Cheap Crown Amp Power $99 - Page 8 - AVS Forum | Home Theater Discussions And Reviews
 79Likes
Old 08-12-2014, 05:00 PM
aaranddeeman's Avatar
Quoted: 1620 Post(s)
Liked: 561
Received mine today (x1000).
I wasn't expecting it to be that sturdy and heavy. So n o complains.
The color that you see in the pictures is ugly. Actually it is not bad at all.
And no issue with rach mount ears either as it very nicely fits between the bottom legs of my HT cabinet and the color matches with the frame.
I am pondering if I should get one more (if I can get one)
Haven't yet connected but will do soon.
I thought I could use Banana plugs to connect the speakers, but...
aaranddeeman is offline
Old 08-12-2014, 06:09 PM
cmryan821's Avatar
Quoted: 195 Post(s)
Liked: 59
No banana plugs but these do have rca inputs. So there's that.
cmryan821 is offline
Old 08-12-2014, 06:21 PM
Liked: 561
What's that logic?
Doctor Morbius's Avatar
Quoted: 124 Post(s)
Liked: 107
Of course you can use banana plugs. Get a box knife and pull out the plastic bits in the binding posts.
Mfusick and Boomassiv like this.
Doctor Morbius is offline
Old 08-12-2014, 06:28 PM
cmryan821's Avatar
Quoted: 195 Post(s)
Liked: 59
What's that logic?
Banana plugs and rca inputs are the typical connections in consumer amps, but pro amps rarely have rca inputs. So I was saying that even though you cannot use banana connectors at least you don't need rca to xlr cables/adapters.
Btw, I was mistaken. These do have banana connectors along with rca's.
Old 08-12-2014, 06:31 PM
Liked: 561
Ah. Thanks. I first thought that is how it could be but didn't want to risk damaging anything..
Thanks again..
Old 08-12-2014, 06:33 PM
Liked: 561
Oh okay. May be they have covered everything..
Liked: 561
Finally pulled trigger on one more. Hope it ships..
As there are no vents at bottom or top, I guess we can safely stack them up.
Old 08-12-2014, 06:54 PM
mynym's Avatar
Quoted: 27 Post(s)
Are the ears removable?
Had to Dremel them off my EP2500. Would be nice if they where just screwed in and detachable.
mynym is offline
Old 08-12-2014, 07:32 PM
cmryan821's Avatar
Quoted: 195 Post(s)
Liked: 59
Definitely. Pro amps are made to be stackable in racks. They just need some space behind and in front of them.
Old 08-12-2014, 07:34 PM
cmryan821's Avatar
Quoted: 195 Post(s)
Liked: 59
Nope. They're part of the faceplate.
Old 08-12-2014, 08:48 PM
Liked: 561
Also, while going through the manual, they recommend not keeping any "sensitive" equipment (like preamp) directly above or below to avoid any hum due to magnetic field.
I was planning to keep this amp just under my AV receiver (gap of roughly 2 inches). Not sure if that will pose any such issue.
How are you guys placing your equipment?
Old 08-12-2014, 09:03 PM
cookieattk's Avatar
Quoted: 111 Post(s)
Liked: 89
it shouldnt be a problem at all
cookieattk is offline
Old 08-12-2014, 09:17 PM
CinemaAndy's Avatar
Quoted: 701 Post(s)
Liked: 136
Not bad.
And the payoff is never certain: Some observers contend that a generation has already been trained to be content with the small screen.
Some servers can do non-encrypted playback to an A/V projector, but it's just a ridiculously expensive media player if you don't have a cinema projector.
CinemaAndy is offline
Old 08-12-2014, 09:31 PM
Quoted: 124 Post(s)
Liked: 107
I like the rack mounts on pro amps. It kind of gives them an anti-establishment, thumb your nose at the corporate suits look.
Old 08-12-2014, 10:02 PM
reddidit's Avatar
Liked: 0
Originally Posted by action_jackson View Post
They got 10% off the clearance price, not $99. I believe they are on sale for like $199 and $299, so an aditional 10% off of that.
This.
Seems like a crap-load of wattage for a pretty reasonable price.
reddidit is offline
Old 08-12-2014, 10:53 PM
BrutalBodyShots's Avatar
Quoted: 353 Post(s)
Liked: 85
Anyone else in NY try to order one of these? I did the other day and was called back and told it was out of stock and discontinued. I happen to be in New Hampshire for a few days and passing through MA on the way home and found a location in MA that has one in store for the same price. If it's still there I'll grab it on Friday when I pass through.
BrutalBodyShots is offline
Old 08-13-2014, 05:50 AM
lemonslush's Avatar
Quoted: 823 Post(s)
Liked: 402
Lots of people buying them, anyone actually hook it up yet?
I still have one in the box, the other aside from ground loop issues. I get a static noise when I put my ear against the speaker. My other speakers powered by the receiver don't have that.
Any ideas?
lemonslush is offline
Old 08-13-2014, 05:57 AM
Liked: 561
Why don't you order it now for store pickup at that MA store. That will be an assurance and not luck..
Old 08-13-2014, 06:16 AM
cmryan821's Avatar
Quoted: 195 Post(s)
Liked: 59
Any ideas?
I think this might help. First, set the input voltage on the amp to 1.4V, if you haven't already, then level match your speakers. If it's still present, turn down the amp gain and increase the output voltage from your avr to match speaker levels again. I think that's helped some people.
Old 08-13-2014, 06:24 AM
Sibuna's Avatar
Quoted: 374 Post(s)
Liked: 429
I ordered min on Friday of last week (western NY) they shipped out of PA someplace and should be here today
Sibuna is offline
Old 08-13-2014, 06:25 AM
lemonslush's Avatar
Quoted: 823 Post(s)
Liked: 402
I have it set to .75 currently, I will test that out when I get home. I left the AV set to -5 db and the power on the amp is almost half way so I could match my AV powered speakers. I have a ART Clean box I could hookup but was hoping I wouldn't have to use it.
Thanks for the tip.
Old 08-13-2014, 06:41 AM
NicksHitachi's Avatar
Quoted: 182 Post(s)
Liked: 189
^Set the amp to lower sensitivity that should lower the static you mention.
AFA the ground loop, the best option is get an unbalanced to balanced cable and lift the shield from the neg signal on the source(AVR) end. The balanced end should have the shield grounded to the earth ground through the amp.
Avoid the clean box at all costs. The only reason to use something like that is if the AVR wont push the amp to full power IMO.
NicksHitachi is offline
action_jackson's Avatar
Quoted: 334 Post(s)
Liked: 118
Mine said out for delivery yesterday, but then it said package was not ready at the time of the first pickup attempt. Whatever that means IDK...It is out for delivery again today, I guess the wife will be getting a surprise package hehe. They say it is easier to ask forgiveness than permission, guess this will be a test
Epson Home Cinema 3010 Projector____Paradigm 9SE MK II Main LR
Yamaha RX-V667 AVR_______________Paradigm CC-270 V.3 Center
Emotiva UPA-5 Amplifier______________Dual Stereo Integrity 18" Infinite Baffle
Sony BDP-570 Blu Ray_______________DIY Sound Group Volt 10
action_jackson is offline
Old 08-13-2014, 06:55 AM
lemonslush's Avatar
Quoted: 823 Post(s)
Liked: 402
Balanced to unbalanced, does that mean using something like this http://www.amazon.com/gp/product/B00...=ATVPDKIKX0DER instead of a regulare RCA?
I have those for my sub amps. The crown amp can take the XLR input correct?
Old 08-13-2014, 07:55 AM
Quoted: 182 Post(s)
Liked: 189
Yep, those are what i use and thats worth a shot.
FYI monoprice wires the shield to the neg signal, you need to do surgery on the rca end to "float" the shield. Thats the best way to ensure low noise and combat GL humm. You can always try them in stock trim and see if the humm goes away.
Old 08-13-2014, 07:59 AM
lemonslush's Avatar
Quoted: 823 Post(s)
Liked: 402
Not sure I follow what you mean by "float" the shield. Any way I can find info on this someplace? Thanks for your help BTW.
Do you mean do something like this? http://bcae1.com/images/rca/thumbnails/IMG_9228b_t.jpg
What would I ground the wire to? Would the metal case work?
Old 08-13-2014, 08:05 AM
Quoted: 182 Post(s)
Liked: 189
Float= disconnect
Shield= copper braid surrounding signal wires
You can achieve this any way you like.
See scenario #17.
You see that the shield is not connected at the rca end and only connected at the xlr end. Monoprice grounds the shield to the negative of the signal wire inside the rca connector. You just unscrew the connector disconnect the shield in a neat manner that won't short to any other connection and re-secure the connector.
MemX likes this.
Old 08-13-2014, 08:26 AM
Quoted: 182 Post(s)
Liked: 189
Nope, your not adding a ground connection your removing an unwanted one. See ^
Old 08-13-2014, 08:51 AM
lemonslush's Avatar
Quoted: 823 Post(s)
Liked: 402
Gotcha, thanks very much for the explanation. Would using a rca to xlr converter be a better bet then?
