Differences between MiniDSP / AntiMode / Bassis / SEQSS ? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 08-01-2014, 11:24 AM - Thread Starter
MemX's Avatar
Quoted: 55 Post(s)
Liked: 64
Question Differences between MiniDSP / AntiMode / Bassis / SEQSS ?
So, this is an ultra-n00b post but I'm not sure I've seen a post or thread that summarises all the differences between the various non-AVR EQ options that are available.
From what I can tell we have:
- Behringer Feedback Destroyer (BFD)
- MiniDSP
- AntiMode 8033
- old-skool bassis
- Bossobass SEQSS
Am I missing any?
Going entirely from memory of what I think I've read (so the following may well be complete rubbish)...
- The BFD seems to have its lowest EQ filter as 20Hz, but I understand it's possible to boost/cut below that through some clever manipulaton.
- The MiniDSP offers full signal manipulation via PC interface - but IIRC it rolls off / is limited to 5Hz?
- The AntiMode can only cut frequencies rather than boost them? (I'm guessing from the name... lol)
- Old-skool Bassis are hard to find and a couple of hundred £/$ on ebay, therefore I think I would rule them out.
- Bosso's SEQSS looks to have the lowest and most powerful extension (flat to 2Hz or 3Hz?) but it applies a boost across the board rather than having the manipulation abilities of the MiniDSP?
Out of all of those I'm considering the MiniDSP and Bossobass SEQSS, so if my recollections detailed above are correct, it looks like a trade off between precise signal manipulation and higher power to lower frequencies?
(Oh, and I imagine cost as well - MiniDSP = cheap, I'm not sure the SEQSS will be... lol)
I think?? lol
MemX is offline
post #2 of 6 Old 08-01-2014, 12:10 PM
mynym's Avatar
Quoted: 22 Post(s)
You may want to also include the DCX2496.
mynym is offline
post #3 of 6 Old 08-01-2014, 12:24 PM
chalugadp's Avatar
Quoted: 1672 Post(s)
Liked: 1505
Missing inuke DSP amps, and my emotiva umc200 does a great job of manual peq
chalugadp is offline
post #4 of 6 Old 08-01-2014, 12:30 PM
Mike Garrett's Avatar
Quoted: 5557 Post(s)
Liked: 3541
Also depends in which MiniDSP you are talking about. I have two 10x10HD's and they offer pretty much anything that you would want.
mjgarrett100@gmail.com
Mike Garrett is offline
post #5 of 6 Old 08-01-2014, 03:45 PM
Nate Hansen's Avatar
Quoted: 252 Post(s)
Liked: 162
You can also use a PC, which will do everything any of those boxes can do and more.
Nate Hansen is offline
post #6 of 6 Old 08-02-2014, 05:05 AM
Martycool007's Avatar
Quoted: 280 Post(s)
Liked: 176
Nate is right! Something like JRiver would offer a great deal of flexibility for EQ'ing your setup. You could use JRiver for many other things as well ranging from movie and music streaming, active crossovers, and many other possible options as well! One day I would like to use JRiver in place of my receiver and BluRay player using my PC + JRiver as my pre/pro & source all rolled into one! Although, that is a pretty costly way of doing things as you have to spend over a grand on hardware in order to ditch the AVR and BluRay player using a PC solely for the source and pre/pro!
Martycool007 is offline
