Duratex Alternative - AVS Forum | Home Theater Discussions And Reviews
 49Likes
post #1 of 188 Old 07-28-2014, 05:17 PM - Thread Starter
chalugadp's Avatar
Quoted: 1673 Post(s)
Liked: 1529
Duratex Alternative
Hey folks,
I was in Home Depot today and saw this product
Saw commercials for this product and was intrigued. It was only 35$ a gallon and they had 20 different colors. I bought a gallon of black and tried it out. Didn't have a tonne of time but I put some on bare MDF and then a coat over top of my sub with duratex already. I sanded down duratex with 120 grit so it was smooth.
Duratex
Restore
Restore is not as textured. When you use a semi smooth roller it comes out to the texture of duratex with a foam roller. What I like though is it covers the seams( I still have one in my top but its covered with my wife's doilies) about the same as duratex with 6 mm roller. Restore paint is very thick.
Overall I prefer the restore look better. I f you like the really pebbled look then restore is not for you. I like that restore is half the price and locally available. You may want to try it out.
kevings, Mfusick, Archaea and 10 others like this.
chalugadp is offline
post #2 of 188 Old 07-28-2014, 05:21 PM
dtsdig's Avatar
Quoted: 895 Post(s)
Liked: 1002
Pretty cool! I wonder what some of the other colors would turn out like.
Next spring I'm planning on building five speakers for an outdoor theater and have been wondering how I was going to finish them without buying duratex. Thanks!
dtsdig is online now
post #3 of 188 Old 07-28-2014, 06:26 PM
kevings's Avatar
Quoted: 298 Post(s)
Liked: 462
kevings is offline
post #4 of 188 Old 07-28-2014, 07:04 PM
d_c
d_c's Avatar
Quoted: 884 Post(s)
Liked: 1010
Good thinking man!
d_c is online now
post #5 of 188 Old 07-28-2014, 07:15 PM - Thread Starter
chalugadp's Avatar
Liked: 1529
Originally Posted by kevings View Post
Nice post Donny! I'm gonna have to pick up a gallon of this sooner or later and give it a try.
With your prep skills it will be perfect.
Lots of colors
http://www.rustoleum.com/en/product-...ete-restore-4x
post #6 of 188 Old 07-28-2014, 07:34 PM
basshead81's Avatar
Quoted: 231 Post(s)
Liked: 6384
In your thread that was locked I posted pics of my friends DIY downfiring MC's.They were finished with white deck restore....looks pretty good.
basshead81 is offline
post #7 of 188 Old 07-28-2014, 07:41 PM - Thread Starter
chalugadp's Avatar
Liked: 1529
I just didn't find duratex was good value for the price. Now shipping to me was 85$ total so more then most. Even with foam roller its a bit more rough then I want and it didn't cover up seams that great. My prep skills for painting are not great. I have little patience , especially when my sub's are all covered with stuff on top.
After I get all my speakers done I might go back and use a color other then black with restore for my subs. Will see.
post #8 of 188 Old 07-28-2014, 07:45 PM
gpmbc's Avatar
Quoted: 336 Post(s)
Liked: 206
Is it easy to apply?
gpmbc is online now
post #9 of 188 Old 07-28-2014, 07:50 PM - Thread Starter
chalugadp's Avatar
Liked: 1529
Yup, no different then duratex except you don't want to use a foam roller with it. No harder then putting on regular paint.
I would say if duratex is really successful for someone then stick to it. If you only somewhat liked it then maybe try this stuff.
post #10 of 188 Old 07-28-2014, 07:52 PM
gpmbc's Avatar
Quoted: 336 Post(s)
Liked: 206
Thx, I will try some on the boxes that I'm building now.
gpmbc is online now
post #11 of 188 Old 07-28-2014, 08:02 PM
Face2's Avatar
Quoted: 341 Post(s)
Liked: 205
Unlike Duratex, I wouldn't recommend applying this indoors.
Face2 is online now
post #12 of 188 Old 07-28-2014, 08:22 PM - Thread Starter
chalugadp's Avatar
Liked: 1529
Yes it does stink more then duratex.
post #13 of 188 Old 07-28-2014, 09:18 PM
Boxozaxu's Avatar
Quoted: 459 Post(s)
Liked: 312
I used this on my deck last year. Same thing as the restore product but smooth texture. The deck still looks great but I can still smell it. Especially on warm days.
Boxozaxu is offline
post #14 of 188 Old 07-28-2014, 09:35 PM - Thread Starter
chalugadp's Avatar
Liked: 1529
I'll see in a couple days if I can smell it.
post #15 of 188 Old 07-28-2014, 09:47 PM
A9X-308's Avatar
Quoted: 1506 Post(s)
Liked: 1139
I was going to curse another bleeping product we can't get down here after I checked Rustoleum's site. Then I found there is a distributor for Duratex down here now.
A9X-308 is offline
post #16 of 188 Old 07-29-2014, 02:31 AM
SpinMonster's Avatar
Quoted: 259 Post(s)
Liked: 111
Duratex can have a very smooth texture. Besides the foam roller, it can be sprayed. I understand you're happy with your choice but I am posting this so others searching for duratex feedback don't look at your posted pics of the duratex and think the result always looks like that.
SpinMonster is offline
post #17 of 188 Old 07-29-2014, 02:34 AM - Thread Starter
chalugadp's Avatar
Liked: 1529
That looks awesome. If its a smooth finish then why not use regular paint ?
post #18 of 188 Old 07-29-2014, 03:14 AM
kevings's Avatar
Quoted: 298 Post(s)
Liked: 462
kevings is offline
post #19 of 188 Old 07-29-2014, 04:52 AM
lemonslush's Avatar
Quoted: 827 Post(s)
Liked: 413
I used this stuff. It was over $50 for the gallon at walmart and has a very strong smell.
lemonslush is offline
post #20 of 188 Old 07-29-2014, 08:31 AM
Bassment's Avatar
Quoted: 945 Post(s)
Liked: 378
nice find, that stuff looks great and a great price. Does anyone else have any really cheap options for a 100% smooth texture, flat black paint?
I paid 35.00 for a quart of the black paint I used on my stands -.- lol
Bassment is offline
post #21 of 188 Old 07-29-2014, 08:58 AM - Thread Starter
chalugadp's Avatar
Liked: 1529
I just did the smell test and its fine. Can only smell it with nose directly on surface. Its been less then 24 hours.
post #22 of 188 Old 07-29-2014, 09:43 AM
Boxozaxu's Avatar
Quoted: 459 Post(s)
Liked: 312
That's awesome.
If smell did turn out to be a problem you could always hit it with some spray on satin poly. Might even be a good idea to do that regardless.
This was a great idea chalugadp!
Boxozaxu is offline
post #23 of 188 Old 07-29-2014, 09:48 AM
ADAIR's Avatar
Quoted: 17 Post(s)
Spin monster,
Is there a thread for that sub?
Gorgeous work !
I found the build thread here:
http://www.aespeakers.com/phpbb2/viewtopic.php?t=701
ADAIR is offline
post #24 of 188 Old 07-29-2014, 10:16 AM - Thread Starter
chalugadp's Avatar
Liked: 1529
That's awesome.
I now have 90% left of my restore and don't need the rest. If anyone lives near me ( Vancouver area) and wants it they can have it for a two litre of Coke.
post #25 of 188 Old 07-29-2014, 11:32 AM
Quoted: 259 Post(s)
Liked: 111
Duratex is used because it super durable. Its like arguing to use paint over powder coating when powder coating is 9 times as think, flexes for items so it can be used on springs and sway bars, and can be used the moment it comes out of the oven.
I can't comment on what you used because I haven't and I don't like making generalizations about things I don't have first hand experience with.
Duratex is water based and has no nasty smell. It cleans up with water and you can hammer on it once its done unlike anything else because it is way thicker than paint but has properties of a polymer. Its way thicker than paint and hides seams far superior to the results you got in the pictures you posted. Here is the side with all the seams on my last project and you can't see anything except a perfect finish. The second picture shows its uniform finish. I chose a texture on that finish and I get many compliments on it.
post #26 of 188 Old 07-29-2014, 12:03 PM - Thread Starter
chalugadp's Avatar
Liked: 1529
Both are very similar thickness. Another option for those who don't want pebbles so thick. Most here don't spray duratex I think. I was lazy in my prep work but duratex didn't cover seams. Didn't work for eljaycanuck either.
post #27 of 188 Old 07-29-2014, 12:14 PM
kevings's Avatar
Quoted: 298 Post(s)
Liked: 462
kevings is offline
post #28 of 188 Old 07-29-2014, 12:47 PM
eljaycanuck's Avatar
Quoted: 1342 Post(s)
Liked: 1956
Duratex ... [is] way thicker than paint and hides seams far superior to the results you got in the pictures you posted.
... I was lazy in my prep work but duratex didn't cover seams. Didn't work for eljaycanuck either.
That's correct. I did one coat of primer + two coats of DuraTex over all surfaces, and a third coat of DuraTex over the tops and fronts, and seams are still visible.
eljaycanuck is offline
post #29 of 188 Old 07-29-2014, 01:06 PM - Thread Starter
chalugadp's Avatar
Liked: 1529
If it were visible surfaces for my sub's I would have done more prep work. All my speakers will have veneer.
post #30 of 188 Old 07-29-2014, 01:57 PM
PM-Performance's Avatar
Quoted: 247 Post(s)
Liked: 142
I'm surprised on the no smell. I read a ton of reviews f this stuff smelling pretty bad even outdoors when used for decks. I was looking at its stuff heavily to do on my deck, but horrible reviews for it. Never thought about using for a box though. Great on thinking outside the box on this one.
Klipsch RF-82|RC-62|RS-52|RB-51, 2 Ultimax 18's in Marty Cabs Powered by Inuke 6000DSP|
Denon AVR-X4000|Oppo BDP-103|Epson 5020UB with Elite SableFrame 110"|
4 Aura Bass Shakers powered by Dayton PSA-250|4 Seatcraft 5131 seats
PM-Performance is offline
