The Undertaker- Two Nearfield SI HST-18's - Page 4 - AVS Forum | Home Theater Discussions And Reviews
 130Likes
Old 08-29-2014, 12:17 PM
Bass Enabler
Scott Simonian's Avatar
Quoted: 5284 Post(s)
Liked: 4168
Yes that was exactly what I was thinking but Brandon spec'd a longer overall enclosure than what Kevin built.
But yes that's pretty much what I was thinking but with two PR's one on each side dual-opposed to cancel out all that inertia.
Scott Simonian is offline
Old 08-29-2014, 01:53 PM - Thread Starter
Point Source
beastaudio's Avatar
Quoted: 3496 Post(s)
Liked: 2826
I was actually thinking something more like this:
beastaudio is offline
Old 08-29-2014, 02:18 PM
Bass Enabler
Liked: 4168
I would not recommend this orientation nor would I recommend pairing only two PR's with two HST18's.
Would there be an additional pair of PR's on the other end? It could work if you had another two PR's on the opposite side.
Old 08-29-2014, 02:25 PM
ambesolman's Avatar
Quoted: 1076 Post(s)
Liked: 895
Originally Posted by Electrodynamic View Post
I also have 24" PR's available with over 5" of stroke capability.
He be strokin!
Sent using Tapatalk since the mobile version is still
Bombelman likes this.
ambesolman is offline
Old 08-29-2014, 03:06 PM - Thread Starter
Point Source
beastaudio's Avatar
Liked: 2826
Yes, haha forgive my absolute lack of MS paint skills. I meant to label that as 2 PR's on each side for a total of 4 PR's with the HST's front firing. My bad
Old 08-29-2014, 03:10 PM
Bass Enabler
Liked: 4168
Ah okay. So yeah that might work out.
What kind of volume are we working with here? I'll do some sims for you.
Old 08-29-2014, 03:16 PM - Thread Starter
Point Source
beastaudio's Avatar
Liked: 2826
Frikking huge if I went that route. But i need to measure here in a little while to see. anywhere between 18 cuft to 25cuft if I spanned the back of the couch, went 18 inches deep, and made it a height of 40 inches to fit the PR's stacked on the sides. It aint looking too good to get it much smaller than 18 cuft going this route.
Old 08-29-2014, 03:26 PM
Bass Enabler
Liked: 4168
Hmm yeah. 18cuft is gonna be pretty large. It will work though. A quick sim with the PR18-2100 nets a ~14hz tune but the PR's run out of excursion with 1,500w input. Lot's of Xmax on the HST18's left over which isn't necessarily a bad thing.
Old 08-29-2014, 03:28 PM
Anthony_Gomez's Avatar
Quoted: 61 Post(s)
Liked: 184
Can we get an SI8HST with PRs? :P you know...sunfire jr? :-D
Anthony_Gomez is offline
Old 08-29-2014, 03:30 PM
Bass Enabler
Liked: 4168
Little 8" HST?
Small driver, all surround. No surface area!
Old 08-29-2014, 03:33 PM - Thread Starter
Point Source
beastaudio's Avatar
Liked: 2826
haha. Yea this is a 10" sundown. Mean lookin little guy
Old 08-29-2014, 03:57 PM
Reefdvr27's Avatar
Quoted: 1564 Post(s)
Liked: 1038
I believe I am ready for my first sub build !!
Reefdvr27 is offline
Old 08-29-2014, 04:00 PM - Thread Starter
Point Source
beastaudio's Avatar
Liked: 2826
What's that Dave?
Old 08-29-2014, 04:30 PM
Reefdvr27's Avatar
Liked: 1038
What's that Dave?
Looking to do something to pair up with the 215's up front.
Old 08-29-2014, 06:17 PM
chrapladm's Avatar
Quoted: 824 Post(s)
Liked: 286
Funny I am going to be building a Sunfire like sub in a few months. I have a lot of scrap wood and thought it would be nice to have a small subwoofer for shiz and giggles. I was looking at the either a SA-8V2 and custom 8 PR's or possibly going to a 10 version. Although I would probably stick with the SA line up because it is easier to get PR's with more Xmax than a X series. I just wish I could find a small plate amp for it. No worries though as an Inuke 1000 should be fine on the little sub. (8 version)
That being said I dont know what kind of limitations you have Beast but what about 24 PR's for your setup?
Possibly get away with a pair of them with a pair of HST. I have not simulated this but just a thought.
chrapladm is offline
Old 08-31-2014, 04:14 PM - Thread Starter
Point Source
beastaudio's Avatar
Liked: 2826
24" PR's would have to go in the same space, on the sides of the box, so I could do that and get away with 2, but that makes the box even wider, which is not going to work. Honestly I am almost dead set on just another sealed near field for the two HST's. I know, not all that special, but it is really all that will fit in the space, without tossing the rear row and riser so far back into the room that there is literally no room to walk (Or throw darts) in the rear of the theater Gotta make a little sacrifice here as the PR build is something I would REALLY like to do, just not in the cards.
Old 08-31-2014, 04:56 PM
chrapladm's Avatar
Quoted: 824 Post(s)
Liked: 286
When you dont live in simulation land sealed is terrific. When your busy only looking at simulations it seems like sealed is such a waste. So I think you will be just fine either way.
Old 08-31-2014, 11:40 PM
Mike Garrett's Avatar
Quoted: 5568 Post(s)
Liked: 3549
Near field sealed works well.
mjgarrett100@gmail.com
Mike Garrett is offline
Old 09-02-2014, 12:43 PM
Reefdvr27's Avatar
Liked: 1038
I agree Andrews near field sealed was allot of fun.
Old 09-02-2014, 12:44 PM
Bass Enabler
Liked: 4168
But what about nearfield LLT?
*points at sig*
Going to do it. That's right.
Old 09-02-2014, 01:18 PM - Thread Starter
Point Source
beastaudio's Avatar
Liked: 2826
Show off
Old 09-02-2014, 01:55 PM
Quoted: 61 Post(s)
Liked: 184
I don't need a sub. I have plenty. Heck, I'm shipping off an old one now. ..but I have such a strong urge to do this too! Heck, if there was a good long through 6" and PR's and tiny plate amp, I'd probably be pushed over the edge of sanity :-D
Old 09-13-2014, 07:57 PM - Thread Starter
Point Source
beastaudio's Avatar
Liked: 2826
Well, made some progress today. Finally. Work/life has been getting in the way of sawdust creation lately.
Name:	2014-09-13 17.16.07.jpg
ID:	261394   Click image for larger version
Name:	2014-09-13 18.27.59.jpg
ID:	261402   Click image for larger version
Name:	2014-09-13 21.29.22.jpg
Old 09-13-2014, 09:25 PM
LTD02's Avatar
Quoted: 2340 Post(s)
Liked: 2576
"It is closer to 17 cuft, and it just went off to Josh Ricci so he can get his testing done on the 24 "
just saw this...very nice.
Listen. It's All Good.
LTD02 is offline
Old 09-13-2014, 09:32 PM
LTD02's Avatar
Liked: 2576
"That would be get me to go back to resonant for my main system. Nearfield PR sub tuned 15-20hz."
@Scott Simonian
i thought you had something like 30 drivers powering your bass. do you think more spl from the p.r. system would really be worth it?
LTD02 is offline
Old 09-13-2014, 09:51 PM - Thread Starter
Point Source
beastaudio's Avatar
Liked: 2826
Not sure what that quote was from, actually.... BUT I ended up with a dual sealed. I tried to look at ANY way I could do PR's on this setup, but I just don't have the space between rows to make it happen. 12 cuft. for the big boys, as narrow of a box as I could manage, at a measly 14 1/4" deep. Will make a great bar for the second row and brutal destruction for those ballsy enough to sit in the front row:
Name:	2014-09-13 23.37.37.jpg
Scott Simonian likes this.
Old 09-13-2014, 09:59 PM
LTD02's Avatar
Liked: 2576
if I read it right, you sent your gtg box to josh so that he could test the 24?
LTD02 is offline
Old 09-13-2014, 11:00 PM
ambesolman's Avatar
Liked: 895
You guys all know what this means
Old 09-13-2014, 11:36 PM - Thread Starter
Point Source
beastaudio's Avatar
Liked: 2826
Yes, that box went Westerly, gotcha
To supplement, I did this little guy. Nearfield, for fun, with the HST's. Seems like a great trade-off to me
Old 09-14-2014, 07:01 AM
V.X.Donique's Avatar
Quoted: 52 Post(s)
Liked: 45
The HST and Sundown surrounds look like hemorrhoid cushions.
V.X.Donique
Introducing the Vier Systems Xero.1/Midbasiks Subwoofer builds....
Creator of the AVScience DIY Speakers and Subwoofers Forum
"Don't concentrate on the finger or you will miss all that heavenly glory." -Bruce Lee
V.X.Donique is offline
