Eminence driver sale - Page 2 - AVS Forum | Home Theater Discussions And Reviews
 13Likes
post #31 of 94 Old 07-30-2014, 12:03 PM
pony9134's Avatar
Quoted: 66 Post(s)
Liked: 69
does anyone think it would be worth swapping my ultimax out for one of these in my 3cft sealed, with the spa 500 amp
pony9134 is offline
post #32 of 94 Old 07-30-2014, 12:48 PM
notnyt's Avatar
Quoted: 2791 Post(s)
Liked: 2573
Originally Posted by d_c View Post
Sealed or ported? A couple of T-60 would sound nice too.
Prob ported around 30hz. Need to model it out some more.
notnyt is offline
post #33 of 94 Old 07-30-2014, 12:52 PM
notnyt's Avatar
Liked: 2573
no
notnyt is offline
post #34 of 94 Old 07-30-2014, 04:00 PM
Stumbo's Avatar
Quoted: 55 Post(s)
Liked: 88
I'm going to grab a pair for backyard duty.
Stumbo is offline
post #35 of 94 Old 07-30-2014, 06:45 PM
notnyt's Avatar
Liked: 2573
Was considering building something full range with these. Going to see how they model soon and maybe toss an seos15 or something up top. Might also just end up using em for sub duty. Will see.
notnyt is offline
post #36 of 94 Old 07-30-2014, 07:03 PM
cookieattk's Avatar
Quoted: 111 Post(s)
Liked: 91
i really feel compelled to buy 8 and put them in a huge synergy horn that wouldn't fit in my space
cookieattk is offline
post #37 of 94 Old 07-30-2014, 07:12 PM
d_c
d_c's Avatar
Quoted: 896 Post(s)
Liked: 1035
I'm using these or my sdx15 as the low end for a 3 way using the TD12m and seos 12 for the top.
d_c is offline
post #38 of 94 Old 07-30-2014, 08:00 PM
maxmercy's Avatar
Quoted: 63 Post(s)
Liked: 169
Two 675L horns will get you >130dB before power compression losses with these drivers from 30-150Hz, under Xmax. Eight gets you 142dB. Not bad for a backyard system.
JSS
maxmercy is offline
post #39 of 94 Old 07-30-2014, 08:06 PM
MDST's Avatar
Quoted: 32 Post(s)
How about two Eminence Lab12 for 130$ new?? What do you guys think about those Lab12?? Sealed or vented? Medium room, most movies!
MDST is offline
post #40 of 94 Old 07-30-2014, 08:29 PM
notnyt's Avatar
Liked: 2573
ebay 4 ohm vs normal 6 ohm. 4 ohm in red.. sealed and ported plotted. sealed in 2 cubes, ported in 3 cubes tuned to 35hz. 800w to sealed, 1000w to ported.
These model pretty nice.
And in a 4 cubic foot box...
ID:	189330   Click image for larger version
ID:	189338   Click image for larger version
notnyt is offline
post #41 of 94 Old 07-30-2014, 09:00 PM
notnyt's Avatar
Liked: 2573
Looks like I'm going to build a 6 cubic foot enclosure for this, tuned to 34hz. Will setup a 4th order or steeper 28hz butterworth highpass filter. This is how it models with 800w. Red is ebay 4ohm, other is 6 ohm standard. Will use two of the PE 6" ports or more likely a slot port since it doesn't cost anything.
I'm not exactly sure where this is going yet, but will post build plans. This will be a music only sub for my garage.
ID:	189370   Click image for larger version
ID:	189378   Click image for larger version
notnyt is offline
post #42 of 94 Old 07-30-2014, 11:01 PM
d_c
d_c's Avatar
Quoted: 896 Post(s)
Liked: 1035
Looks fun, these are a treat. Using PVC as ports is my favorite lately: routes nicely for a big flare and is cheap. I think it's easier than slots, looks good, and is fun to build. But, you get free bracing with slots. The 28hz filter is still ok with a Fs of 34?
d_c is offline
post #43 of 94 Old 07-30-2014, 11:25 PM
notnyt's Avatar
Liked: 2573
excursion graph above is with 28hz 4th order. 30 might be a little happier.
notnyt is offline
post #44 of 94 Old 07-31-2014, 07:17 AM
LFM2's Avatar
Lab 15
The specs of these ebay Lab 15's look like they might work well in a Klipsch LaScala type bass bin. I'd like to use them up to 250 hz with a Synergy horn above. What do you guys think?
LFM2 is offline
post #45 of 94 Old 07-31-2014, 07:42 AM
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2698
basshead81 likes this.
Mfusick is offline
post #46 of 94 Old 07-31-2014, 08:45 AM
Bassment's Avatar
Quoted: 946 Post(s)
Liked: 379
Wow these are such a good deal, must resist. What was the shipping cost on one or two?
Bassment is offline
post #47 of 94 Old 07-31-2014, 09:55 AM
notnyt's Avatar
Liked: 2573
was high $20s to ship two of em to NY, I think I got two for just under $240
notnyt is offline
post #48 of 94 Old 07-31-2014, 10:31 AM
Bassment's Avatar
Quoted: 946 Post(s)
Liked: 379
wow I just bought 2, I don't even want them.
Bassment is offline
post #49 of 94 Old 07-31-2014, 10:32 AM
notnyt's Avatar
Liked: 2573
Keep in mind, these are higher fs and different specs than original lab15s.
notnyt is offline
post #50 of 94 Old 07-31-2014, 10:38 AM
Bassment's Avatar
Quoted: 946 Post(s)
Liked: 379
can you post the T/S?
Bassment is offline
post #51 of 94 Old 07-31-2014, 10:41 AM
notnyt's Avatar
Liked: 2573
already did
notnyt is offline
post #52 of 94 Old 07-31-2014, 10:50 AM
Bassment's Avatar
Quoted: 946 Post(s)
Liked: 379
Bassment is offline
post #53 of 94 Old 07-31-2014, 11:15 AM - Thread Starter
chalugadp's Avatar
Quoted: 1674 Post(s)
Liked: 1532
Man I should get a cut of this guys take
chalugadp is offline
post #54 of 94 Old 07-31-2014, 11:33 AM
Bassment's Avatar
Quoted: 946 Post(s)
Liked: 379
I think I'm going to do 27 hz tune, 5.5 cu ft box, 25 hz 2nd order HPF, each one ran off of my two spare channels of my inuke nu4-6000 that does exactly 600 watt rms (that were reserved for my Tempests, but I'll just keep using those off my receiver)
Bassment is offline
post #55 of 94 Old 07-31-2014, 12:56 PM
d_c
d_c's Avatar
Quoted: 896 Post(s)
Liked: 1035
d_c is offline
post #56 of 94 Old 07-31-2014, 01:16 PM
Bassment's Avatar
Quoted: 946 Post(s)
Liked: 379
Bassment is offline
post #57 of 94 Old 07-31-2014, 01:23 PM - Thread Starter
chalugadp's Avatar
Liked: 1532
Face looks like a si driver
post #58 of 94 Old 07-31-2014, 02:00 PM
joebuddyguy's Avatar
Quoted: 65 Post(s)
Liked: 110
looking good...can't wait to get mine. It was very opportune timing as I was just about to order a pair of those infinity reference 1262w's. I think these will have a "tad" more oomph and for not a whole bunch more money. I think they look a lot nicer to boot
joebuddyguy is offline
post #59 of 94 Old 07-31-2014, 02:06 PM
d_c
d_c's Avatar
Quoted: 896 Post(s)
Liked: 1035
foam surround looks good to me, what don't you like?
I like the look, but the foam wears out faster than the rubber surrounds. It's definitely not a deal breaker. I guess most of the ones that have started cracking and falling apart on me have been 15-20 years old. I will probably have them swapped out long before that.
I really like the flat dust cover. That and the cone are pretty beefy material. I ran some 20hz tones on each for about 15 minutes and they function well and are both good to go for a day of break in.
d_c is offline
post #60 of 94 Old 07-31-2014, 06:37 PM
lemonslush's Avatar
Quoted: 828 Post(s)
Liked: 414
Anyone making a sealed box?
lemonslush is offline
