Cutting a perfect 90° - AVS Forum | Home Theater Discussions And Reviews
post #1 of 12 Old 08-16-2014, 03:37 PM - Thread Starter
AVI20's Avatar
What do all you guys use/suggest on cutting a perfect 90° angle?
I'm looking to upgrade and need some suggestions! Thanks!
AVI20 is offline
post #2 of 12 Old 08-16-2014, 03:55 PM
Bassment's Avatar
Quoted: 946 Post(s)
Liked: 379
track saw, table saw, straight edge guide on a router or jigsaw, clamp on straight edge and circular saw
Bassment is offline
post #3 of 12 Old 08-16-2014, 03:58 PM
kevings's Avatar
Quoted: 299 Post(s)
Liked: 466
Id suggest a you use a carpenters square, and draw the cut lines on your material. From there i'd use a circular saw or jig saw with a clamp acting as an edge guide. A table saw would also work. And finally if you have a real steady hand and some free time, a powerful magnifying glass combined with the power of the sun : )
kevings is offline
post #4 of 12 Old 08-16-2014, 04:06 PM
Ivan Beaver's Avatar
Quoted: 16 Post(s)
Liked: 59
What kind of 90° are you talking about?
Is it on the edge or on the dimension of a piece?
Lets say you want a piece that is 24" x16"x3/4" thick. Is the 90° on the 3/4" side or the 24x16 side?
You use completely different methods-depending on the cut.
Danley Sound Labs
Physics-not fads
Ivan Beaver is offline
post #5 of 12 Old 08-16-2014, 04:10 PM - Thread Starter
AVI20's Avatar
Both! Haha! I know a jointer will do the 3/4 inch side, but I think I'm more concerned about "24x16" cuts.
AVI20 is offline
post #6 of 12 Old 08-16-2014, 04:12 PM - Thread Starter
AVI20's Avatar
Haha, I don't have that much time!! But the circular saw I have, maybe it's time to quit eyeballing it and buy a edge guide!
AVI20 is offline
post #7 of 12 Old 08-16-2014, 04:24 PM - Thread Starter
AVI20's Avatar
What guides do you use/like?
AVI20 is offline
post #8 of 12 Old 08-17-2014, 06:41 AM
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2698
Table saw
Mfusick is offline
post #9 of 12 Old 08-17-2014, 08:18 AM
Bburnett's Avatar
Quoted: 42 Post(s)
I noticed in your coffee table thread there was an image of a nice, clamp on straight edge. Do you mind me asking where you bought that? I'd like to pick one up.
Bburnett is offline
post #10 of 12 Old 08-17-2014, 09:13 AM
kevings's Avatar
Quoted: 299 Post(s)
Liked: 466
I use Pittsburg clamps from harborfreight.Com
Here:
Pittsburgh - Item#66581
Your actually in luck because the 50 inch model is on sale for 19.99.
Having a 36 inch model might also be a good idea, for added versatility.
I'm very happy with them. They are inexpensive and get the job done.
kevings is offline
post #11 of 12 Old 08-17-2014, 09:17 AM
Bburnett's Avatar
Quoted: 42 Post(s)
Here:
Thanks very much. I will swing by HF.
BTW - I also live in Anaheim.
Bburnett is offline
post #12 of 12 Old 08-17-2014, 09:52 AM
kevings's Avatar
Quoted: 299 Post(s)
Liked: 466
No prob / its good to have a neighbor on avs
kevings is offline
