Data-Bass Info Explanation Please - AVS Forum | Home Theater Discussions And Reviews
 5Likes
post #1 of 33 Old 08-01-2014, 11:24 PM - Thread Starter
randyc1's Avatar
Quoted: 238 Post(s)
Liked: 40
I'm comparing 2 very different Subs , Sealed SI 18" , 22" cube vs a Rythmik FV15HP.
Why when comparing Measurements like first one: (Max Burst), the Rythmik has higher SPL in lower Hz,..
Then when you look at (Basic Responce) & (Full Range Responce) graphs the SI 18" has a much higher Overall ?
Which graph demonstrates overall real world performance comparison ?
randyc1 is offline
post #2 of 33 Old 08-02-2014, 12:26 AM
BassThatHz's Avatar
Quoted: 2032 Post(s)
Liked: 1550
They are so close the difference is trivial.
The SI is probably cheaper, thus better.
BassThatHz is online now
post #3 of 33 Old 08-02-2014, 05:54 AM
eljaycanuck's Avatar
Quoted: 1227 Post(s)
Liked: 1798
OP, I had a similar question in this thread regarding the ChaseHT SS-18.1 (which I have) and the PSA XV15 (which I was contemplating buying).
The same question applies to the SS-18.1 vs. the UXL-18 in a sealed enclosure (which is my current project).
The SS-18 easily beats the other two subs in Basic Response and Full Range Response, but loses to them (but only below the ~50-60Hz mark) in Max Burst and Max Long Term Output.
If I'm never going to run my subs at reference, how were / are people able to state that the XV15 and UXL are superior to the SS-18?
I hope someone will chime in with a clear explanation.
eljaycanuck is offline
post #4 of 33 Old 08-02-2014, 06:49 AM
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2682
+1
Mfusick is offline
post #5 of 33 Old 08-02-2014, 08:00 AM - Thread Starter
randyc1's Avatar
Quoted: 238 Post(s)
Liked: 40
+1
..If close,why is there such a difference in the Basic Rresponce?
randyc1 is offline
post #6 of 33 Old 08-02-2014, 08:43 AM
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2682
The only thing that matters is SPL, extension, and distortion. If the SI 18 can play low enough and loud enough and with the limited amount of distortion you desire in a simple cubed sealed box, I don't see a lot of reason not to take that option. Your upgrade path is easy, add another. Use a nice amp with DSP or active electronics, really a nice value for the money. Assuming the money isn't a factor then I guess you can flip a coin.
Mfusick is offline
post #7 of 33 Old 08-02-2014, 08:49 AM
basshead81's Avatar
Quoted: 179 Post(s)
Liked: 5207
Um the XV15 is flatter (due to dsp)then the SS-18 in both base and full range response so I am not sure what you are seeing. Also the SS-18 was messured with the powersoft K10 amp, so you are not getting withing 6db of those data-bass numbers above 30hz with any amp chane offers nor any behringer pro amp.
Aside from that base response and full range only means so much. The room response will change that. They key is to look at output, compression, and extension. Even if a sub shows higher distortion does not mean it will sound worse then a sub with less thd but has less output. Turn the sub that has significantly more headroom down just 1db from its max output numbers and you will reduce thd 50%.
Last edited by basshead81; 08-02-2014 at 10:12 AM. Reason: changed post...did not like how it read. :)
basshead81 is offline
post #8 of 33 Old 08-02-2014, 08:58 AM - Thread Starter
randyc1's Avatar
Quoted: 238 Post(s)
Liked: 40
I have 2 Ported 3.6 cuft Dayton RSS315HO Subs . My room is big 22x23x8 and they cant keep up.
After seeing member Chalugadp going from Martycube's to 3 Micro 15"(21"cube) because they are more room freindly, got me thinking?
Would have simply puting the SI18'' in Sealed 22" cubes (similar to the Micro size) been a better option than going to Ported 15"
This is why i'm trying to understand the Graphs on Data Bass ?
randyc1 is offline
post #9 of 33 Old 08-02-2014, 10:11 AM
basshead81's Avatar
Quoted: 179 Post(s)
Liked: 5207
Likely not...Ricci tested all the DIY subs with his VERY
Expensive PowerSoft K10 amp. So more then likely you will see about 4-6db less output above 40hz with most cheaper pro amps aside from what the power ratings are.
The FV15HP would likely have similar output above 40hz and more in the 16-30hz compared to a Sealed SI18 driven by a Inuke 3000. The FV is using a true 600watt rms hypex amp and is servo driven. A Inuke 3000 will deliver about 6-700watts a channel in 2ohm for short bursts.
The FV15 probably has more output then your ported daytons due to the smallish enclosure. I would suggest adding 2 more 15's or going to ported 18's.
post #10 of 33 Old 08-02-2014, 10:38 AM
chalugadp's Avatar
Quoted: 1672 Post(s)
Liked: 1505
I watched captain America 2 last night. Volume was -10 from reference. In my 4000 cuft room the micro-cubes were awesome. The nearfield sub was rocking the couch. It felt like I had bombs going off underneath me and all around me. That's what I want. Immersive, tight, tactile bass at -10 from reference. With my SPL meter explosions that were 90-100dbs loud were visceral.
My two minimartys ( one with uxl18) never sounded nearly as good when I had the two up front. Moving the mini beside the couch wasn't an option. The minimarty only felt somewhat tactile when SPL was over 113dbs.
The micro-cubes can play clean up to reference. After that its pushing it in my large room. Because I'm not looking for 120 dB's its perfect for me.
chalugadp is offline
post #11 of 33 Old 08-02-2014, 11:29 AM
LTD02's Avatar
Quoted: 2340 Post(s)
Liked: 2576
also remember that for the diy systems josh is testing the systems with an extremely powerful amplifier.
Mfusick likes this.
Listen. It's All Good.
LTD02 is offline
post #12 of 33 Old 08-02-2014, 12:48 PM
Fatshaft's Avatar
Quoted: 590 Post(s)
Liked: 904
Randy,
If you'd like you can borrow 2 of my SI'18's for a week or 2 and have some fun with them.
Let me know and I'd be more than happy to do so!
Kind regards,
My Build Thread
Equipment Speakers:
3x 1099's for LCR duty
4x Fusion 8's for surround duty
8x subs: 4x FTW21's and 4x SI18's
Fatshaft is online now
post #13 of 33 Old 08-02-2014, 02:02 PM - Thread Starter
randyc1's Avatar
Quoted: 238 Post(s)
Liked: 40
...Ok but how is the "Basic Reponce" graph on Data Bass Explained when comparing (SI 18" Sealed & the FV15HP) , why does the SI have so much more Output ?
I thought the Inuke3000 was tested to be 1100w@2ohm ?
randyc1 is offline
post #14 of 33 Old 08-02-2014, 02:10 PM - Thread Starter
randyc1's Avatar
Quoted: 238 Post(s)
Liked: 40
Originally Posted by Fatshaft View Post
Randy,
Kind regards,
Thanks FS ! , I will certainly consider it !! : )
randyc1 is offline
post #15 of 33 Old 08-02-2014, 02:27 PM
basshead81's Avatar
Quoted: 179 Post(s)
Liked: 5207
the response shape is untouched with the diy subs vs commercial. The FV15HP, XV15, VTF-15 etc... All have custom calibrated amps to shape the signal. That is why Inuke dsp amps are popular because it makes it fairly easy for the diy'er to shape the base response. This is part of the extra cost you pay buying Id being the subs are custom tuned to extract the most clean output. They do not just slap a amp and driver in the box and ship it off to the customer. There is a lot involved into shaping the signal(response) to get the most performance out of the subs without sacraficing sound quality.
Again the SI and any DIY sub shows a lot of output above 40hz because of Ricci 10kw power soft amp that runs in 6-8000.00 dollar range. Again you need to subtract about 4-5db off the top(50-125hz) on most of those subs for real world numbers that you would see with a budget amp such as the Inuke. Make sense?
That is the only issue I see with data-bass is the fact that the little things are not boldly stated and can be confusing.
post #16 of 33 Old 08-02-2014, 02:28 PM
basshead81's Avatar
Quoted: 179 Post(s)
Liked: 5207
X2. I believe I mentioned this but possibly you broke it down so it was easier to understand.
post #17 of 33 Old 08-02-2014, 02:31 PM
chalugadp's Avatar
Liked: 1505
I have found ltd02 graphs very accurate for real world performance. Tried over 5 setups ( different subs with each) with graphs he has provided and bang on each time. You would want 5dbs of headroom from his graph.
I know he's just using winisd, nothing magical but its nice to know its spot on.
post #18 of 33 Old 08-02-2014, 02:37 PM - Thread Starter
randyc1's Avatar
Quoted: 238 Post(s)
Liked: 40
...Ok Ok got it ,thanks ,.. so basically a Ported 15" will have more output than a sealed SI18"
With that in mind I will probably build a few Rythmik clones , with either the RSS 390HO or the SI15"
randyc1 is offline
post #19 of 33 Old 08-02-2014, 02:44 PM
basshead81's Avatar
Quoted: 179 Post(s)
Liked: 5207
If you took a SI 15 in a maximum efficiency ported enclosure and put it up against a sealed SI 18 both using the same amp andpower, the 15 would have more output around the tune, the 18 would have more output above and below the 15's port tune.
post #20 of 33 Old 08-02-2014, 03:05 PM
chalugadp's Avatar
Liked: 1505
That's not what this says.
Ignore blue line. The rest are 15" in ported design.
Here is 18" in sealed design(blue line). All with 1100 watts
From 18-40hz ported better. Now I have never had sealed in my room. But I have sent micro-cubes to people with sealed 18" and they found signficant improvement.
post #21 of 33 Old 08-02-2014, 04:18 PM
Ricci's Avatar
Quoted: 184 Post(s)
Liked: 472
Basic response and full range response are just that. These have nothing to do with how powerful a system is or how low it can effectively extend.
To see how capable a particular system is from a dynamic and sustained output perspective you would look at CEA-2010 burst data and long term output compression tests. For passive systems you would need to subtract a good 4-10dB from the CEA-2010 data at 40Hz and above to be representative of what a typical amp that would be "Safe" to use with these would be. Think of the CEA-2010 data for passive systems as maximum burst output before driver failure without a power limit. The amount of power varies with frequency and is greatly reduced at the lower frequencies. To see a better representation of what the passive system would do full bandwidth with a typical or appropriate amount of power look at the loudest long term output compression sweep. This represents an amount of constant voltage input and output from the passive system that it will survive over atleast a brief time from 2-125Hz.
A lot of this is covered in the "Know How" section at DB.
Mfusick, Archaea and randyc1 like this.
Ricci is offline
post #22 of 33 Old 08-02-2014, 04:26 PM
Liked: 1798
I'm still not understanding.
The DIY UXL and the SS-18 were both tested with Ricci's powerful amp, yes? So what does it mean, in real-world terms, that the SS-18 easily bests the UXL - in terms of output - in both Basic Response and Full Range Response?
If there's no value to those measurements, why are they even there?
And if I never play my system at reference volume, will I actually notice the advantage that the UXL has in Max Burst and Max Long Term Output?
IOW, what actual improvement should I notice going from dual SS-18s to dual UXLs?
(The whole reason I'm making the $2,500 move to UXLs is to realize an improvement over the SS-18s.)
-- Edit --
Just saw Ricci's post. I'll go take a look at the "Know How" section.
post #23 of 33 Old 08-02-2014, 04:43 PM
chalugadp's Avatar
Liked: 1505
At modest levels the uxl18 won't give you any advantage. If you don't listen louder the -10 dbs for movies its doubtful any better bass. The uxl18 only show there advantage over si and Dayton when pushed near its top. That's where you see the 4 db advantage. At reference the si and Dayton in a system might be near clean output maximum. In same scenario the uxl18 will have greater headroom and play clean louder. At -10 all the drivers have lots of headroom.
post #24 of 33 Old 08-02-2014, 04:46 PM
Liked: 1798
post #25 of 33 Old 08-02-2014, 05:02 PM
chalugadp's Avatar
Liked: 1505
Thanks for the explanation, chaluga.
I'm not slamming uxl18 at all. Its capable of extreme SPL ,clean and tight. Just if you drive a Ferrari at just over the speed limit its a lot closer to a Lexus.
post #26 of 33 Old 08-02-2014, 05:29 PM
Liked: 1798
I didn't think you were slamming the UXL. It's just that I was under the impression* that a pair of sealed UXL subs would provide a noticeable improvement in sub-20Hz performance - down to as low as ~10Hz - in my room at my listening levels vs. my current SS-18s.
(*From comments made in this thread. A couple of examples:
- post #234 - " ... I think Eljay would see an enormous upgrade down low by replacing those SS-18.1s with UXL-18s to get 100-105dB @ 10Hz ... "
- post #255 - "Great choice. Nothing like changing subs that take up the same space and get low end gains equivalent to adding another quad pack of your current subs. ... ")
If they'll do that, I'm happy. If they won't do that, I'll have essentially wasted $2,500.
But I won't worry about the latter outcome just yet...
post #27 of 33 Old 08-02-2014, 05:30 PM
Archaea's Avatar
Quoted: 2842 Post(s)
Liked: 2422
21 posts to get to the answer --- from the man himself!
Basic response and full range response don't have anything to do with maximum output - they are just frequency response plots for the system's native unstressed frequency response. As long as those plots are taken above the noise floor and below threshold of compression they are accurate - regardless of SPL. You can't compare basic response to maximum long term output or burst. Basic response on something like the Rythmik (or any ID sub with built in EQ through DSP) goes out the window when you take a driver to the limit and you'll begin to see what the driver does at full bore. So a nice behaved flat line to 20hz on a ported sub, doesn't stay flat as you hit full tilt (well unless you are amp limited).
Something that will help you understand is to look at some compression sweeps. Basically a compression sweep is when you keep increasing the volume until the sub is tapped out. You'll notice the frequency plots change as the SPL levels increase on the same system.
Look at the long term output compression on the Rythmik FV-15HP
http://www.data-bass.com/data?page=system&id=51&mset=49
Under Extended Charts.
Then compare that to the SI 18" long term compression output which doesn't typcially change much on a sealed sub's native frequency response.
http://www.data-bass.com/data?page=system&id=90&mset=97
If you add EQ to the sealed sub and repeat the compression tests the same thing would apply. The boost you apply in the lower frequencies would disappear as you max out the SPL.
Archaea is online now
post #28 of 33 Old 08-02-2014, 07:14 PM
basshead81's Avatar
Quoted: 179 Post(s)
Liked: 5207
yea but those charts are not the end all be all for determining sub performance either.
post #29 of 33 Old 08-02-2014, 07:22 PM
basshead81's Avatar
Quoted: 179 Post(s)
Liked: 5207
Here is the long term output of between the SI18 and FV15.
and SI18 vs SS-18
ID:	193937   Click image for larger version
post #30 of 33 Old 08-02-2014, 07:26 PM
chalugadp's Avatar
Liked: 1505
My real world experience along with bassthathz measurements with his pricey scope had the graphs I posted accurate. More then that I have 3 users who much prefer the ported 15 over the sealed 18". I'm not going to argue with you much bass since its your expert opinion that pushed me over the edge to go with the micro-cube. Here's a couple virtual beers
