Stereo Integity HT18 *6 Infinite Baffle - AVS Forum | Home Theater Discussions And Reviews
post #1 of 35 Old 08-03-2014, 10:07 AM - Thread Starter
evoryder's Avatar
Quoted: 78 Post(s)
Liked: 93
Hello everyone,
I don't post on here very often, I'm more of a reader, my name is George. I ordered 4 SI HT 18s out of the first batch last year and I just recently ordered 2 more to be delivered on Tuesday. I'm going to be using them in an infinite baffle with a manifold hidden in the walk-in closet that opens up to the master suite area about 40*18 total ft^2. The other side is a typical Florida open floor plan with living room, family room, kitchen and dining area, probrably about 40*40 with vaulted Ceilings. I'm going to attempt to add pictures of my progress so far.
evoryder is offline
post #2 of 35 Old 08-03-2014, 10:07 AM - Thread Starter
evoryder's Avatar
Quoted: 78 Post(s)
Liked: 93
This is the start of the opening, it will have to be made taller of course but I wanted to know the spacing of the studs and build a stable platform.
evoryder is offline
post #3 of 35 Old 08-03-2014, 10:08 AM - Thread Starter
evoryder's Avatar
Quoted: 78 Post(s)
Liked: 93
This is the opening in relation to the television. I hope it doesn't shake off the wall.
evoryder is offline
post #4 of 35 Old 08-03-2014, 10:09 AM - Thread Starter
evoryder's Avatar
Quoted: 78 Post(s)
Liked: 93
Bolting to the concrete.
evoryder is offline
post #5 of 35 Old 08-03-2014, 10:10 AM - Thread Starter
evoryder's Avatar
Quoted: 78 Post(s)
Liked: 93
Level platform tied to slab.
evoryder is offline
post #6 of 35 Old 08-03-2014, 10:10 AM - Thread Starter
evoryder's Avatar
Quoted: 78 Post(s)
Liked: 93
evoryder is offline
post #7 of 35 Old 08-03-2014, 10:11 AM - Thread Starter
evoryder's Avatar
Quoted: 78 Post(s)
Liked: 93
evoryder is offline
post #8 of 35 Old 08-03-2014, 10:11 AM - Thread Starter
evoryder's Avatar
Quoted: 78 Post(s)
Liked: 93
Almost Done
evoryder is offline
post #9 of 35 Old 08-03-2014, 10:12 AM - Thread Starter
evoryder's Avatar
Quoted: 78 Post(s)
Liked: 93
evoryder is offline
post #10 of 35 Old 08-03-2014, 10:21 AM - Thread Starter
evoryder's Avatar
Quoted: 78 Post(s)
Liked: 93
So there you have it, there will be 2 18s per side of the manifold for a total of 6. How much more bracing do you think will be needed and any other suggetions would be great. This is my first time with a home enclosure of any sort. I built some boxes for cars years ago but I'm basically a beginner again. Thanks for looking. OH and the amp is a crown XLS 2500, I will be running it 3 ohm stereo, they are dual 2ohm subs. Each of the subs voicecoils will be wired in parallel to 1 ohm, and then 3 in series per channel.
evoryder is offline
post #11 of 35 Old 08-03-2014, 03:26 PM
action_jackson's Avatar
Quoted: 353 Post(s)
Liked: 131
Hey, looking forward to seeing how this project turns out, thanks for sharing! It has been recomended that you use 2 layers of 3/4 material, one layer of OSB or Plywood and one layer of MDF. I'm not sure about the bracing part.
I am planning to order a couple of these tomorrow for an infinite baffle. Have you already had the 4 running and decided it was not enough? How big is your room?
Epson Home Cinema 3010 Projector____Paradigm 9SE MK II Main LR
Yamaha RX-V667 AVR_______________Paradigm CC-270 V.3 Center
Emotiva UPA-5 Amplifier______________Dual Stereo Integrity 18" Infinite Baffle
Sony BDP-570 Blu Ray_______________DIY Sound Group Volt 10
action_jackson is offline
post #12 of 35 Old 08-03-2014, 03:44 PM - Thread Starter
evoryder's Avatar
Quoted: 78 Post(s)
Liked: 93
No, I havnt used any of them yet. Theyve been sitting in the box. I noticed I had the room for the additional two once I saw the studs were 24 inches apart, and I ordered two more. Its an open plan Florida room about 40*40 with vaulted ceilings. Its a lot of space to fill up.
evoryder is offline
post #13 of 35 Old 08-04-2014, 12:35 AM
Stumbo's Avatar
Quoted: 55 Post(s)
Liked: 88
What made you chose the SI vs the IB318?
Stumbo is offline
post #14 of 35 Old 08-04-2014, 06:54 AM
Mr. Electric Wiz's Avatar
Quoted: 80 Post(s)
Liked: 40
Awesome!
Can't wait to see the finished product!
Mr. Electric Wiz is offline
post #15 of 35 Old 08-04-2014, 06:56 AM - Thread Starter
evoryder's Avatar
Quoted: 78 Post(s)
Liked: 93
I wanted the option to use them in a box if I don't like the infinite baffle. This is something new to me and I'm not sure how I will like it.
evoryder is offline
post #16 of 35 Old 09-12-2014, 07:18 AM - Thread Starter
evoryder's Avatar
Quoted: 78 Post(s)
Liked: 93
I've made some more progress, almost finished
Here's my makeshift speaker cutout circle jig.
ID:	259186   Click image for larger version
evoryder is offline
post #17 of 35 Old 09-12-2014, 07:27 AM - Thread Starter
evoryder's Avatar
Quoted: 78 Post(s)
Liked: 93
Test fit
Front facing living area
Here is the back with temp wiring.
evoryder is offline
post #18 of 35 Old 09-12-2014, 07:31 AM - Thread Starter
evoryder's Avatar
Quoted: 78 Post(s)
Liked: 93
I still have to fill the gap around the outside of the enclosure, and then I can pull a response graph. The lower frequencies are much louder than the higher up right now. It is fairly loud, the part I like most so far is that the sound is much cleaner than a box. It doesn't have that compressed sound you get with a box.
evoryder is offline
post #19 of 35 Old 09-12-2014, 09:00 AM
filtor1's Avatar
Quoted: 213 Post(s)
Liked: 167
Nice job! Where in FL are you?
filtor1 is offline
post #20 of 35 Old 09-12-2014, 10:07 AM - Thread Starter
evoryder's Avatar
Quoted: 78 Post(s)
Liked: 93
Thanks, I'm in Deltona
evoryder is offline
post #21 of 35 Old 09-12-2014, 10:12 AM
filtor1's Avatar
Quoted: 213 Post(s)
Liked: 167
About 2.5hours from me. Maybe when I get my build finished we can exchange demos.
filtor1 is offline
post #22 of 35 Old 09-12-2014, 11:51 AM - Thread Starter
evoryder's Avatar
Quoted: 78 Post(s)
Liked: 93
Sounds good, I don't know if my house will still be standing... it sounds like the house from that Halloween cartoon movie that gets up and walks away. There are rattles and creaks everywhere.
evoryder is offline
post #23 of 35 Old 09-12-2014, 12:53 PM
filtor1's Avatar
Quoted: 213 Post(s)
Liked: 167
Hahana, I see some drywall practice in your future...
filtor1 is offline
post #24 of 35 Old 09-12-2014, 01:24 PM
cookieattk's Avatar
Quoted: 111 Post(s)
Liked: 91
i know this defeats the point of ib but u might want to high pass @ 10hz
cookieattk is offline
post #25 of 35 Old 09-12-2014, 08:45 PM - Thread Starter
evoryder's Avatar
Quoted: 78 Post(s)
Liked: 93
I'm pretty sure the Crown amp has a built in non-defeatable high pass at 18 hz or so.
evoryder is offline
post #26 of 35 Old 09-28-2014, 08:51 AM - Thread Starter
evoryder's Avatar
Quoted: 78 Post(s)
Liked: 93
Took some measurements with UMIK1 and REW. Hopefully the Image shows correctly.
Teal = Manifold Opening
Red = No Auddyssey
Green = Audyssey with Dynamic EQ
Blue = Audyssey No Multi EQ
evoryder is offline
post #27 of 35 Old 09-28-2014, 10:53 AM
Thomas-W's Avatar
Quoted: 22 Post(s)
Pretty nasty looking 50Hz room null.
Did you test other room positions before deciding on the current location?
How are the drivers wired? A bit tricky to get equal power to all the drivers when 6 are being used.
Cult of the Infinitely Baffled (Resource for IB sub builders)
Thomas-W is offline
post #28 of 35 Old 09-29-2014, 06:41 AM - Thread Starter
evoryder's Avatar
Quoted: 78 Post(s)
Liked: 93
The voice coils are in parallel with 3 speakers in series per channel. The manifold is in the only place I could fit it, so I didn't have alot of options. I can adjust my seating position a little and/or add my other subs back in to help if needed. I'm still finishing everything up so this is just preliminary.
The other thing it could be is that the back wave at 50 hz is coming through the bedroom door and cancelling it out. I didn't have it closed at the time, so it could be acting like a really huge ported box.
evoryder is offline
post #29 of 35 Old 09-29-2014, 06:49 AM
Thomas-W's Avatar
Quoted: 22 Post(s)
It would be nice if things worked that way but unfortunately they don't.
Do you have space in the room for 'super chunk' style bass traps?
Thomas-W is offline
post #30 of 35 Old 09-29-2014, 07:30 AM - Thread Starter
evoryder's Avatar
Quoted: 78 Post(s)
Liked: 93
I do have room now that my boxed subs are no longer in use, I just havn't gotten that far yet. With my living area being so big and open I'm just not sure how to tackle that aspect yet. I plan on putting bass traps in the front corners, the back is open to the kitchen and truly the left side is open to dining and family rooms, with a false arched wall dividing the two rooms..
evoryder is offline
