Who uses this spiral router bit? - AVS Forum | Home Theater Discussions And Reviews
 4Likes
  • 1 Post By rhodesj
  • 1 Post By Mike Garrett
  • 1 Post By SeekingNirvana
  • 1 Post By JohnDean
post #1 of 22 Old 08-20-2014, 04:25 PM - Thread Starter
Black Cat 13's Avatar
Quoted: 14 Post(s)
Liked: 0
ive been told to get a 1/2 spiral bit but all i can find is 1/4. is this bit good for cutting circles? i have a jasper jig pro 200 and 3hp porter cable router
http://www.homedepot.com/p/Diablo-1-...1&str_nbr=1777
Black Cat 13 is offline
post #2 of 22 Old 08-20-2014, 04:30 PM
randyc1's Avatar
Quoted: 238 Post(s)
Liked: 40
I even prefer the 1/4 " !! ..but I also prefer a (Down-Spiral) , keeps dust in groove and helps cutout stay put till cutout is finished.
randyc1 is offline
post #3 of 22 Old 08-20-2014, 04:36 PM - Thread Starter
Quoted: 14 Post(s)
Liked: 0
wow. your the first to ever recommend a downward cut. are they they same price? im stoked on my first bass horn build. im going with the keyestone design
File Type: pdf Keystone_sub_dwg_corrections_2_Hornresp (1).pdf (17.0 KB, 37 views)
post #4 of 22 Old 08-20-2014, 05:09 PM
Mike Garrett's Avatar
Quoted: 5564 Post(s)
Liked: 3542
It probably depends on your router. I have a 3.5 hp router and I use a 1/2" spiral up-cut. Goes through MDF and plywood like butter. In 3/4" MDF I could cut a circle with one pass, but I do use two passes.
mjgarrett100@gmail.com
Mike Garrett is online now
post #5 of 22 Old 08-20-2014, 05:44 PM
Bill Fitzmaurice's Avatar
Liked: 4630
You must be looking in the wrong places. A 1/4 bit will heat up very quickly and give you burned cuts. Whiteside Router Bits is a good source.
Bill Fitzmaurice is online now
post #6 of 22 Old 08-20-2014, 06:00 PM
randyc1's Avatar
Quoted: 238 Post(s)
Liked: 40
Maybe it is easier ,.. never tried the 1/2" , I just thought the 1/4" would be a little easier to push through.
randyc1 is offline
post #7 of 22 Old 08-20-2014, 06:12 PM - Thread Starter
Quoted: 14 Post(s)
Liked: 0
you provide a link for 1/2 spiral upcut. thanx
post #8 of 22 Old 08-20-2014, 06:12 PM - Thread Starter
Quoted: 14 Post(s)
Liked: 0
post #9 of 22 Old 08-20-2014, 06:23 PM
rhodesj's Avatar
Quoted: 852 Post(s)
Liked: 471
The Jasper 240 jig I have is calibrated for 1/4" bits. If you used a 1/2" bit you would need to adjust the cut diameter on the jig to compensate.
Most recommendations I've seen are to use an up-cut bit for most work, but a down-cut bit for anything veneered, to prevent tearout of the veneer.
andyc56 likes this.
rhodesj is offline
post #10 of 22 Old 08-20-2014, 06:29 PM
BrickTop's Avatar
Quoted: 47 Post(s)
Liked: 31
Agreed...the Jasper Jig definitely calls for the 1/4" bit.
BrickTop is offline
post #11 of 22 Old 08-20-2014, 06:41 PM
Liked: 3542
I use a Whiteside RU5100. It has 1" of cutting length. You can buy at several places.
Black Cat 13 likes this.
post #12 of 22 Old 08-21-2014, 12:19 AM - Thread Starter
Quoted: 14 Post(s)
Liked: 0
DAMN... i dont think my router is compatible with the jasper jig 200 pro. i have porter cable 8931 plunge base. kinda hard to determine what is compatible on the jasper website. i did see this... wonder if i fit in the category PC8902/8931
post #13 of 22 Old 08-21-2014, 08:42 AM
SeekingNirvana's Avatar
Quoted: 233 Post(s)
Liked: 123
You want to use a "up spiral" bit, so that it removes the material from the cut. If you use a down spiral it will leave all the dust in the cut and make it wear faster, since you will recutting everything you already did.
A 1/4" bit will work fine for what you need. I've cut over 30 holes with mine and there is no signs of hear stress, burned cuts, or wear. It looks like it's new, and it's still as sharp as it was when I got it. I did my cuts in 3/4" MDF with three passes. Yes I could have done it in one, but I just cut a little at a time and I let the tool do the work, don't force it. Plus the jasper jig is set up for a 1/4" bit.
If your router doesn't line up with the jasper hole patterns, just drill your own holes. There is screws on your router base plate that you can use as a template.
SeekingNirvana is offline
post #14 of 22 Old 08-21-2014, 10:11 AM
JohnDean's Avatar
Quoted: 430 Post(s)
Liked: 183
You guys with over 3hp handheld routers are bigger men than I. I've done it and find it's hard to hang onto if it hits a blemish.
Whiteside is always my first stop for router bits. They make great bits and their customer service is second to none.
JohnDean is offline
post #15 of 22 Old 08-21-2014, 02:26 PM
lilmike's Avatar
Quoted: 64 Post(s)
Liked: 160
Got a local Rockler or Woodcraft store? They typically have Whiteside bits on the rack.
Like a lot of the other folks here, I use Whiteside's 1/4" solid carbide upcut spiral bits with my Jasper Jig, I made a LOT of speakers before I dulled the first one (most of my work is not MDF though). Cutting through a drywall screw is what did it in. I cut enough circles to where I have a router dedicated to the Jasper Jig.
You can also wave the bits in from Amazon.
lilmike is offline
post #16 of 22 Old 08-21-2014, 02:47 PM
JohnDean's Avatar
Quoted: 430 Post(s)
Liked: 183
I've had really good experiences buying my bits from Hartville Tool. Fast free shipping and if you spend $50 you get free furniture plans.
JohnDean is offline
post #17 of 22 Old 08-21-2014, 08:00 PM
Sibuna's Avatar
Quoted: 373 Post(s)
Liked: 429
http://www.mlcswoodworking.com/shops...ghlight=up+cut
Sibuna is offline
post #18 of 22 Old 08-22-2014, 02:38 AM - Thread Starter
Quoted: 14 Post(s)
Liked: 0
ok... i bought a fued diablo 1/4 upcut spiral bit at home depot. this was just for testing. very impressed! it took 2 passes to cut through 3/4" baltic birch ply. zero burns and a perfect circle. my only complaint is with the jasper jig. it tends to lift a little during the cutting. i couldnt find the rods that come with the jasper jig pro 200. used the drill bit to hold the jig down. any suggestions on keep the jig down during cutting? over-all... this rig is very solid. very impressed with the porter cable router. very smooth!
post #19 of 22 Old 08-22-2014, 10:42 PM - Thread Starter
Quoted: 14 Post(s)
Liked: 0
anybody?
post #20 of 22 Old 08-23-2014, 10:22 AM
Quoted: 233 Post(s)
Liked: 123
anybody?
Try using a larger diameter bit, one that fits snugly into the jasper jig. The little piece that comes with the jig fits pretty tight.
post #21 of 22 Old 08-23-2014, 05:30 PM
Face2's Avatar
Quoted: 334 Post(s)
Liked: 201
Face2 is offline
post #22 of 22 Old 08-24-2014, 08:46 AM
Thomas-W's Avatar
Quoted: 20 Post(s)
3/8" per pass is a little much. If you want the bit to last take 1/4"or less per pass
My guess is it's riding up on the pin because you're pulling the router too fast.
They're 1/8" stainless steel machinist pins. You can buy lengths of 1/8" SS rod and make your own pins. Look on Amazon or eBay for the rods
Thomas-W is offline
