First DIY subwoofer?!?! - AVS Forum | Home Theater Discussions And Reviews
 1Likes
  • 1 Post By LTD02
post #1 of 9 Old 07-30-2014, 04:23 PM - Thread Starter
Choppsho's Avatar
Quoted: 18 Post(s)
I found this half built gem on craigslist and after reading through other diy dayton audio reference 15 hf sealed builds I am a little lost with its performance. I believe it may be underpowered. The enclosure measures 29 inches high, 21.5 inches wide and 13.5 inches deep (which I believe gives it nearly ideal volume). It is built and braced very well. It is also stuffed with some polyfil and there seems to also be small square fiberglass insulation pieces glued to the walls. The amp powering it is an older dayton audio 240 watt into 4 ohm ( I believe an spa240 ) I am trying to attach these photos but avs on my iPad seems really buggy. It was pretty much given to me with the wildly low o.b.o. I gave. Any input is a help. I am coming from a klipsch rw12d...I figured this would be an improvement but as of right now it's hard to tell. If the output could be improved with a larger amp and better placement I plane on duplicating this build to run duals.
Choppsho is offline
post #2 of 9 Old 07-30-2014, 04:24 PM - Thread Starter
Choppsho's Avatar
Quoted: 18 Post(s)
Another photo
Choppsho is offline
post #3 of 9 Old 07-30-2014, 04:26 PM - Thread Starter
Choppsho's Avatar
Quoted: 18 Post(s)
And another
Choppsho is offline
post #4 of 9 Old 07-30-2014, 04:27 PM - Thread Starter
Choppsho's Avatar
Quoted: 18 Post(s)
Sorry for some reason I can only upload one at a time...last one
Choppsho is offline
post #5 of 9 Old 07-30-2014, 04:28 PM
BassThatHz's Avatar
Quoted: 2391 Post(s)
Liked: 2168
Looks good to me, 240 watt is probably a bit on the low side though.
BassThatHz is offline
post #6 of 9 Old 07-30-2014, 04:28 PM - Thread Starter
Choppsho's Avatar
Quoted: 18 Post(s)
And this
Choppsho is offline
post #7 of 9 Old 07-30-2014, 04:42 PM
kevings's Avatar
Quoted: 299 Post(s)
Liked: 466
kevings is offline
post #8 of 9 Old 07-30-2014, 04:45 PM - Thread Starter
Choppsho's Avatar
Quoted: 18 Post(s)
The seller was asking 200 or best offer...and after a week he took my offer which was significantly lower...I wanted to do my own build or buy a pre fab box and driver from parts express but this was way cheaper
Choppsho is offline
post #9 of 9 Old 08-06-2014, 09:51 PM
LTD02's Avatar
Quoted: 2553 Post(s)
Liked: 2888
9 cubic feet tuned to around 17hz vs. sealed both with 250 watts. I'm not really sure what I would 'advise' here, but the larger ported enclosure will provide quite a bit more bass. most plate amps have built in eq and high pass filters though, so that could be changing the response and may be the reason the original builder wasn't happy. I wouldn't send a ton of power to the -hf models, but in largish cabs, they don't really need it anyways.
Choppsho likes this.
Listen. It's All Good.
LTD02 is online now
