can the Denham MTM's keep up with multiple 18's? - AVS Forum | Home Theater Discussions And Reviews
Old 08-06-2014, 03:36 PM - Thread Starter
corndogggy's Avatar
Quoted: 157 Post(s)
Liked: 44
http://www.diysoundgroup.com/speaker...enham-kit.html
If I had 3 of those up front, could they keep up with 2-4 18's or is this just silliness? If I go with a DIY kit that is any bigger, the project gets exponentially complex. The next step up that I think would work:
http://www.divine-audio.com/canaiolo/3/
Lots harder. Is it necessary? Or are these more of something you'd use with no sub at all?
corndogggy is offline
Old 08-06-2014, 05:25 PM
Manic1!'s Avatar
Quoted: 175 Post(s)
Liked: 75
What are you powering the speakers with?
Manic1! is online now
Old 08-06-2014, 05:52 PM
mbyrnes's Avatar
Quoted: 93 Post(s)
Liked: 186
I would look at SEOS speakers. You will want something highly efficient imo. With that much bass I would want a speaker that could keep up at loud volume levels. I have 1099s and they are up to the task. Plenty of designs that would be better imo. Depends on your size needs and budget. Something should fit for you.
mbyrnes is offline
Old 08-06-2014, 06:33 PM
Samps's Avatar
Quoted: 789 Post(s)
Liked: 418
Here is a recent thread with some good info
HELP DIY speakers -> Denham MTM Look interesting any input?
Samps is online now
