15" Ported Design Help ? 20W x 24H x 24D (external dimentions) - AVS Forum | Home Theater Discussions And Reviews
Old 08-05-2014, 07:58 PM - Thread Starter
randyc1's Avatar
Quoted: 238 Post(s)
Liked: 40
Would like to upgrade my current 2 -12" RSS315HO,3.6cuft net Subs with 15" subs in bigger cabs. The biggest I would like to go is 20W x 24H x 24D,which comes out to (6.6cuft External). these dimension allow me to use them upright 24"high or on there sides 20" high.
I will build 4 for my 22'x24'x8' room. 2 front firing,slotted, martystyle, and 2 downfiring to be a little less obvious for the back of my Media room.
Drivers : 4 x RSS390HO or SI 15D4" ? Powered by a inuke 6000dsp ??, dont know which Driver would turn out better for this size enclosure after port and tune are determined ?. Will be used mainly for HT.
Picture of what i have now
Thanks !!
randyc1 is offline
Old 08-05-2014, 08:12 PM
chalugadp's Avatar
Quoted: 1672 Post(s)
Liked: 1505
Si15d4 and you can run 2 off of inuke3000dsp. Both drivers will perform similar but Dayton will need inuke6000 for full power.
Your tuning will be 21-22hz. Usuable to 17hz.
chalugadp is offline
Old 08-05-2014, 10:08 PM - Thread Starter
randyc1's Avatar
Quoted: 238 Post(s)
Liked: 40
Hi Chalugadp Thanks , ...I dont have WinISD, is this how you calculated Net Vol and Port ?
randyc1 is offline
Old 08-05-2014, 10:11 PM
chalugadp's Avatar
Liked: 1505
Seen so many sizes that I know tuning pretty well. Your slightly smaller then cube and bigger then micro.
Old 08-06-2014, 04:09 PM - Thread Starter
randyc1's Avatar
Quoted: 238 Post(s)
Liked: 40
...Just need someone who can design this for me now
randyc1 is offline
Old 08-06-2014, 06:13 PM
chrapladm's Avatar
Quoted: 827 Post(s)
Liked: 288
Do you have the 15" SI's already?
chrapladm is offline
Old 08-06-2014, 06:22 PM - Thread Starter
randyc1's Avatar
Quoted: 238 Post(s)
Liked: 40
Hi again Chrapladm,... no I don't , not sure between SI15" or RSS390HO for the dimentions I want to build ?, ...if very similar the SI15 is $145.00 though ?
randyc1 is offline
Old 08-06-2014, 07:42 PM
chrapladm's Avatar
Quoted: 827 Post(s)
Liked: 288
Unless you see them online I dont believe the SI 15's are available any more. The UM15's are from Dayton. The 390 has less excursion than the UM15. BUT its your call.
Old 08-06-2014, 07:53 PM - Thread Starter
randyc1's Avatar
Quoted: 238 Post(s)
Liked: 40
...The SI still have D4's and the UM15 takes a huge ported box , way bigger than the Ext: 20x24x24 i would like to build. so i guess the 2 best for the money are the SI and RSS.
How much depends on TS Paremeters ?
randyc1 is offline
Old 08-06-2014, 08:12 PM
chalugadp's Avatar
Liked: 1505
...The SI still have D4's and the UM15 takes a huge ported box , way bigger than the Ex: 20x24x24 i would like to build. so i guess the 2 best for the money are the SI and RSS.
The UM won't work in a ported box that small. The Dayton can handle more power and i know it works great in that size. Never used the si15 in that size cab.
Old 08-06-2014, 08:15 PM - Thread Starter
randyc1's Avatar
Quoted: 238 Post(s)
Liked: 40
The SI15" has Same power handeling as the 18"..which from what we have learned is quit a bit more than 600W,..I guess it all depends on the TS parameters ??
randyc1 is offline
Old 08-09-2014, 01:50 PM - Thread Starter
randyc1's Avatar
Quoted: 238 Post(s)
Liked: 40
Talking
...Anybody willing to Design-Model these for me in a 4.4cuft net cab with the SI15"
Ext Enclosure: 20Wx 24Hx 25D.
Slot Port : 17.75W x 1.5" ?
randyc1 is offline
Old 08-13-2014, 07:50 AM - Thread Starter
randyc1's Avatar
Quoted: 238 Post(s)
Liked: 40
...Anyone like Modeling a Driver ?
randyc1 is offline
Old 08-13-2014, 02:13 PM
RickJames's Avatar
Quoted: 80 Post(s)
Liked: 65
Bill's Simplexx 15 sub is 20x20, 24.5 high. An SPL chart with the RSS390 HO is in this thread, http://billfitzmaurice.info/forum/vi...p?f=12&t=20963
RickJames is offline
Old 08-13-2014, 02:14 PM
Bassment's Avatar
Quoted: 904 Post(s)
Liked: 364
Bassment is offline
Old 08-13-2014, 02:20 PM
Bassment's Avatar
Quoted: 904 Post(s)
Liked: 364
For a 20 hz tune you need approximately:
Slot Port : 17.75W x 1.5" x 31"
Bassment is offline
Old 08-13-2014, 06:54 PM - Thread Starter
randyc1's Avatar
Quoted: 238 Post(s)
Liked: 40
Yes thanks Bassment !!,
Thats about what i had calculated also,... just wished I could get someone to model this for me with the SI15" to check if everything is were it should be , Vent speed, Ideal Tuning ..ect ?
randyc1 is offline
Old 08-13-2014, 09:18 PM
chrapladm's Avatar
Quoted: 827 Post(s)
Liked: 288
Dont worry about ideal tuning. And I will post another simulation with that port size.
Old 08-13-2014, 10:16 PM - Thread Starter
randyc1's Avatar
Quoted: 238 Post(s)
Liked: 40
dont worry about ideal tuning. And i will post another simulation with that port size.
Great Thanks !!
randyc1 is offline
Old 08-14-2014, 07:11 AM
Bassment's Avatar
Quoted: 904 Post(s)
Liked: 364
2nd order 17 hz HPF
5 cubic feet internal box
20 hz tune
900 watts
under xmax at all frequencies
Bassment is offline
Old 08-14-2014, 08:59 AM - Thread Starter
randyc1's Avatar
Quoted: 238 Post(s)
Liked: 40
2nd order 17 hz HPF
20 hz tune
900 watts
Thanks Bassment ,... mine is actually 4.4cuft net
This is what LTD came up with (Micro thread) for the SI15 in a Smaller 3.5cuft @23 Hz tune
...Pactally Identical ?? ...Is it just beacause he used 1100W ??
randyc1 is offline
Old 08-14-2014, 09:05 AM
Bassment's Avatar
Quoted: 904 Post(s)
Liked: 364
yep, the extra watts would make up for the tiny bit of sensitivity lost by going to a smaller box size.
Bassment is offline
Old 08-14-2014, 09:17 AM - Thread Starter
randyc1's Avatar
Quoted: 238 Post(s)
Liked: 40
Thanks again Bassment for helping me out !!
randyc1 is offline
Old 08-14-2014, 09:40 AM
Bassment's Avatar
Quoted: 904 Post(s)
Liked: 364
you want a 35.5" long slot port then if your net internal is 4.5 cu ft, for a 20 hz tune
Bassment is offline
Old 08-14-2014, 11:13 AM - Thread Starter
randyc1's Avatar
Quoted: 238 Post(s)
Liked: 40
Thanks ,..How do you go about choosing the ideal "Tune",.. is it a compromise of SPL and Extension ?
Will the fact that i will be building 4 Subs change the choosen "Tune" ?
Thanks again !
randyc1 is offline
Old 08-14-2014, 11:34 AM
Bassment's Avatar
Quoted: 904 Post(s)
Liked: 364
Yea a compromise of SPL and extension, and also box size. 4 sub's won't effect what tuning you want, it's the box size mainly. My thoughts for SI (15 or 18), and most other HT subs, is to tune in general:
13 cu ft to 14 hz
6.5 cu ft to 17 hz
4 cu ft to 20 hz
I don't find small changes in tuning frequencies to be noticeable at all. I don't think someone could tell the difference between a 19 hz and 20 hz tuning frequency. To do large jumps in optimal tuning frequencies you need to do large changes in box sizes.
Bassment is offline
Old 08-14-2014, 01:32 PM - Thread Starter
randyc1's Avatar
Quoted: 238 Post(s)
Liked: 40
13 cu ft to 14 hz
6.5 cu ft to 17 hz
4 cu ft to 20 hz
...OK last question Bassment , ...do you have any idea if my Port Velocity is OK with my
17.75" x 1.5" (26.6sq in) Slot Port ? The Area comes to a little over the same area as( 2) 4" Round ports ???
randyc1 is offline
Old 08-14-2014, 01:58 PM
Bassment's Avatar
Quoted: 904 Post(s)
Liked: 364
Bassment is offline
Old 08-14-2014, 02:02 PM - Thread Starter
randyc1's Avatar
Quoted: 238 Post(s)
Liked: 40
Ya it was good
Thanks soo much for taking the time to help me !!
randyc1 is offline
Old 08-18-2014, 07:22 PM
chrapladm's Avatar
Quoted: 827 Post(s)
Liked: 288
Glad you got it sorted.
