How are they for music?
I have 4648th cabs( 2 x 2226h) and 1 2446h compression driver for LCR. Due to my moving in a few months I never had a chance to set them up.
I know they are going to do extremely well for ht but how about music?
The 2446 compression driver from JBL is an excellent performer, only problem is the lack of a top end. You could always add a super tweeter, as was mentioned, but, that would add to crossover complexities. My advise, if you can afford it, would be to add some Be diaphragms from TruXtnt. That would get rid of the breakup at the higher frequencies and would likely give you one of the best sounding compression drivers that you will ever hear! Couple that to duel 2226's per speaker and you will be in heaven!
Only drawback is their price, which I believe is advertised at $600 or so each, BUT, you can probably get them down to $300-ish each if you look around.
If you want to really rock that joint, you've got the right gear. If all you want to do is hear the delicate upper harmonics of those violins from your Diana Krall SACD's then maybe keep looking.
Is there a big difference between the active JBL and the passive ?
Related Threads
AVS Forum
34M posts
1.5M members
Since 1999
