notnyt's Avatar
Liked: 2556
Not as good, but half the price. Supposed to stop being vaporware this week. We'll see. I'd go zv4 18 from sundown before uxl18. They're cheaper than UXL18 by a bit as well, and ship from the US. A friend/sudown dealer has a large order coming in shortly. He's putting 8 in my old sealed enclosures. There will be pics.
um18-22: http://www.parts-express.com/dayton-...-coil--295-518
sundown zv4 18: http://www.sundownaudio.com/index.ph...-4-series.html
notnyt is offline
post #235 of 505 Old 07-31-2014, 09:09 PM
chrapladm's Avatar
Quoted: 937 Post(s)
Liked: 350
I love exploring but I dont think your going to beat Not's suggestion. Either way this would be a killer sub system.
Not speaking of 6th order have you ever built a system like Mr Seatons? I dont know if you recall seeing the pictures he posted of a 4th or 6th order type system he built for someone that looked quite interesting. I think he used 18 TC PR's but I could be wrong. I am assuming you have seen it. Either way just curious.
chrapladm is offline
post #236 of 505 Old 07-31-2014, 09:17 PM
Cortga's Avatar
I modeled it in hornresp and used the output to make a template, then built it in place, measure twice then cut to fit.
Cortga is offline
post #237 of 505 Old 07-31-2014, 09:17 PM
notnyt's Avatar
Liked: 2556
I remember seeing some interesting builds from him, but I don't recall anything bandpass. I recall seeing him building something with 15's behind some 18" prs.
notnyt is offline
post #238 of 505 Old 07-31-2014, 09:32 PM - Thread Starter
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2697
Those do look awesome .
Quick question I've never asked. Would mixing different subs be problematic in the same style enclosure and tune?
Let's say I started with 4 of something ported at 15hz. Added 4 more of something else at later date also ported at 15hz. Problem ?
Mfusick is offline
post #239 of 505 Old 07-31-2014, 09:33 PM
notnyt's Avatar
Liked: 2556
Phase might be different, hard to say. If you place them in a different location it might not be that bad? I generally would stay homogenous.
notnyt is offline
post #240 of 505 Old 07-31-2014, 09:34 PM
chrapladm's Avatar
Quoted: 937 Post(s)
Liked: 350
Ya that was it. I dont recall what configuration it was. I am always limited on space so different configurations sometimes are a good thing. Although a simple ported seems to best most of those other cabinet types.
