Can you get away with just 1 othorn? - AVS Forum | Home Theater Discussions And Reviews
 2Likes
  • 1 Post By MBentz
  • 1 Post By Audio Geek
post #1 of 14 Old 08-12-2014, 03:26 AM - Thread Starter
Black Cat 13's Avatar
Quoted: 14 Post(s)
Liked: 0
now that my company has taken on a titan 39 bass horn to build... im looking to build an Othorn for my jam room. it's a man cave for loud guitars and metal! do i need 2 othorns or can i get away with just one? this is going to be a 2.1 system with waveguide and AE drivers. i'd like some input on these bass horns. best subs for this design... crossovers and listening impressions. thanx!
my room is 500 square ft. 18ft ceilings... all hardwood
Black Cat 13 is offline
post #2 of 14 Old 08-12-2014, 06:31 AM
chrapladm's Avatar
Quoted: 825 Post(s)
Liked: 286
One Othorn would be plenty. What is the T39 for?
chrapladm is online now
post #3 of 14 Old 08-12-2014, 10:39 AM - Thread Starter
Quoted: 14 Post(s)
Liked: 0
T39 is for tailgating at football games for charity. A company event. The t39 will be my first basshorn build
post #4 of 14 Old 08-12-2014, 05:40 PM
Audio Geek's Avatar
Quoted: 91 Post(s)
Liked: 42
Is this for just music or for home theater as well? Live music?
Audio Geek is offline
post #5 of 14 Old 08-12-2014, 07:48 PM
cookieattk's Avatar
Quoted: 111 Post(s)
Liked: 89
othorn outputs 120+ db thats really loud
cookieattk is offline
post #6 of 14 Old 08-12-2014, 08:15 PM
Bill Fitzmaurice's Avatar
Liked: 4632
If that's the case you don't need to go lower than 30Hz. Pro-touring concert sound subs don't.
Bill Fitzmaurice is online now
post #7 of 14 Old 08-13-2014, 07:42 AM
MBentz's Avatar
Quoted: 24 Post(s)
Liked: 43
I would sooner do one Othorn + potent amplifier, than two Othorns + weak sauce amplifiers.
Btw, touring sound systems are starting to dig lower these days. I would also never let status quo be the reason for picking any specification. Either your music digs low, or it doesn't...and the speakers you build should be based on your musical goals.
Nodscene likes this.
MBentz is offline
post #8 of 14 Old 08-13-2014, 09:31 AM
RickJames's Avatar
Quoted: 78 Post(s)
Liked: 65
Electric bass speakers aren't, and metal doesn't go real low anyway. I use Bills T48s for my real PA, they go as low as we need, and we play metal, so they go as low as a man cave for metal needs.
RickJames is online now
post #9 of 14 Old 08-13-2014, 09:47 AM
d_c
d_c's Avatar
Quoted: 824 Post(s)
Liked: 876
I also have two of the 30" t48. They are awesome for most music. I also have two Ghallarhorns which are awesome for everything I throw at it. Both types are incredibly loud. The t48 is much, much lighter and 1/4 the price, much easier to build than the Othorn or Ghorn. Id like to see the max spl comparison between the t48 and Othorn. I have not heard the Othorn, but I would choose a Gjallarhorn over Othorn (and did) just due to the type of music I listen to since the Ghorn goes deeper. Luke would be the best man to talk to about that though, as he has both. Any of the three I mentioned, when properly placed, is plenty for most sane people inside a room.
d_c is online now
post #10 of 14 Old 08-13-2014, 10:00 AM
lukeamdman's Avatar
Quoted: 1079 Post(s)
Liked: 1200
The Othorn is very strong down to 25hz, and just one will exceed 120db at 25hz without room gain. Over 30hz is more around 130db for just one.
Another sub I'm really impressed with is a front loaded horn called the F20, and it's MUCH cheaper to build than the Othorn. With a single 15" driver and only ~400 watts it really pounds. If you upgrade the driver you can feed it even more power. stormwind13 could give more details about that.
lukeamdman is offline
post #11 of 14 Old 08-13-2014, 10:03 AM
Audio Geek's Avatar
Quoted: 91 Post(s)
Liked: 42
+1
SonicSoundVW likes this.
post #12 of 14 Old 09-06-2014, 10:29 AM
Liked: 0
Saw this a while ago, just thought i would share :-)
http://www.prosoundweb.com/article/g...the_new_50_hz/
SonicSoundVW is offline
post #13 of 14 Old 10-05-2014, 08:00 PM
alethia123's Avatar
We did a party in this old coop house. Two othorns in one large living room type room.....Ill put it this way. The way this sub behaves, below 45hz the stuff on the walls and fixtures stop flapping and shaking like normal with average subs and start like....shifting things violently, the room becomes very "pressurized". I hope you have cool neighbors if you expect to jam often :-) sorry for my laymans term description. Im just a dude who loves speakers!
alethia123 is offline
post #14 of 14 Old 10-06-2014, 12:31 AM
sandydankness's Avatar
Quoted: 105 Post(s)
Liked: 74
I've been to Luke's house, trust me two othorns are just as loud as the front row of any show I've seen. One is overkill for 95% of the metalheads on earth, and goes lower than any drop c iv'e heard.
sandydankness is offline
