External Crossover - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 07-30-2014, 05:27 PM - Thread Starter
horfcha's Avatar
Quoted: 17 Post(s)
External Crossover
So I've ordered the 1099s but this musing isn't really specific to any one speaker model. I've been gearing up for the build process and I realized that it might be more fun to showcase the crossover by building it outside of the speaker cabinet. Maybe I'm just nerdy, but I like the look of the electronic components and think that there a pleasing amount of functional artistry going on in some of the layouts I've seen. Has anyone attempted to incorporate their crossover as a visual component to their cabinet?
I was imagining a nicely finished box with a plexi face for viewing. One could even get really fancy and tap into the standby power to run a small LED for internal backlighting or paint the components in some sort of art deco color scheme.
Here is the breakdown as I see it--mostly aesthetic, as I didn't find a lot of literature suggesting a tangible sonic difference.
Pros:
  • could look nice
  • easier to replace and/or modify
  • less vibration / heat
Cons:
  • extra work to make it look nice
  • larger due to external location
  • longer + more visible wires
horfcha is offline
post #2 of 6 Old 07-30-2014, 05:37 PM
A9X-308's Avatar
Quoted: 1280 Post(s)
Liked: 951
Pros:
  • could look nice
Cons:
There won't be any sonic difference from just moving it outside the enclosure unless it was perhaps metres away. The idea doesn't appeal to me, bit if you like it, have at it.
A9X-308 is offline
post #3 of 6 Old 07-30-2014, 06:12 PM
chalugadp's Avatar
Quoted: 1670 Post(s)
Liked: 1505
Definitely a little
Go for it.
chalugadp is offline
post #4 of 6 Old 07-31-2014, 08:01 PM
BassThatHz's Avatar
Quoted: 2031 Post(s)
Liked: 1546
I am doing external crossovers for my LCR, I was gonna do surrounds too but decided against the idea.
The only reason I'm doing it is to be able to go full active if I want.
Here is the back of my center channel.
BassThatHz is offline
post #5 of 6 Old 07-31-2014, 08:47 PM
Face2's Avatar
Quoted: 334 Post(s)
Liked: 201
Why didn't you use Speakon connectors?
Face2 is offline
post #6 of 6 Old 07-31-2014, 09:17 PM
beefbuzz's Avatar
Liked: 8
Pros:
  • could look nice
Cons:
Visible crossovers were pretty standard fare for car audio separates back in the day. Some used plexi or wire mesh for the cover. You can still find examples by searching 'passive crossovers' on ebay. I still have an old set somewhere. Oh and I very much like the idea!
beefbuzz is offline
