Toe in on a sub? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 8 Old 08-21-2014, 08:20 AM - Thread Starter
MikeE715's Avatar
Toe in on a sub?
Hey all. Im going to take the plunge. Idea is to mate the Tempest to a Martycube. I would like to sexy it up a bit and add some curves. Question is what would be the effect of toeing in the sub. I think it would look better to have everything on the same plane.
MikeE715 is offline
post #2 of 8 Old 08-21-2014, 08:31 AM
Audio Geek's Avatar
Quoted: 91 Post(s)
Liked: 42
The bass frequencies are omnidirectional so it wouldn't make a noticeable difference.
Audio Geek is offline
post #3 of 8 Old 08-21-2014, 10:17 AM
Bassment's Avatar
Quoted: 904 Post(s)
Liked: 364
The only issue with putting your subs with your mains is that the placement of the sub might not be ideal. But if you don't have multiple places you can place your sub, then it doesn't matter any ways.
The direction the sub faces doesn't matter as it is omnidirectional.
Bassment is offline
post #4 of 8 Old 08-21-2014, 11:35 AM - Thread Starter
MikeE715's Avatar
Cool unfortunately I don't have a lot of places I can place them so I'll have to live with it.
MikeE715 is offline
post #5 of 8 Old 08-21-2014, 12:07 PM
kevings's Avatar
Quoted: 293 Post(s)
Liked: 455
kevings is online now
post #6 of 8 Old 08-21-2014, 10:12 PM
BassThatHz's Avatar
Quoted: 2031 Post(s)
Liked: 1547
In my experience, the higher frequencies will be slightly quieter if you put the cone against a wall, but forward facing it can be off by as much as +-40 degrees at it won't have one bit of difference.
Once you approach 40 to 90 and then 90 to 180 degrees, that's when the higher frequencies become reduced slightly... not sure how many db's but I'd guess it's at least 3db per cone.
Below 50hz it doesn't seem to make one bit of difference it's free boundary-gain.
BassThatHz is online now
post #7 of 8 Old 08-21-2014, 10:14 PM
Archaea's Avatar
Quoted: 2840 Post(s)
Liked: 2420
In my measuring experience ported sub facing seems to make a wee bit of difference, but you'll need to have a measuring tool to see if it's better or worse. Omnimic or REW for instance.
It is a measurable difference with my ported caps for instance on the direction they are facing, especially in the higher 'midbass', kick drum frequencies. A few dB here or there.
Archaea is online now
post #8 of 8 Old 08-21-2014, 11:16 PM
LTD02's Avatar
Quoted: 2340 Post(s)
Liked: 2574
that could also be from not just the direction of the sub, but the distance as well.
Listen. It's All Good.
LTD02 is online now
