Emergency.....No output from sub - AVS Forum | Home Theater Discussions And Reviews
 2Likes
  • 1 Post By BassThatHz
  • 1 Post By PM-Performance
post #1 of 17 Old 08-16-2014, 12:06 PM - Thread Starter
chadcj7's Avatar
Quoted: 58 Post(s)
I just finished my martycube and I have no output at all
I am not sure if I configured my amp incorrect or what. It is a 3000dsp in bridged mode. I have a xlr to rya adapter to the back of my denon 3313 and then a speakon cable from sub to 3000dsp.
I would appreciate any help that you can give me
chadcj7 is offline
post #2 of 17 Old 08-16-2014, 12:15 PM
chalugadp's Avatar
Quoted: 1674 Post(s)
Liked: 1532
Bridge mode being red 1+ and black 2+. You have speakon connector and cables with that wiring ?
Gains are turned up all the way, you picked bridge mode on inuke as well.
chalugadp is offline
post #3 of 17 Old 08-16-2014, 12:36 PM
wvu80's Avatar
Quoted: 329 Post(s)
Liked: 293
Did you make your own Speakon cables? I have seen posts from others that have made theirs, and had similar problems.
Can you post exactly what wires you connected with what terminals? I won't be able to troubleshoot that, but there are others here who will.
wvu80 is offline
post #4 of 17 Old 08-16-2014, 12:37 PM - Thread Starter
chadcj7's Avatar
Quoted: 58 Post(s)
yes. I just doubled checked them and still nothing
I have attached pics of what my sub wiring looks like just to be safe
chadcj7 is offline
post #5 of 17 Old 08-16-2014, 12:38 PM - Thread Starter
chadcj7's Avatar
Quoted: 58 Post(s)
I did not make my speakon cables. I purchased it
chadcj7 is offline
post #6 of 17 Old 08-16-2014, 12:52 PM
chalugadp's Avatar
Liked: 1532
They come in stereo mode. You changed them to bridge mode ?
post #7 of 17 Old 08-16-2014, 12:55 PM
doc5150's Avatar
Quoted: 43 Post(s)
Liked: 34
Take it out of bridged mode does it work? if so then you need to rewire the speakon cable like chalugadp mentioned.
doc5150 is offline
post #8 of 17 Old 08-16-2014, 12:56 PM
BassThatHz's Avatar
Quoted: 2388 Post(s)
Liked: 2162
This is like the 10th thread on this topic, 99% of the time they have the speakons miss-wired or wrong inputs and outputs connections, or wrong amp mode, or insufficient gain/sensitivity. Or a combination of all of them.
It all has to be perfect or it wont work.
Only 1% of the time is it a defective driver or amp or avr.
It is impossible to see how it is wired by that picture, you need two closeups of the terminals,
and also one of each side of the speakon wire, and one of the speakon binding inside the box.
You should also post pictures of your AVR volume level and subwoofer output gain, and screenshots of all of the pages of the inukeDSP settings.
Then we will know...
Quickett likes this.
BassThatHz is offline
post #9 of 17 Old 08-16-2014, 12:56 PM - Thread Starter
chadcj7's Avatar
Quoted: 58 Post(s)
the actual speakon cable comes in stereo mode? How do I change it to bridge mode?
chadcj7 is offline
post #10 of 17 Old 08-16-2014, 01:02 PM
chalugadp's Avatar
Liked: 1532
YouTube it.
post #11 of 17 Old 08-16-2014, 01:08 PM
PM-Performance's Avatar
Quoted: 255 Post(s)
Liked: 146
Bridge is +1 and +2
Stereo is -1 and +1 on speak on terminals
If those voicecoils are in series they look ok, if you intended parallel then looks like you are missing one of the wires for the other coil
Klipsch RF-82|RC-62|RS-52|RB-51, 2 Ultimax 18's in Marty Cabs Powered by Inuke 6000DSP|
Denon AVR-X4000|Oppo BDP-103|Epson 5020UB with Elite SableFrame 110"|
4 Aura Bass Shakers powered by Dayton PSA-250|4 Seatcraft 5131 seats
PM-Performance is offline
post #12 of 17 Old 08-16-2014, 01:23 PM
mtg90's Avatar
Quoted: 496 Post(s)
Liked: 974
If you have a speakon plate on your sub assuming you did not solder the wires to the terminals (or even if so) it may be easier to swap the - wire from the 1- terminal to the 2+ terminal then it would be to disassemble the speakon connectors on the cable and rewire those. However that would only work if the speakon cable you purchased is a 4 conductor cable.
Edit added picture to illustrate:
mtg90 is offline
post #13 of 17 Old 08-16-2014, 01:30 PM - Thread Starter
chadcj7's Avatar
Quoted: 58 Post(s)
Thank you everyone. It was my speakon cable that was incorrect. In all of my reading I never remember seeing that. Well it is working now and I will say that I have big smile on my face. I am only getting one light on the amp with the gain all the way up. If you can point me in any direction or guide on how to fix this I will appreciate it
Once again I love this forum and everyone's quick responses!!!!! Also I think the addiction has hit!!!
I will post more pics of the build in another thread
chadcj7 is offline
post #14 of 17 Old 08-16-2014, 01:41 PM
chalugadp's Avatar
Liked: 1532
I'm going to make a FAQ for marty subs later today it will cover foam connectors cable wiring ect.
post #15 of 17 Old 08-16-2014, 03:49 PM
BassThatHz's Avatar
Liked: 2162
One light is like ~300watts or less
Two lights is like ~750watts
Three lights is like ~1500watts
Just under clipping is full power.
With all the speakers and subs disconnected, you should be able to reach just below the clipping-lights with a heavy bass song/movie with the AVR at around 0db or a bit higher.
(This is assuming the sub can handle that much power and you want/need it that loud.)
If not, then you probably need an RCA to XLR converter box, such as a Cleanbox Pro.
Just remember to lower the volume before reconnecting the speakers and subs (with the electronics turned off), otherwise loud thump and house fire.
post #16 of 17 Old 08-16-2014, 03:59 PM
Bassment's Avatar
Quoted: 946 Post(s)
Liked: 379
I've never heard of a LFE pre-out ever that can not do 0.7 volts to power an inuke to max. Every single time it's inuke gain is too low or LFE trim is too low
Bassment is offline
post #17 of 17 Old 08-16-2014, 04:08 PM
Quoted: 255 Post(s)
Liked: 146
Follow chugalupdp's inuke gain post a week or two ago.
I followed this and worked great for me.
chalugadp likes this.
