Will covering a bass trap w/perforated hardboard reduce effectiveness? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 16 Old 08-06-2014, 07:27 PM - Thread Starter
noah katz's Avatar
Quoted: 878 Post(s)
Liked: 304
Quick version:
Will the 3/16" perforated panel shown in the pic reduce the effectiveness of OC 702 behind it?
Details:
I'm covering bass traps (6" thick OC 702 x 24" x 60") with grasscloth fabric.
For looks and with no small effort I made the faces curved.
I carefully measured, cut, and stapled the grasscloth to the frames.
I made the frames a bit oversized in depth so if I had a problem with the grasscloth buckling or wrinkling, I could put batting in to fluff it out.
Didn't work, there are wrinkles I can't get rid of.
So I'm redoing them with perforated hardboard panels to match the frame curvature and give a surface for the grasscloth to follow.
My concern is that with only 5% open area the panels will impede effectiveness of the traps.
The panels are 3/16" thick and even with the curvature applied (see pic; if you're thinking it doesn't look like 6" thick it's because 4" is in the wall cavity behind it), it flexes noticeably with moderate finger pressure.
So likely it's transparent to bass but I'd like someone with more experience to verify.
Increasing the open area by drilling the holes bigger is a nonstarter (about 5000 holes).
I could groove them to increase flexibility, but I'd rather not as that would still be quite tedious.
Noah
noah katz is online now
post #2 of 16 Old 08-08-2014, 05:39 AM
Audio Geek's Avatar
Quoted: 91 Post(s)
Liked: 42
How about using a metal grill instead?
Audio Geek is offline
post #3 of 16 Old 08-08-2014, 08:44 AM
JohnDean's Avatar
Quoted: 430 Post(s)
Liked: 183
How about using a hole saw/drill bit to make every 5th hole 2"? I've done that before and it cuts through very quickly.
JohnDean is online now
post #4 of 16 Old 08-08-2014, 09:56 AM
JackNC's Avatar
Quoted: 135 Post(s)
Liked: 37
you can model the effect of the holy panel here:
http://www.acousticmodelling.com/multi.php
JackNC is offline
post #5 of 16 Old 08-08-2014, 10:28 AM - Thread Starter
noah katz's Avatar
Quoted: 878 Post(s)
Liked: 304
I considered that real perforated etc metal was expensive.
I looked at hardware cloth but thought thin wood-based material would be easier to attach and give a more uniform surface.
I actually tried that but too slow considering the number of holes.
Neat calculator, thanks.
Also I have no idea what to choose for "Porous model", but leaving everything on the left at defaults and with the data for the perforated panel I got "Absorber configuration is not valid."
Water under the bridge at this point; turns out the panels were so stiff that applying the curvature caused the sides of the frames to bow out.
To make them more flexible I cut 1/8" deep x 5/8" wide grooves between every column of holes; this took a few hours, so not too bad.
Now the frames don't bow out and the panels deflect easily with finger pressure so I'm confident they're transparent to bass.
Noah
post #6 of 16 Old 08-08-2014, 11:01 AM
BassThatHz's Avatar
Quoted: 2031 Post(s)
Liked: 1546
It won't absorb highs with the hardboard, which is probably what you want (maybe).
The bass will go right through it; 60hz will go through a solid block of 5/8 drywall, 5/8 OSB and 6 inches of insulation + air gap, with only a few db's of reduction... which is a standard house construction, that's why you can hear bass cars zooming by (although most of that weakness is windows and doors, which bass also goes through.)
Even in my theater, distant thunder <105db sounds like someone jumping on a sheet of 1/8 plywood outside; and that's more than double the thickness of what a standard house construction is.
I haven't seen too many before and after bass trap measurements threads, but I would imagine that the bass isn't "trapped" by very much.
BassThatHz is offline
post #7 of 16 Old 08-08-2014, 11:15 AM
corndogggy's Avatar
Quoted: 157 Post(s)
Liked: 44
A real easy test for this type of thing is can you put your mouth on any part of it and comfortably breathe through it with no additional effort or discomfort? If you cannot do that, then you don't need to be firing soundwaves through it.
corndogggy is offline
post #8 of 16 Old 08-08-2014, 01:23 PM
Audio Geek's Avatar
Quoted: 91 Post(s)
Liked: 42
What about chicken wire?
http://www.homedepot.com/s/chicken+wire+fence?NCNI-5
Not sure how clean it'll look covered, though.
post #9 of 16 Old 08-08-2014, 02:00 PM - Thread Starter
noah katz's Avatar
Quoted: 878 Post(s)
Liked: 304
Doesn't really matter; they're out of the way in the corners and all of my speakers are CD.
Not totally absorbing is different than not attenuating at all. and house insulation has much lower low freq absorption than OC 702.
In any case I heard an appreciable reduction in boominess when I added them at all four corners and in a big opening in the back wall.
Not sure I'm getting your point, but bass easily goes through things that air can't.
Too flexible to hold shape.
Noah
post #10 of 16 Old 08-08-2014, 02:40 PM
asarose247's Avatar
Quoted: 695 Post(s)
Liked: 451
Lots of relevant info, video and links at Realtraps, Ethan Winer"s site, the real lowdown.
you'll want a desktop icon, it is almost too much for just one visit
DIY FAN Denon X5200 , ATI A 2000 for 7.4.6 SCATMOS/DSU/SHARP 80" LED/LCD
L/R: Fusion 15 V2 , C: 88 Special , SL/SR: F4Q4LP , RL/RR: F-3, TF/TR: Volt 6's TM: SLX
SUBMAXIMUS, ,Submaximus V3,LOWARHORNCustom Dual Driver VBSS,2 x Inuke6000DSP
www.avsforum.com/forum/155-diy-speakers-subs/1485120-submaximus-large-front-loaded-horn
http://www.avsforum.com/forum/155-di...orn-build.html
asarose247 is online now
post #11 of 16 Old 08-09-2014, 06:35 AM
Martycool007's Avatar
Quoted: 280 Post(s)
Liked: 176
So are these curved panels 6" thick? I am not familiar with OC702, but I have used OC703 on my theater walls and ceiling. How much difference in price is there between OC703 versus OC702? I would imagine that your bass traps are very expensive! Around here a 2ft by.4ft panel of 2" thick OC703 cost almost $80! I can just imagine what a 6" deep and really wide bass trap would cost!
In my old theater room I just used stacked triangles of pink fluffy in each corner to work as my bass traps, but now that I have a real theater room that I want to look really nice, I must find a prettier solution to my corner bass traps.
Any suggestions? Perhaps it could check on some OC702 and do a build similar to yours, assuming that it's no where near $80 per 2" thick 2ft by 4ft panel!
Martycool007 is offline
post #12 of 16 Old 08-09-2014, 01:54 PM - Thread Starter
noah katz's Avatar
Quoted: 878 Post(s)
Liked: 304
I may have misremembered the number, maybe I have OC 703.
They're built up from flat 2" pieces with the top layer making the curve cut from different thicknesses/angles; now that I added the curves frames/hardboard that was wasted effort.
It's been years, but IIRC it was about $125 for all of it from a heating/insulation supply.
Or maybe I did it in two rounds and that was just one of them; can't remember.
Noah
post #13 of 16 Old 08-09-2014, 03:45 PM
corndogggy's Avatar
Quoted: 157 Post(s)
Liked: 44
Do you think it is optimal to use a solid-core commercial-grade steel-plated door panel for a subwoofer grill? Why not? Bass will go right through it after all. I mean, it really will. I used to work at a place that had steel external walls, several inches of insulation, then drywall interior, I'd roll up in my car and about jolt people's teeth out. So, would steel wrapped fiberglass backed by drywall make a good subwoofer grill?
post #14 of 16 Old 08-09-2014, 08:38 PM - Thread Starter
noah katz's Avatar
Quoted: 878 Post(s)
Liked: 304
Still not getting what that has to do with anything I said.
Oh, you mean my original concern is totally unfounded; got it.
Noah
post #15 of 16 Old 08-10-2014, 02:33 AM
LTD02's Avatar
Quoted: 2340 Post(s)
Liked: 2573
get some perforated metal plate--the stuff the pro-audio guys use for their grills. it is pretty much acoustically transparent, not too expensive, and should hold the shape you are shooting for.
Listen. It's All Good.
LTD02 is offline
post #16 of 16 Old 08-10-2014, 06:05 PM - Thread Starter
noah katz's Avatar
Quoted: 878 Post(s)
Liked: 304
As I said
Water under the bridge at this point...
Noah
