Mini Marty Sub Question - AVS Forum | Home Theater Discussions And Reviews
 1Likes
  • 1 Post By brian6751
post #1 of 17 Old 08-10-2014, 07:51 PM - Thread Starter
AVI20's Avatar
I built a mini Marty about 3 months ago, killer sub, I love everything about it. I have a iNuke6000dsp to power it, how many more of the mini Martys will thus amp push?
Also I built the sub and asked if I should use any polyfill,I was told no, so I didnt. Would asking some in make a difference?
Thank you all in advance!
AVI20 is offline
post #2 of 17 Old 08-10-2014, 08:07 PM
Samps's Avatar
Quoted: 787 Post(s)
Liked: 413
The 6000 can run 2 easy, four would be pushing it. Don't think three can work since you can't bridge.
Samps is online now
post #3 of 17 Old 08-10-2014, 08:13 PM
atabea's Avatar
Quoted: 543 Post(s)
Liked: 332
Not sure about the amp question, but if your build was one of the larger Marty variants, I would suggest you add either some poly fill, foam or pillows.
atabea is online now
post #4 of 17 Old 08-10-2014, 08:34 PM
Audio Geek's Avatar
Quoted: 91 Post(s)
Liked: 42
It depends on the drivers that you have. What do you have?
Audio Geek is offline
post #5 of 17 Old 08-10-2014, 11:19 PM
randyc1's Avatar
Quoted: 238 Post(s)
Liked: 40
Should be able to Power 4 SI's,.. 2 SI D4 on each channel wired in parallel for a total of 4 ohm load . (3100W x 2 channel@ 4ohm), each sub will recieve 1500 (1100W) each.
randyc1 is offline
post #6 of 17 Old 08-11-2014, 04:39 PM - Thread Starter
AVI20's Avatar
I used the Dayton audio 18ho
AVI20 is offline
post #7 of 17 Old 08-11-2014, 04:40 PM - Thread Starter
AVI20's Avatar
just normal house pillows? If so how many?
AVI20 is offline
post #8 of 17 Old 08-11-2014, 04:53 PM
atabea's Avatar
Quoted: 543 Post(s)
Liked: 332
If your Marty is similar to mine (which 24x30x36 WHD), then three regular-sized walmart pillows will be sufficient. Here is a picture of how I placed them in the sub. And not to worry, their position does not affect performance in any way.
post #9 of 17 Old 08-11-2014, 05:20 PM
Audio Geek's Avatar
Quoted: 91 Post(s)
Liked: 42
https://www.parts-express.com/dayton...4-ohm--295-472
If the above is your driver, its impedence is 4 ohms.
Assuming the manufacturer specs are accurate:
A single driver on each channel (so two total) would get 3100 W @ 4 ohms. You'd need to limit the output of the amp to protect the drivers.
You could hook up two drivers in series (4 ohms * 2 = 8 ohms) for 1600 W @ 8 ohms / 2 drivers = 800 W / driver. This is per channel, so using both channels, you could hook up four drivers.
You could hook up in parallel two sets of two drivers in series (4 ohms * 2 / 2 = 4 ohms) for an impedence of 4 ohms, you could hook up 4 drivers per channel for 3100 W / 4 = 775 W / driver. Using both channels, this could be eight drivers total.
You can mix and match how many you have hooked up to each channel since they're independent.
post #10 of 17 Old 08-11-2014, 05:34 PM - Thread Starter
AVI20's Avatar
Thank you! That was really helpful, I think I'll start with 4 total, then maybe go to 8. Just never enough bass is there??
AVI20 is offline
post #11 of 17 Old 08-11-2014, 05:34 PM - Thread Starter
AVI20's Avatar
awesome! Off too wally world! Thank you sir!
AVI20 is offline
post #12 of 17 Old 08-11-2014, 06:13 PM
Samps's Avatar
Quoted: 787 Post(s)
Liked: 413
The 3000 was bench tested to put out 2000 watts bridged into 4 ohms. The 6000 is two permanantly bridged 3000s. So 4 SI would see 1000 each. That certainly should be enough to push them hard but I think you can run up to 1300 watts each. So 4 on the 6000 leaves a little on the table.
Samps is online now
post #13 of 17 Old 08-11-2014, 06:19 PM
brian6751's Avatar
Quoted: 879 Post(s)
Liked: 674
Here is a chart showing the actual rms numbers
http://music-group.force.com/PKB/art...fs=Search&pn=1
You would be fine running one more dayton with plenty of headroom but, 4 of those drivers on that amp would get 550 watts each. I would get a different amp or different drivers before doing that personally.
Either two UXL-18's or four SI 18 D4's
randyc1 likes this.
That's not science! - Cyborg
Steam ID: The Barbeerian
Rivers Edge Theater
brian6751 is online now
post #14 of 17 Old 08-18-2014, 06:36 PM
aaronlinkous's Avatar
Quoted: 55 Post(s)
Liked: 68
Atabea, do you have a build of your sub anywhere? Im looking at making my mini a bit smaller than spec and front ported like you and trying to research everything.
aaronlinkous is offline
post #15 of 17 Old 08-18-2014, 06:41 PM
atabea's Avatar
Quoted: 543 Post(s)
Liked: 332
Here: Another LTD02 Designed Sub Build
post #16 of 17 Old 08-18-2014, 07:10 PM
Quoted: 55 Post(s)
Liked: 68
Awesome, Thanks!
post #17 of 17 Old 08-18-2014, 07:15 PM
Samps's Avatar
Quoted: 787 Post(s)
Liked: 413
In my previous post I wrote the SI could handle 1300 but I think it is 1100 not 1300.
Samps is online now
