Volt-10 Curve Ball:
Calcumalations:
I use Durham's Rock hard putty to fill any gaps.
Woofer Cutouts Done
Did the sanding on the curves. Here is a comparo, the final result is pretty smooth:
Extreme Closeup!(Wayne's World Ref):
Sides on:
Now we are starting to look like a surround speaker:
Veneer:
Reconstituted Mascar Ebony
Contact cement used:
Also, the back panel requires some bracing. It resonates at about the same frequency as a tom drum on a drum kit so, bracing added:
Terminal cups in:
Veneer Time!
This is a "Carpet Chisel?" It works much better than a J roller in applying the needed pressure to get the contact adhesive activated:
Im really liking the look.
Now the tricky part:
Seams turned out nice n tight:
This is obviously without any finish:
Calcumalations:
Woofer Cutouts Done
Sides on:
Veneer:
Terminal cups in:
Veneer Time!
