another Infinity 1262w build - AVS Forum | Home Theater Discussions And Reviews
 11Likes
post #1 of 38 Old 08-10-2014, 10:12 AM - Thread Starter
brian6751's Avatar
Quoted: 1146 Post(s)
Liked: 1125
i have had two of these drivers in two 1.5cft. sealed boxes for a while now but i want to try them in ported enclosures.
i know these have been modeled and built to death but im new to using WinISD and all my other builds were copies of others designs so i wanted to model these myself so i can get better at that part of DIY.
my plan is to build two slot ported boxes:
4 cft. NET volume after accounting for the port, driver and bracing.
18Hz tuning
Two ports 4.5" wide 1.5" tall and 25.8" long
box outer dimensions are 18" wide 26" high 21" deep.
port volume at 435 cubic inches
bracing at 200 cubic inches (plywood strips)
driver at .12 cubic feet
i come up with a max rear port velocity of 24.97 m/s at 17.87Hz.
SPL with 300 watts is just over 104 DB at 18Hz. HPF at 17Hz.
Name:	Screen Shot 2014-08-10 at 1.08.25 PM.png
ID:	206465   Click image for larger version
Name:	Screen Shot 2014-08-10 at 1.21.36 PM.png
ID:	206473   Click image for larger version
Name:	Screen Shot 2014-08-10 at 1.22.11 PM.png
That's not science! - Cyborg
FOR SALE: nothing at the moment
Rivers Edge Theater
brian6751 is offline
post #2 of 38 Old 08-10-2014, 10:40 AM
aackthpt's Avatar
Quoted: 16 Post(s)
Liked: 26
I'm not sure what port airspeed most people are using as a limit nowadays but it looked high based on memory, and still does based on a quick review of Collo's stuff:
http://www.subwoofer-builder.com/port-flares.htm
I'm guessing this is the regular WinISD? Most of the screen dumps I see around are from the pro alpha or whatever.
aackthpt is offline
post #3 of 38 Old 08-10-2014, 10:45 AM - Thread Starter
brian6751's Avatar
Liked: 1125
its pro alpha.
the port velocity is one area i need more education on. i was shooting for under 30 m/s which is what seemed to be a good target from my limited reading on the subject.
Rivers Edge Theater
post #4 of 38 Old 08-10-2014, 11:17 AM - Thread Starter
brian6751's Avatar
Liked: 1125
Looks like if I go to two 5" x 2" ports at 38.8" long port velocity maxes at 16.8 m/s
post #5 of 38 Old 08-10-2014, 07:11 PM
JohnDean's Avatar
Quoted: 467 Post(s)
Liked: 206
Add an 18hz hpf to your first model and see what that does for your airspeed.
JohnDean is offline
post #6 of 38 Old 08-11-2014, 11:20 PM
LTD02's Avatar
Quoted: 2527 Post(s)
Liked: 2869
that's probably about borderline.
if a larger cab is possible, the port area can be increased without increasing the length.
should be a fun project from a comparative perspective.
Listen. It's All Good.
LTD02 is offline
post #7 of 38 Old 08-12-2014, 06:42 AM
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2697
Port at 20hz. Not 18hz.
brian6751 likes this.
Mfusick is offline
post #8 of 38 Old 08-12-2014, 07:02 AM
randyc1's Avatar
Quoted: 241 Post(s)
Liked: 40
18Hz tuning
I have built (2) 3.6cuft net Ported SUBS with the RSS315HO @18Hz tune with one 4" Port and pushed them to the limits of the SA1000 Amp and never heard any Port Chuffing,...if this can help ?
randyc1 is offline
post #9 of 38 Old 08-12-2014, 07:06 AM
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2697
I built a really nice 24" cube with slot port and 20hz tune on a bash amp plate and it works great. Impressive actually.
Mfusick is offline
post #10 of 38 Old 08-12-2014, 12:20 PM - Thread Starter
brian6751's Avatar
Liked: 1125
ok so using the same 2 5" x 2" ports 38.8" long with a tuning of 18Hz and a HPF at 18Hz i get a max port velocity of 15.2 m/s
ID:	209201   Click image for larger version
Name:	Screen Shot 2014-08-12 at 3.18.52 PM.png
ID:	209209   Click image for larger version
Name:	Screen Shot 2014-08-12 at 3.19.31 PM.png
ID:	209217   Click image for larger version
Name:	Screen Shot 2014-08-12 at 3.20.05 PM.png
Rivers Edge Theater
post #11 of 38 Old 08-12-2014, 12:21 PM - Thread Starter
brian6751's Avatar
Liked: 1125
i always liked those subs. they look really cool
randyc1 likes this.
Rivers Edge Theater
post #12 of 38 Old 08-12-2014, 12:31 PM - Thread Starter
brian6751's Avatar
Liked: 1125
i will try to take comparative readings. ill need to take some more sweeps with the sealed setup and also another close mic with the amp settings
Rivers Edge Theater
post #13 of 38 Old 08-12-2014, 01:31 PM - Thread Starter
brian6751's Avatar
Liked: 1125
hmm
making the box 5cft. with two 5.5"x2"x33.7" ports gets me 105db at 18Hz with 16.3 m/s velocity at 300 watts
going to 500 watts, which would be about the peak of the amp at full throttle, gets up to 107db with air speed at 21.1 m/s.
dang. that seems very impressive from this budget driver. am i missing something?
Rivers Edge Theater
post #14 of 38 Old 08-12-2014, 03:17 PM
manuetdeo's Avatar
Quoted: 56 Post(s)
Liked: 79
hmm
nope, with my 1260s I have a 22hz tune and get 105db at 20hz with 300w before hiting xmax, airspeed at 12m/s.
Mfusick and LTD02 like this.
manuetdeo is offline
post #15 of 38 Old 08-12-2014, 03:21 PM - Thread Starter
brian6751's Avatar
Liked: 1125
i should mention that these are actually the 1262's. allows me to wire them as 2 ohms to a Behringer inuke 1000dsp. i dont think that makes a difference.
what is your box volume?
Rivers Edge Theater
post #16 of 38 Old 08-12-2014, 04:05 PM
manuetdeo's Avatar
Quoted: 56 Post(s)
Liked: 79
I saw they were the 1262s, I believe they are the same driver except for the DVC, either way they seem to model pretty close to each other. My boxes are 4.5 cu ft net.
post #17 of 38 Old 08-12-2014, 04:39 PM - Thread Starter
brian6751's Avatar
Liked: 1125
im only seeing an increase of 1.5 db from 4 to 5 cft. im kind of leaning towards 4 cft. on these
Rivers Edge Theater
post #18 of 38 Old 08-12-2014, 04:52 PM - Thread Starter
brian6751's Avatar
Liked: 1125
im also looking at two of these in a 8 cft. box......
Mfusick likes this.
Rivers Edge Theater
post #19 of 38 Old 08-12-2014, 05:26 PM
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2697
This works rather nice. You get a benefit of dual drivers. You could make it simple 24"x24"x48" for the easiest possible build. Trim one dimension the 1.5" to make it square with the .75+.75 edges, this allows you to use 24" wood + some 23.25" so you waste nothing.
Mfusick is offline
post #20 of 38 Old 08-12-2014, 05:35 PM - Thread Starter
brian6751's Avatar
Liked: 1125
yeah... unfortunately that size isnt going to work for this application. there just isnt enough room. thats also a lot more firepower than my little AJ Pioneer mains can keep up with
Rivers Edge Theater
post #21 of 38 Old 08-12-2014, 06:02 PM - Thread Starter
brian6751's Avatar
Liked: 1125
i think im going to take your advice. 4 cft. tuned to 20 Hz with a 20 hpf looks to be the sweet spot. im want to use 3 ports. each 1.5" x 5" x 35.5"
port velocity stays under 15 m/s with 300 watts and just breaks 19 m/s with 500 watts.
how does that sound?
Mfusick likes this.
Rivers Edge Theater
post #22 of 38 Old 08-12-2014, 06:14 PM
manuetdeo's Avatar
Quoted: 56 Post(s)
Liked: 79
Sounds good, If your WAF is as bad as mine, you'll never hit 100db anyways. Around here 75 is making her go deaf and going to ruining our kids hearing for life!
post #23 of 38 Old 08-12-2014, 06:53 PM - Thread Starter
brian6751's Avatar
Liked: 1125
that depends. if its me watching my stuff, its 75. If its her watching the Kardashians(sp?) its 130!!!
Rivers Edge Theater
post #24 of 38 Old 08-13-2014, 02:10 PM - Thread Starter
brian6751's Avatar
Liked: 1125
18 Hz in Blue
Name:	Screen Shot 2014-08-13 at 5.08.58 PM.png
ID:	210625   Click image for larger version
Name:	Screen Shot 2014-08-13 at 5.09.47 PM.png
Rivers Edge Theater
post #25 of 38 Old 08-17-2014, 08:48 AM - Thread Starter
brian6751's Avatar
Liked: 1125
problem with 18Hz is that it seems to go past xmax. 20Hz in 4 cubes keeps it just under xmax at all levels. but its really close. 12.7mm out of 13mm max. is that too close?
thats with 300 watts. boost that to 500 and im over 16mm at around 30 Hz
300 watts
500 watts
Name:	Screen Shot 2014-08-17 at 12.40.03 PM.png
Rivers Edge Theater
post #26 of 38 Old 08-17-2014, 10:22 AM
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2697
20-22hz is perfect. Error on the side of higher if you need to.
Mfusick is offline
post #27 of 38 Old 08-17-2014, 10:29 AM - Thread Starter
brian6751's Avatar
Liked: 1125
i also have a question regarding the slot port. if one wide slot port is separated by two braces, should it be calculated as three separate ports? i noticed it calculates differently counted as three separate as opposed to just adjusting the width of one port to account for the braces.
Example.
this sub is 16.5" wide total. If i want a slot across the entire bottom, i subtract 1.5" to account for the side panels, then another 1.5" to account for the vent braces which gives me 13.5"
1 slot port 1.5 x 13.5 calculates to 30.25" for a 20Hz tune.
Now lets treat it as 3 separate ports. 13.5 divided by 3 = 4.5
3 ports 1.5 x 4.5 calculates to 31.82" for the same tune.
if its 3 ports then i think ill go with 1.75 x 4 x 33
Rivers Edge Theater
post #28 of 38 Old 08-17-2014, 10:32 AM - Thread Starter
brian6751's Avatar
Liked: 1125
ill just have to limit the amp to 300 watts. this driver cannot handle 500 watts with this box design. thats fine. its still hitting 105DB at 20Hz with 300 watts
Rivers Edge Theater
post #29 of 38 Old 08-17-2014, 12:04 PM
Mrkazador's Avatar
Quoted: 262 Post(s)
Liked: 390
i also have a question regarding the slot port. If one wide slot port is separated by two braces, should it be calculated as three separate ports?
yes!
Mrkazador is online now
post #30 of 38 Old 08-17-2014, 01:20 PM
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2697
I just calculate the slot port as a single port. And I subtract out the braces from the length total. Simple that way.
Mfusick is offline
