HELP - Semi-DIY BIC formula vs DIY Dayton - AVS Forum
post #1 of 1 Old 08-04-2014, 05:15 PM - Thread Starter
brendanb21's Avatar
Hi Guys,
Apologies in advance if I am posting this into the wrong section.
I am hoping I could get a little advice, from down under. When it comes to speakers there is not a great deal to choose from locally. So I have decided to import from the states
I need 4 speakers to complete my 7.1 home theatre (surrounds and rears). My budget is approx USD 650/700 (not including shipping). Im narrowing my choices to the following, Note: I do not have LCR chosen yet either which I know is important, but after deciding on the below I will most probably match.
1. Bic Formula FH8-W with custom trapezoidal style enclosure. (Im not keen on mounting in wall in fear of losing sound isolation into my house).
2. Dayton Kit RS621 with slimline custom enclosure
3. Forget DIY altogether (bacause im slightly scared) and grab either Bic Formula FH-65B or Bic Venturi DV62
If it helps, I just purchased an Onkyo TX-NR616.
Thank you all.
brendanb21 is offline
User Tag List
