Just another sealed SI18HT build (and a hint of 1099's) - AVS Forum | Home Theater Discussions And Reviews
 6Likes
  • 4 Post By Anthony_Gomez
  • 1 Post By Fatshaft
  • 1 Post By Anthony_Gomez
Old 08-13-2014, 09:48 AM - Thread Starter
Anthony_Gomez's Avatar
Quoted: 61 Post(s)
Liked: 184
Nothing special here. Plenty of builds on AVS. I'm terrible at documenting and doing proper build threads, but I did have a few pics so thought I'd share.
starting to build some boxes. The had to set up the canopy to save me from the desert sun (garage had too much stuff to build inside :P)
add some bracing using cuttoff scrap
Sanded, routed all edges, bondo, sanded, routed and finally a couple coats of duratex. So dry and hot here, that I could start the second coat on by the time I finished with the first (very dry to the touch). Only took about 24 hours before it it cured hard.
that hole back there is for a speakon circular terminal.
I was lazy so I stuffed by shoving in three cheap pillows from walmart. Kept the cover on to contain the poly.
Subs in place. Don't mind the chaos of the equipment rack. I just shoved things in there as I was making room. I'm actually making a smaller rack. That one was when I had a ton of equipment to house.
These subs replace the tumult/PR in the corner. Also a beast. I tested the speakers on the Ender's Game rocket launch. I forgot to turn them down (they were +12 db hot) and shook the whole house. It was lovely :-D Wife a few rooms down had a sudden surprise :P
Oh look, a hint of 1099's! Just gluing in some scrap wood for screws to bite into a bit better. I didn't double baffle. Since this pic, I've added more foam (I just had the pink stuff sitting around so thought I'd use it).
XO's are almost all built. These will be finished tonight or tomorrow night. We'll see how ambitious I get. More pics later with everything in place.
That's all. As I said, nothing to crazy. Just a few pics. More to come tonight or tomorrow as the 1099's get finished.
ID:	210273   Click image for larger version
ID:	210281   Click image for larger version
ID:	210289   Click image for larger version
ID:	210297   Click image for larger version
ID:	210313   Click image for larger version
Fatshaft, LTD02, dtsdig and 1 others like this.
Anthony_Gomez is offline
Old 08-13-2014, 09:50 AM
Bass Enabler
Scott Simonian's Avatar
Quoted: 5285 Post(s)
Liked: 4173
Hell yeah! You make it look so easy, Anthony.
Great work.
Scott Simonian is online now
Old 08-13-2014, 11:46 AM
dtsdig's Avatar
Quoted: 828 Post(s)
Liked: 916
dtsdig is online now
Old 08-13-2014, 11:54 AM
chalugadp's Avatar
Quoted: 1672 Post(s)
Liked: 1505
Let us know how the1099 sound . Your opinion holds some weight.
chalugadp is offline
Old 08-13-2014, 11:57 AM - Thread Starter
Quoted: 61 Post(s)
Liked: 184
Will do! The 1099's won't touch the SQ of the Egos (Focal Utopia + Hiquphon with solid XO), but the Egos are way less sensitive and can't touch the dynamics or dispersion of the 1099s. Will be a fun comparison!
Old 08-13-2014, 02:53 PM
eydsamoht's Avatar
Quoted: 21 Post(s)
Are you going to do any wood trim on the 1099s, or leave them just duratex coated?
eydsamoht is offline
Old 08-13-2014, 02:58 PM - Thread Starter
Quoted: 61 Post(s)
Liked: 184
black. matching the subs (subs will serve as speaker stands). The wood trim sub has other matching wood trim speakers, but that was originally a stereo set and didn't need to visually blend in.
http://webfiles.uci.edu/algomez/Audio/Usher4.jpg
Old 08-13-2014, 04:06 PM
action_jackson's Avatar
Quoted: 321 Post(s)
Liked: 108
Nice job on the subs! I just got a pair of these in yesterday and plan to get started on them this weekend.
Looking forward to reading your impressions of the 1099s as well.
Epson Home Cinema 3010 Projector____Paradigm 9SE MK II Main LR
Yamaha RX-V667 AVR_______________Paradigm CC-270 V.3 Center
Emotiva UPA-5 Amplifier______________Dual Stereo Integrity 18" Infinite Baffle
Sony BDP-570 Blu Ray_______________DIY Sound Group Volt 10
action_jackson is online now
Old 08-14-2014, 10:32 AM - Thread Starter
Quoted: 61 Post(s)
Liked: 184
I forgot how much I hated building up large XOs. If I'm lucky, I'll finish wiring them up tonight....probably not that lucky.
Old 08-14-2014, 10:57 AM
Fatshaft's Avatar
Quoted: 590 Post(s)
Liked: 904
soon
blake18 likes this.
My Build Thread
Equipment Speakers:
3x 1099's for LCR duty
4x Fusion 8's for surround duty
8x subs: 4x FTW21's and 4x SI18's
Fatshaft is offline
Old 08-14-2014, 03:04 PM
zeus33's Avatar
Quoted: 1335 Post(s)
Liked: 996
Nice work!
zeus33 is online now
Old 08-14-2014, 11:10 PM
LTD02's Avatar
Quoted: 2341 Post(s)
Liked: 2577
nice work. they look right at home!
Listen. It's All Good.
LTD02 is offline
Old 08-18-2014, 07:28 AM - Thread Starter
Quoted: 61 Post(s)
Liked: 184
finally finished with the XOs. A long and tedious process. Double checking and I did catch one 2 for 3 ohm resister switch, but that's an easy fix.
Mounted them in the enclosures, along with more foam
wired up drivers, tested, then fastened all the drivers once I confirmed that everything sounded right.
Put the L/R into the main room using the SI's as stands. Intentionally oriented with CD on bottom of mids to bring the tweeter to the right listening height (you can see the old speakers still in scene on the walls). I need to do some moding to my TV stand to get the center to fit. I'm replacing it later on (along with the TV which will be wall mounted) so I don't worry about this part.
I need to run to work now, but will post up some listening impressions later on.
also need to sell off/trade old gear to fund a couple Volt-10 surrounds :-D
Name:	2014-08-16 08.41.24.jpg
ID:	217377   Click image for larger version
Name:	2014-08-16 08.58.32.jpg
ID:	217385   Click image for larger version
Old 08-18-2014, 02:40 PM - Thread Starter
Quoted: 61 Post(s)
Liked: 184
so I thought I'd leave some brief listening impressions of the L/R + subs setup.
In comparison, I was previously running the same subs with the small monitors you also see in the last photo.
I played through a wide ranged of music such as: Ellie Goulding, Ludovico Einaudi, Gnarls Barkley, Aerosmith, Annie Lennox and Lana Del Ray, and a bunch of pop club/dance music.
Also watched a couple movies: Ender's Game, Serenity. Then regular broadcast TV and streaming Louis CK.
First the pluses:
Dynamics are huge. I've built and listened to tons of inefficient speakers. I'm talking 84-86db 1w/m. While I can play them loud, then do run into compression. The 1099's are effortless in this regard. I can keep turning them up and they just get louder (as they should).
Sub integration is seamless. I'm running the classic 80 hz. Stereo subs, independently EQ'd also helps here.
Mid bass is strong, but not overwhelming.
Room control is better here than with the TMs, and that's expected vs MTMs which are superior here by design.
The sweet spot is wide enough that I didn't miss the center channel while watching movies. I wasn't sitting dead center either (2 person couch)
Vocals seemed pretty accurate. No standout squawk in the midrange.
The minuses
Size. DUH! These speakers are huge. But I'm ok with that. Wife is ok with that. I just still need to get used to these massive beasts in small room.
Harsher. The upper end can't touch the small 2-ways (Egos). The Egos were simply silky smooth with that "listen to all day long" non-fatiguing sound. Hiquphones were magical in this area. The 1099's are rougher here. I don't think it is a padding issue, just the difference between a CD and a small dome. It's not that the 1099s sound bad in the upper end, but rather that I've been spoiled for so long. I probably would't want the 1099s for a music only system without exploring how to tame the upper end (if even possible). ...but these are for HT and for that, I'm pretty impressed.
Old 08-24-2014, 07:48 AM - Thread Starter
Quoted: 61 Post(s)
Liked: 184
Finally got the center in place. Putting in a lot of listening time. Definitely enjoying these. Worth every penny (and then some).
Scott Simonian likes this.
Old 08-24-2014, 08:33 AM
Fatshaft's Avatar
Quoted: 590 Post(s)
Liked: 904
Looks very nice and congrats!
enjoy them now...
My Build Thread
Equipment Speakers:
Fatshaft is offline
Old 08-24-2014, 12:26 PM
sslv2pwned's Avatar
Quoted: 127 Post(s)
Liked: 33
I love it. I should try turning my 1099's upside-down
Sent from my Nexus 5 using Tapatalk
sslv2pwned is offline
Old 08-24-2014, 12:40 PM - Thread Starter
Quoted: 61 Post(s)
Liked: 184
it brought the CD to the right ear level :-D
Old 08-24-2014, 03:20 PM
Boxozaxu's Avatar
Quoted: 455 Post(s)
Liked: 295
Looks great Anthony! Nice job! ☺
Your post with the pluses and minuses was well done also. I enjoyed reading that.
Boxozaxu is offline
