newbie with inuke 6000dsp setup questions - AVS Forum | Home Theater Discussions And Reviews
 3Likes
post #1 of 39 Old 08-14-2014, 06:57 PM - Thread Starter
brendelac's Avatar
Quoted: 161 Post(s)
Liked: 91
I have a mini marty with UXL-18 driver and nu6000dsp. A lot of the inuke setup options are confusing and leave me scratching my head. Right now I'm trying to set the amp to bridge mode, but the only options I seem to have available are STEREO, DUAL, BIAMP1 and BIAMP2.
Please feel free to walk me through this like a 5 year old. The inuke is connected to a Denon 4311 if that is of any relevance. Thanks.
brendelac is offline
post #2 of 39 Old 08-14-2014, 08:50 PM
derrickdj1's Avatar
Quoted: 992 Post(s)
Liked: 731
You can't bridge the Nuke 6000. Stereo is the choice for two subs or one.
derrickdj1 is offline
post #3 of 39 Old 08-14-2014, 08:52 PM
chalugadp's Avatar
Quoted: 1674 Post(s)
Liked: 1532
Damn, sorry I forgot about that. What an idiot I am. Sorry dude. Pos 1+ and neg 1-.
chalugadp is offline
post #4 of 39 Old 08-14-2014, 09:06 PM - Thread Starter
brendelac's Avatar
Quoted: 161 Post(s)
Liked: 91
OK, adjusted the speakon connectors as above and have the amp set to stereo mode. I have both sub-outs connected to the inuke via RCA-to-XLR cables (do I only need to use one?) and am using the CH-A output to the mini-marty but no sound from the sub.
Also, connecting the Denon to the Behringer produces a hum from both main speakers that is quite audible when there is no other sound being output.
post #5 of 39 Old 08-14-2014, 09:26 PM
chalugadp's Avatar
Liked: 1532
Only need one RCA to xlr. Your only using one channel to power one sub.
post #6 of 39 Old 08-14-2014, 09:31 PM - Thread Starter
brendelac's Avatar
Quoted: 161 Post(s)
Liked: 91
One RCA/XLR removed. Any idea why I am getting zero output?
post #7 of 39 Old 08-14-2014, 09:44 PM
chalugadp's Avatar
Liked: 1532
Disconnect sub at speakon connector on sub. Then put a bass heavy song on. Disconnect all speakers and turn volume on avr up to -10. Then watch clipping lights. Do they light up (1,2,3, or even red)
post #8 of 39 Old 08-14-2014, 09:47 PM
doc5150's Avatar
Quoted: 43 Post(s)
Liked: 34
If your using the software on laptop or by using amp...look and see if your getting input signal...if you changed modes make sure you save settings for it to apply, turn off crossover for now, can set it later
doc5150 is offline
post #9 of 39 Old 08-14-2014, 09:51 PM - Thread Starter
brendelac's Avatar
Quoted: 161 Post(s)
Liked: 91
One clipping light flashes. This would indicate that the problem is between the amp and woofer, yes?
post #10 of 39 Old 08-14-2014, 09:52 PM
chalugadp's Avatar
Liked: 1532
Where are the gains set ?
You should get two to three lights on bass song at -10.
post #11 of 39 Old 08-14-2014, 09:57 PM
doc5150's Avatar
Quoted: 43 Post(s)
Liked: 34
very possible, make sure your speakon cable is +1 and -1 , if you have a dvm check your cable for good connection
I am using a 4310ci and it will clip that amp easily
doc5150 is offline
post #12 of 39 Old 08-14-2014, 09:59 PM - Thread Starter
brendelac's Avatar
Quoted: 161 Post(s)
Liked: 91
I had the channel A gain all the way up, playing some Daft Punk. My AVR still has audyssey and sub eq settings being used so that may have the output level decreased. I think it was at -4 if memory serves me correctly.
Got 2 and 3 clipping lights when I went above 0 on the AVR.
post #13 of 39 Old 08-14-2014, 10:07 PM
chalugadp's Avatar
Liked: 1532
Ok I'm guessing you have a problem with speakon at sub. Did you solder wires on or crimp. Check them.
post #14 of 39 Old 08-14-2014, 10:09 PM
doc5150's Avatar
Quoted: 43 Post(s)
Liked: 34
well you have an output issue then, either sub cable wired wrong or something in the amp settings..this amp wont do parallel unless is biamped so chan 1 input and output has to be used
doc5150 is offline
post #15 of 39 Old 08-14-2014, 10:17 PM
chalugadp's Avatar
Liked: 1532
As frustrating as it is we've all been there. Will figure it out.
post #16 of 39 Old 08-14-2014, 10:20 PM
LTD02's Avatar
Quoted: 2553 Post(s)
Liked: 2888
fyi, the amber lights are just level indicators. the red one indicates clipping.
I'd turn off audyssey and eq while sorting things out and manually set the sub level output to +0 (to start).
as was mentioned, to rule out a wiring problem driver-side, if you have a multimeter, check the resistance across pins 1+ and 1- (which run all the way through the driver). should read somewhere in the ballpark of 3.2-3.5 ohms or so.
Listen. It's All Good.
LTD02 is offline
post #17 of 39 Old 08-14-2014, 10:23 PM - Thread Starter
brendelac's Avatar
Quoted: 161 Post(s)
Liked: 91
Are you referring to the cabinet or driver? The driver has the spring tabs with the black electrical tape wire going to negative and the other to positive. The cabinet still has the connections that were in place when I bought from you.
post #18 of 39 Old 08-14-2014, 10:26 PM
chalugadp's Avatar
Liked: 1532
The four pole speakon on outside of cab. Remove small screws and pull it out. I had it wired for bridge mode so if you didn't change it then there's your problem. It was bridge mode cuz my inuke3000dsp .
LTD02 likes this.
post #19 of 39 Old 08-14-2014, 10:27 PM
doc5150's Avatar
Quoted: 43 Post(s)
Liked: 34
Make sure your speakon connectors are wired correctly then.
doc5150 is offline
post #20 of 39 Old 08-14-2014, 10:29 PM - Thread Starter
brendelac's Avatar
Quoted: 161 Post(s)
Liked: 91
That must be it. See, all this could have been avoided if you sold me your 3000
Will update in a bit...
post #21 of 39 Old 08-14-2014, 10:32 PM
chalugadp's Avatar
Liked: 1532
That's it. I think I sniffed a lot of oil today and my brain is scrambled
Your going to love the bass coming.
post #22 of 39 Old 08-14-2014, 10:48 PM - Thread Starter
brendelac's Avatar
Quoted: 161 Post(s)
Liked: 91
Bingo!
Only problem now is the wire to speakon connection in the cabinet. The blades are so close together that the spade connectors on each wire will be touching each other.
post #23 of 39 Old 08-14-2014, 10:55 PM
chalugadp's Avatar
Liked: 1532
Can't have em touching obviously. Bridged they were on opposite sides. Smaller spades or solder on.
post #24 of 39 Old 08-14-2014, 11:01 PM - Thread Starter
brendelac's Avatar
Quoted: 161 Post(s)
Liked: 91
Ya, it looks like the ends on the wires are oversized for the neutrik blades. I'll make a run to Ukranian Tire tomorrow and get the correct size.
This will be the third time the driver has been screwed into the cabinet. In hindsight there was no reason to remove it tonight, but I did. I thought maybe I forgot to wire the driver. Anyways, does having the extra holes in the mounting surface affect performance at all?
post #25 of 39 Old 08-14-2014, 11:10 PM
FriscoDTM's Avatar
Quoted: 306 Post(s)
Liked: 278
disconnect your cable tv coax and see if the hum goes away - if so, you have a ground loop from the cable wire
Display 2013 Samsung 75" UN75F6300 TV Media Xbox One S, Dune Solo, QNAP TS-453A NAS
Pre/Amp Marantz 7702mk2 Processor + DIY 11ch Icepower 50ASX2BTL Monoblock Amp Amp Build Link
7.2.4 Speakers DIYSG 1099s (LCR), Volt 10LX (SL, SR), Volt 8LX (BL, BR), Volt 10LX (TF, TR) Volt Build Link
Subs Dual 19Hz DIY Ported UXL-18s + FP14k Amp + MiniDSP 2x4 Balanced Tactile Crowsons + iNuke 6000DSP
FriscoDTM is offline
post #26 of 39 Old 08-14-2014, 11:20 PM
chalugadp's Avatar
Liked: 1532
No. Just rotate so holes are fresh. Is there gasket in there (can't remember ) if not put one in.
post #27 of 39 Old 08-14-2014, 11:26 PM - Thread Starter
brendelac's Avatar
Quoted: 161 Post(s)
Liked: 91
You gave me a fresh one which I haven't used yet. I will use it tomorrow, hopefully the last time I will be fastening the driver to the cabinet.
Thanks, I will check in the morning - just heading for bed. It's only a problem with the inuke connected. Could it be that is powered through the same surge protector as my AVR?
post #28 of 39 Old 08-15-2014, 10:47 AM
BassThatHz's Avatar
Quoted: 2383 Post(s)
Liked: 2155
Clipping the inputs before the outputs is always bad.
The outputs tell you how many watts are going to the speaker.
In 4-ohms it would be:
0db 3000watts
-3db 1500watts
-6db 750watts
-9db 375watts
-12db 188watts
-15db 90watts
<18db <45watts
BassThatHz is online now
post #29 of 39 Old 08-15-2014, 12:32 PM - Thread Starter
brendelac's Avatar
Quoted: 161 Post(s)
Liked: 91
So ya, this thing is pretty potent. It is on the boomy side, but I haven't touched the DSP yet and it is currently corner mounted which probably contributes to the boominess. I'm already noticing the trade-off though of having two smaller subs VS one grand-daddy of a sub
The coaxial cable was the cause of the hum. I'm curious why it has never been an issue until the inuke was connected and what is the remedy so that I can keep the coaxial cable connected while being drowned in bass.
post #30 of 39 Old 08-15-2014, 12:45 PM
chalugadp's Avatar
Liked: 1532
I had it almost 2' from corner . It wasn't boomy. You will get it dialed in.
