The Berstuck Box: 2xUM18-22 in 25 Cubic Feet at 16Hz - Page 2 - AVS Forum | Home Theater Discussions And Reviews
 63Likes
post #31 of 238 Old 08-11-2014, 11:24 AM - Thread Starter
notnyt's Avatar
Quoted: 2772 Post(s)
Liked: 2556
Originally Posted by randyc1 View Post
Can i ask how you arrived at that port length , trying to figure out Sot Ports,..How many cuft Net ?
WinISD. All the info is in the first post.
notnyt is offline
post #32 of 238 Old 08-11-2014, 11:27 AM - Thread Starter
notnyt's Avatar
Liked: 2556
Originally Posted by berstuck View Post
Well I ordered in a bora 50 inch clamp on edge guide, and a pneumatic nailer. Still deciding on saw and router, but I'll get those in soon. The cost difference between cheap maple plywood and mdf is about 50 bucks per sub. Am I correct in assuming that trimming off that extra inch is not that big of a deal? Any other advantages to the plywood?
If you go ply, try to go with a high ply count birch or similar ply. No need for a hardwood ply. Make sure you get one without a veneered face.
Cutting just an inch off of an 8 foot board can be tricky to get it perfectly straight. A factory edge will almost always be nice and straight. I did all my builds with ply. Unfortunately, the lumber yards suck here and I had serious warping issues. If you can get good and flat boards, go plywood.
advantages:
Plywood is stronger
Plywood is lighter
disadvantages:
plywood can warp
not a perfectly flat and smooth surface
Upsidedown2 likes this.
notnyt is offline
post #33 of 238 Old 08-11-2014, 11:43 AM
randyc1's Avatar
Quoted: 241 Post(s)
Liked: 40
Yes , I know ,... just that it is sooo much longer than this Port calculator : http://www.mobileinformationlabs.com...0lenth%201.htm
Just wondering why such a difference ?
randyc1 is offline
post #34 of 238 Old 08-11-2014, 11:46 AM - Thread Starter
notnyt's Avatar
Liked: 2556
Most likely because it's not accurate. I'd use a proper app for this, and not some web form. WinISD nailed the port for my last ported design.
EDIT: rofl, swapped height and width and it gives me the right length. Because that makes sense.
notnyt is offline
post #35 of 238 Old 08-11-2014, 11:53 AM
randyc1's Avatar
Quoted: 241 Post(s)
Liked: 40
Yes! ..why is that?
randyc1 is offline
post #36 of 238 Old 08-11-2014, 11:54 AM - Thread Starter
notnyt's Avatar
Liked: 2556
Yes! ..why is that?
Who knows, they're probably doing some weird calculations for the slot port stuff. Meh, I wouldn't bother with that.
notnyt is offline
post #37 of 238 Old 08-11-2014, 11:58 AM
randyc1's Avatar
Quoted: 241 Post(s)
Liked: 40
Allright , thanks Notnyt !!!
randyc1 is offline
post #38 of 238 Old 08-11-2014, 12:37 PM
traider79's Avatar
Awesome Plans. I am gonna watch the build progress.
traider79 is offline
post #39 of 238 Old 08-11-2014, 12:46 PM
jbrown15's Avatar
Quoted: 2523 Post(s)
Liked: 1995
disadvantages:
plywood can warp
I know you can definitely vouch for that one, I remember pictures that you posted of the plywood you had for your fourth cabinet I believe that was pretty warped.
jbrown15 is offline
post #40 of 238 Old 08-11-2014, 12:49 PM - Thread Starter
notnyt's Avatar
Liked: 2556
They were all a fight and a struggle, some were REALLY bad Especially with panels that size. I broke my foot I think dropping the front baffle on it from a table when I was struggling to line stuff up. I had some crazy pictures posted of how bad the boards were warped, probably buried in my build thread somewhere... They didn't show the half of it once you get a box assembled of warped boards and need to squeeze the baffle into place. Ugh.
My locale sucks for getting flat ply
notnyt is offline
post #41 of 238 Old 08-11-2014, 02:36 PM
berstuck's Avatar
Quoted: 66 Post(s)
Liked: 52
Cabinet grade redwood ply is $35 at home depot. Sound ok?
berstuck is offline
post #42 of 238 Old 08-11-2014, 03:39 PM
corndogggy's Avatar
Quoted: 157 Post(s)
Liked: 44
I'm sure my wife will love it.
Famous last words.
Bombelman likes this.
corndogggy is offline
post #43 of 238 Old 08-11-2014, 03:41 PM
berstuck's Avatar
Quoted: 66 Post(s)
Liked: 52
Originally Posted by corndogggy View Post
Famous last words.
I believe you missed the sarcasm in my post sir.
berstuck is offline
post #44 of 238 Old 08-11-2014, 03:49 PM
corndogggy's Avatar
Quoted: 157 Post(s)
Liked: 44
Originally Posted by chalugadp View Post
I'd spend a little extra on brad nailer. Yes harbour freight has one for 20 bucks but I think the Porter cable is worth the 70 bucks.
I've had those Harbor Freight $20 specials, they don't last, but not because of why some people think. They actually work ok at first, but the problem is that they very quickly get to the point where the piston fires a brad but then gets stuck. At that point you have to stop and take a thin screwdriver to shove the piston back into the housing. It is extremely ghetto. I have bought multiple Hitachi units and they work very well.
Personally though, I can't wrap my head around the idea that people are friggin brad nailing a multi-thousand watt subwoofer setup with multiple 18's that weighs well into the triple digits. Get some good plywood and Kreg screw the thing. Yeah I realize it's glued and that's doing most of the work, but still.
post #45 of 238 Old 08-11-2014, 03:50 PM
corndogggy's Avatar
Quoted: 157 Post(s)
Liked: 44
Maybe you missed it in mine. I know how it is.
post #46 of 238 Old 08-11-2014, 03:52 PM
berstuck's Avatar
Quoted: 66 Post(s)
Liked: 52
I don't know what a kreg screw is. Anyhow I bought a $35 nail gun from Lowe's. Hopefully it works well enough.
berstuck is offline
post #47 of 238 Old 08-11-2014, 03:54 PM
corndogggy's Avatar
Quoted: 157 Post(s)
Liked: 44
Does that mean red oak plywood? I figured it would be more than that for 3/4". It's $50 on their site.
http://www.homedepot.com/p/Unbranded...5956/100046409
Read the reviews, they're kind of scary, lots of warping going on. 13 ply baltic birch is the way to go in my opinion but that isn't compatible with your goals.
post #48 of 238 Old 08-11-2014, 03:54 PM
berstuck's Avatar
Quoted: 66 Post(s)
Liked: 52
Craigslist ad here for mdf core ash plywood b1 grade. $15 a sheet. Is that ok?
berstuck is offline
post #49 of 238 Old 08-11-2014, 03:56 PM
chalugadp's Avatar
Quoted: 1674 Post(s)
Liked: 1531
Glue does all the work. Brad nails just allow me to put whole sub together in an hour instead of waiting for glue to dry and taking the whole day.
chalugadp is offline
post #50 of 238 Old 08-11-2014, 03:58 PM
corndogggy's Avatar
Quoted: 157 Post(s)
Liked: 44
aka. pocket screws. Basically you get a jig and clamp it to the edge of a sheet of wood and drill a hole into the end at about a 30 degree angle maybe, stopping just under the surface, which leaves a flat surface on the inside. When you glue up two pieces of wood, you clamp them together then take these screws and fire them into the hole. The screw disappears under the surface and you don't have anything showing on the outside, unlike firing a nail or brad through the exterior. Ends up looking like the picture below, very strong with no external anything, everything is on the inside. It does take awhile if you aren't used to it though, as you have to think about every single hole. Actually doing it isn't bad.
post #51 of 238 Old 08-11-2014, 04:21 PM
berstuck's Avatar
Quoted: 66 Post(s)
Liked: 52
Here's the link to the home depot ply
http://m.homedepot.com/p/3-4-in-x-4-...KSB/205065277/
Nevermind the clist ad. It was only 3/8.
berstuck is offline
post #52 of 238 Old 08-11-2014, 04:33 PM - Thread Starter
notnyt's Avatar
Liked: 2556
If you can get a higher ply count, it'll generally be better. Can't really see what's there. I've built stuff with like 5 ply and it was ok, but I wasn't happy using it. 11 ply is good.
You might want to go checkout a lumber yard and see what they have available. Check out some birch plies and such.
notnyt is offline
post #53 of 238 Old 08-11-2014, 07:47 PM
berstuck's Avatar
Quoted: 66 Post(s)
Liked: 52
What are everyone's thoughts on cheap track saws. The shop fox track saw is under 300, and a cheap saw plus the ez track is about the same money.
berstuck is offline
post #54 of 238 Old 08-11-2014, 09:13 PM
N8DOGG's Avatar
Quoted: 1111 Post(s)
Liked: 1211
Good looking design!!
N8DOGG is offline
post #55 of 238 Old 08-11-2014, 09:14 PM - Thread Starter
notnyt's Avatar
Liked: 2556
I'll be away from the forum for a week I hope everyone can help Berstuck along the way
notnyt is offline
post #56 of 238 Old 08-11-2014, 10:20 PM
berstuck's Avatar
Quoted: 66 Post(s)
Liked: 52
Ok after getting home and doing some more digging I've settled on this for a saw.
https://www.grizzly.com/products/Tra...er-Pack/T25552
It's 265 with shipping. Cheapest track saw I could find.
berstuck is offline
post #57 of 238 Old 08-11-2014, 10:21 PM
berstuck's Avatar
Quoted: 66 Post(s)
Liked: 52
And I'll probably buy a cheap harbor freight plunge router. I know people hate them, but I gotta go as cheap as possible where I can.
berstuck is offline
post #58 of 238 Old 08-12-2014, 10:32 AM
LTD02's Avatar
Quoted: 2524 Post(s)
Liked: 2867
the difference in the calculators is for slot port correction. the straight slot ports that were done in marty subs needed some correction factor too or they tuned too low.
not's build has a 90 degree bend, which has the effect of increases the port length because it doesn't flow as well as a straight port (at least that's my theory).
this size cab is also effectively the same as two full size front firing marty's (i'm not sure if that makes it a 'double-wide' or just a 'fat marty' :-)), so all the drivers that would work in that one will work in this one...stereo integrity ht18, uxl, 460ho, etc. as that question always seems to get asked.
also, there are a number of 15" drivers that would work in this enclosure as a quad set.
I like the approach to form factor as it keeps the cuts to a minimum (heck, home depot might even be able to make most of the cuts for you). having a simple plan, picture, and cut sheet for folks who don't want to try to design from scratch is awesome.
nice work 'not.
Reddig likes this.
Listen. It's All Good.
LTD02 is offline
post #59 of 238 Old 08-12-2014, 01:14 PM
BCRSS's Avatar
Quoted: 293 Post(s)
Liked: 227
I like this plan. But was wondering if the length would be increased to 96 and the depth to 23 and height to 23 and went sealed, would 4 - 18's work or would 4 - 15's be better?
All gone for now---->The Elusive 1099 (L/C/R)---6 DIY Volt 10 (surrounds 9.4)---SVS PB 12 Plus---SVS PC 12 Plus---2 DIY 18's sealed--2 Pico Wreckers (tapped horns)---AVR Denon 4311CI---Emotiva Xpa-3---Behringer Nu6000DSP & Nu3000DSP iNuke---TV Vizio 70---110" Motorized Screen---Epson 8350 Projector---Unraid Network Storage---Gateway SX 2370 HTPC with 120 SSD
BCRSS is online now
post #60 of 238 Old 08-12-2014, 04:01 PM
corndogggy's Avatar
Quoted: 157 Post(s)
Liked: 44
The beauty of this build is that all long edges are 48", so all the cuts except the bracing are just across the sheet of plywood.
Something that keeps bugging me is whether or not full sheets of plywood sitting at Lowes is perfect enough to use multiple edges on. I don't really know if it is or not, I would assume the edges would often have several imperfections and whatnot. I have these same drivers so I'm genuinely curious.
16hz , Dayton , llt , um18 , UM18-22
