brand new to the game! - AVS Forum | Home Theater Discussions And Reviews
post #1 of 10 Old 07-28-2014, 09:48 AM - Thread Starter
Black Cat 13's Avatar
Quoted: 14 Post(s)
Liked: 0
im looking to build my own studio and home theater speakers and subwoofers. i have some wood work experience. i currently own a table saw, impact and power drills, sander and a porter-cable 2 1/2 hp plunge router. im waiting on my jasper jig pro 200 to get here. i need some help on router bits. i need a bit for cutting perfect circles and flush mounting. a round over bit would be nice to. im not trying to get to fancy, just the basic bits i need to make my job easier. also, i bought a brand new router and i found these 2 bits in the packaging. will these be any good for what im trying to do? thank you
1). 1/2" pattern/flush trim bit
1/4" diameter shank
2). 3/4" pattern/flush trim bit
1/2" diameter shank
ID:	184026   Click image for larger version
ID:	184034   Click image for larger version
Black Cat 13 is offline
post #2 of 10 Old 07-28-2014, 11:42 AM - Thread Starter
Quoted: 14 Post(s)
Liked: 0
anybody?
post #3 of 10 Old 07-28-2014, 11:51 AM
mbyrnes's Avatar
Quoted: 93 Post(s)
Liked: 186
Well what are you trying to do? Build your own design from scratch? That's much more difficult and could take a while to perfect.
You looking for a pre-designed speaker that you can build and finish yourself that you know will sound good?
What are your goals? High spl? Certain size? You building subs? Any info will help
mbyrnes is offline
post #4 of 10 Old 07-28-2014, 12:08 PM
Bassment's Avatar
Quoted: 904 Post(s)
Liked: 364
those look like really cheap bits so they probably aren't that useful. Most useful bits are a 1" cut length flush trim bit (similar to yours, but a better quality one), an upspiral bit for cutting out circles, a roundover bit for the edges of the boxes (if you don't want it to have square edges). Get all the bits with 1/2" shank.
Check out diysoundgroup.com for some really good speaker kits. Most popular ones are the 1099's, Fusion 12 tempests, and Fusion 8 Alchemy's. For subs, if you can do 4 subs or more go with Stereo integrity 18" drivers, if less than 4 look at UXL-18 from innovative sound technologies (mach5 audio).
Bassment is offline
post #5 of 10 Old 07-28-2014, 12:09 PM - Thread Starter
Quoted: 14 Post(s)
Liked: 0
i plan on building high efficient bass horns and monitors. use someone elses designs. im pretty good at reading blue prints. i just need a little help with router bits. ive always used other peoples routers. this is my first router set up.
post #6 of 10 Old 07-28-2014, 12:12 PM - Thread Starter
Quoted: 14 Post(s)
Liked: 0
MLCS makes cheap bits? thats what these bits are. same from the kit below
http://www.ebay.com/itm/like/191255139123?lpid=82
post #7 of 10 Old 07-28-2014, 12:38 PM
Bassment's Avatar
Quoted: 904 Post(s)
Liked: 364
MLCS does make cheap bits, but they make some pretty decent quality ones too though. The 3/4" bit you have is too short to flush trim speaker boxes, and the 1" one you have is long enough, but I would be worried about the 1/4" shank. I'd suggest buying one of their higher quality 1/2" shank, 1" or more cut, flush trim bits, they're only like 12.00 but it would give you a much faster and better cut for flush trimming than the ones you have I think.
Or you could probably just buy one of their bit sets instead, that's what I did. They're a really good value.
Bassment is offline
post #8 of 10 Old 07-28-2014, 01:33 PM - Thread Starter
Quoted: 14 Post(s)
Liked: 0
your speaking foreign language to me lol. could you send me a link to the bits you described? there's so many different types of bits. i tried googling... im lost
post #9 of 10 Old 07-28-2014, 01:41 PM - Thread Starter
Quoted: 14 Post(s)
Liked: 0
so... i need bit like the ones i have circled in the picture? these are 1/2"
post #10 of 10 Old 07-28-2014, 02:24 PM
Bassment's Avatar
Quoted: 904 Post(s)
Liked: 364
I have this set http://www.mlcswoodworking.com/shops...et15piece.html
It is fairly limited with what you can do but is good enough for building speakers.
The one thing it's missing is an up-spiral bit, which will cut circles better than a straight cut. http://www.mlcswoodworking.com/shops.../bt_solid.html something like the 901, 902 or 903 would be good.
The flush trim in this set isn't super great but it works, as it's a 1" cut length.
Bassment is offline
