Chalugadp 1099 Curved CC Build - Page 4 - AVS Forum | Home Theater Discussions And Reviews
 58Likes
post #91 of 231 Old 08-12-2014, 03:59 PM - Thread Starter
chalugadp's Avatar
Quoted: 1672 Post(s)
Liked: 1505
My minion has a port. Just borrowed it. Not needing my minions right now as I'm enjoying Joe's jtrs.
chalugadp is offline
post #92 of 231 Old 08-12-2014, 04:07 PM
tuxedocivic's Avatar
Quoted: 1910 Post(s)
Liked: 1730
Oh right. Forgot about that.
tuxedocivic is offline
post #93 of 231 Old 08-12-2014, 04:53 PM
Erich H's Avatar
Quoted: 1406 Post(s)
Liked: 1774
Minion and Fusion-8 ports are actually different from the 1099. They do not fit the same holes.
_______________________
The SEOS Waveguide Project
Erich H is offline
post #94 of 231 Old 08-12-2014, 05:44 PM
Fatshaft's Avatar
Quoted: 590 Post(s)
Liked: 904
Erich, When I got my 1099's I had a missing port (which you sent to me) and temporarily used one from my Fusion 8 kit and they are identical to me.
My Build Thread
Equipment Speakers:
3x 1099's for LCR duty
4x Fusion 8's for surround duty
8x subs: 4x FTW21's and 4x SI18's
Fatshaft is offline
post #95 of 231 Old 08-12-2014, 05:53 PM
Erich H's Avatar
Liked: 1774
I know, I just wanted to make Mr. Chalugadp nervous for a minute or two being that he already cut the port holes in his speaker.
You ruined the fun!
Boxozaxu likes this.
Erich H is offline
post #96 of 231 Old 08-12-2014, 06:01 PM
Fatshaft's Avatar
Quoted: 590 Post(s)
Liked: 904
You ruined the fun!
Name:	sad homer8.jpg
My Build Thread
Equipment Speakers:
Fatshaft is offline
post #97 of 231 Old 08-12-2014, 06:19 PM
Liked: 1730
Had me going to a minute. I was like, uh oh, that'll be a challenge to fix!!
post #98 of 231 Old 08-12-2014, 07:07 PM - Thread Starter
chalugadp's Avatar
Liked: 1505
You ruined the fun!
Your a cruel man
post #99 of 231 Old 08-12-2014, 07:08 PM - Thread Starter
chalugadp's Avatar
Liked: 1505
Finally home
Everything seems just right. After supper will do a little work on it.
post #100 of 231 Old 08-12-2014, 07:25 PM
Fatshaft's Avatar
Quoted: 590 Post(s)
Liked: 904
ambesolman likes this.
My Build Thread
Equipment Speakers:
Fatshaft is offline
post #101 of 231 Old 08-12-2014, 07:36 PM
atabea's Avatar
Quoted: 558 Post(s)
Liked: 360
Finally home
Who has time for supper when there's a speaker to build?
Congrats on your new acquisition--it's gonna be awesome.
chalugadp likes this.
atabea is offline
post #102 of 231 Old 08-12-2014, 08:35 PM - Thread Starter
chalugadp's Avatar
Liked: 1505
Put in the foam
I like this spray adhesive
Cheaper then 3m and the nozzle is better.
Then cut the block for the front port
Not a perfect fit but will be good after a little fill.
Tomorrow should get all ports filled, and get baffle on with blocks on the back . That leaves me time to mail the xo to tux.
post #103 of 231 Old 08-13-2014, 12:28 AM
sslv2pwned's Avatar
Quoted: 127 Post(s)
Liked: 33
Where did you get the foam?
Also, I'm thinking about using an oil based satin black paint on my baffle and then using veneer for the sides. I like cherry wood. What is the cheapest veneer you would use for a cherry stain?
I have been so busy that I haven't had a chance to open my 1099's yet. I'm hoping I can get started on the crossovers overs tomorrow though.
Sent from my Nexus 7 using Tapatalk
sslv2pwned is offline
post #104 of 231 Old 08-13-2014, 12:55 AM - Thread Starter
chalugadp's Avatar
Liked: 1505
Foam from ebay. 35$ for 4' by 8'.
Cherry veneer is cheap and nice. Maple as well.
post #105 of 231 Old 08-13-2014, 12:59 AM
sslv2pwned's Avatar
Quoted: 127 Post(s)
Liked: 33
So dumb question... If I bought cherry veneer, would I still need to stain it?
post #106 of 231 Old 08-13-2014, 01:12 AM - Thread Starter
chalugadp's Avatar
Liked: 1505
I think cherry veneer looks great with natural watco oil. There is cherry watco oil for a darker look. Thats what I am going to use for mine . Then put poly it lacquer on top bandit looks great. I don't want super gloss for mine. Just a nice low sheen.
Number 1,2,3,4,9(phone pad)
All work great.
post #107 of 231 Old 08-13-2014, 07:25 AM
dtsdig's Avatar
Quoted: 829 Post(s)
Liked: 921
Put in the foam
Chalugadp, the center compartment for the mids and CD should be filled with polyfil from what Tux has said. You may want to check with him about just using foam in there. Looking good!
dtsdig is offline
post #108 of 231 Old 08-13-2014, 07:47 AM
Liked: 1730
^ that's fine. The only thing I was worried about looking at it, is if there's enough room for the mids right near the front. Donny might just have to cut a bit away.
That is open cell foam right? It needs to be the stuff that you can easily squish and breath through.
dtsdig likes this.
post #109 of 231 Old 08-13-2014, 09:15 AM
t3steve's Avatar
I don't mean to derail this great build but I have a quick question. Why is foam used instead of Owens Corning 703 or Roxul Rockboard 60?
t3steve is offline
post #110 of 231 Old 08-13-2014, 09:34 AM
Liked: 1730
Either is fine. Only think I'd be worried about with a hard insulation is reflections off the surface of the insulation because the frequencies are high. The foam Donny is using has a nice irregular surface to it.
post #111 of 231 Old 08-13-2014, 09:39 AM
Liked: 1730
I agree with Donny, no need to stain Cherry unless you want a certain colour. Actually, no need to stain any type of wood unless you want a certain color. But certainly cherry is already nice. Oil like boiled linseed oil followed by lacquer, or like Donny suggested = great look results. Heck, even just several coats of tung oil look good on cherry. Talk about easy.
Cherry will slightly darken with UV exposure and time, so beware of that.
I think people confuse stain with finish. Stain isn't a finish. Every wood needs a finish. Stain is something used to achieve a desired look of the finish. Quite different.
post #112 of 231 Old 08-13-2014, 11:15 AM
Fatshaft's Avatar
Quoted: 590 Post(s)
Liked: 904
Donny,
You building your cabs from the roof?
That looks crazy!
My Build Thread
Equipment Speakers:
Fatshaft is offline
post #113 of 231 Old 08-13-2014, 11:18 AM
jbrown15's Avatar
Quoted: 2523 Post(s)
Liked: 1993
Originally Posted by Fatshaft View Post
Donny,
That looks crazy!
I've been to his place, its a good 10ft drop!....lol
Easily two broken legs if you fall off the deck!....lol
jbrown15 is offline
post #114 of 231 Old 08-13-2014, 11:30 AM - Thread Starter
chalugadp's Avatar
Liked: 1505
Yes open cell.
post #115 of 231 Old 08-13-2014, 11:35 AM - Thread Starter
chalugadp's Avatar
Liked: 1505
Donny,
That looks crazy!
Been building on my deck for last 6 weeks. Probably cut a dozen subs there. Gets hot in the middle of the day. Only a 9' drop
Looks like I might be selling this place and moving closer to Joe . The house 10 minutes away from me is 90,000 less for comparable place. If I do then I have to put up a railing.
post #116 of 231 Old 08-13-2014, 11:42 AM
dtsdig's Avatar
Quoted: 829 Post(s)
Liked: 921
You should install a MARTY RAIL!!!!! LOLOL
Fatshaft, Bassment and Boxozaxu like this.
dtsdig is offline
post #117 of 231 Old 08-13-2014, 02:20 PM - Thread Starter
chalugadp's Avatar
Liked: 1505
Plugs glueing
Once you have first one to fit then flush trim the rest off of that template .
Once glue dries I will attach the baffle. Then fill and sand smooth. Tomorrow I go to pj white to get veneer. I was going to order online but I have had good success with pj veneer. It has a thicker amount of wood then most. Will choose a light color veneer.
post #118 of 231 Old 08-13-2014, 03:16 PM
Liked: 1730
Does PJ white sell paper back veneer ? We don't have them on the island. If they do I'll have to remember to pick some up when I'm over there next time.
post #119 of 231 Old 08-13-2014, 03:34 PM - Thread Starter
chalugadp's Avatar
Liked: 1505
Yes they have about 20-25 choices. Really nice quality. They don't carry really exotic stuff. My xo is xpost on its way to you.
post #120 of 231 Old 08-13-2014, 03:37 PM - Thread Starter
chalugadp's Avatar
Liked: 1505
Did the filling in 2 minutes.
$3 a tube and super easy to put on with putty knife.
Attaching the baffle in about 30 minutes. Crappy weather today so working under overhang .
