The "JohnnySub" - AVS Forum | Home Theater Discussions And Reviews
 76Likes
Old 08-24-2014, 10:23 AM - Thread Starter
chalugadp's Avatar
Quoted: 1672 Post(s)
Liked: 1523
The "JohnnySub"
My front corner of my living room could fit a bigger sub but not minimarty size. I wanted better spl in 18-30hz range in my large room. My two micro-cubes are great for nearfield on either side of my couch and serve as end tables.
Lately I saw a couple people who wanted a sub in between cube and mini sizes. Looking at size chart there was a perfect spot in the middle. Thus the "JohnnySub" was born in honoring ltd02 as well.
Is 7.5 ~ cuft at 18.5hz tuning. Here is spl with si18 and 1100 watts
and here is regular cube (red), Johnny (blue) , minimarty (black) with si18 and 1100 watts.
For some minimarty is just too big. I just can't fit minimarty in my corner of livng room without it screaming look at me. I know some are looking for nearfield sub but mini too big as well. Can lay Johnnysub on its side as well.
32" height allows it to fit on a sheet of mdf perfectly. Here is cutlist .
chalugadp is offline
Old 08-24-2014, 10:39 AM
atabea's Avatar
Quoted: 595 Post(s)
Liked: 413
cool!!!
atabea is online now
Old 08-24-2014, 01:05 PM
Fattykidd's Avatar
Quoted: 561 Post(s)
Liked: 572
This is exactly what I've been looking for to do my two near field behind my couch.... I just picked up my mdf on Friday and was gonna do my cutting this afternoon but looks like I'm gonna be waiting a bit now. Chalugadp you just don't stop contributing to the community, man I tip my hat to you sir....
Fattykidd is offline
Old 08-24-2014, 04:57 PM - Thread Starter
chalugadp's Avatar
Liked: 1523
Thanks ,
You partly inspired me. That and i needed it . Will have the cutlist up as soon as I can figure it out. You will be first to build it. What driver you using ?
Old 08-24-2014, 05:03 PM - Thread Starter
chalugadp's Avatar
Liked: 1523
Can someone graph this in winisd for me ?
Exterior Measurement is 2' deep , 25.5" wide and 32" high. 1100 watts with si18 driver. Port is what I need. Rough calculations are 45" long ( might be +/- two inches). Looking for 18hz tune if possible. 19hz is ok too. Port height could be 2" or 2.5" high.
If someone can graph it and confirm port needed I can do cutlist.
Old 08-24-2014, 05:27 PM
FriscoDTM's Avatar
Quoted: 278 Post(s)
Liked: 261
I thought there were already a couple 32" variants - I assembled my first one yesterday and will prep for paint next weekend.
LTD02 likes this.
Display 2013 Samsung 75" UN75F6300 TV Media Xbox One S, Dune Solo, QNAP TS-453A NAS
Pre/Amp Marantz 7702mk2 Processor + DIY 11ch Icepower 50ASX2BTL Monoblock Amp Amp Build Link
7.2.4 Speakers DIYSG 1099s (LCR), Volt 10LX (SL, SR), Volt 8LX (BL, BR), Volt 10LX (TF, TR) Volt Build Link
Subs Dual 19Hz DIY Ported UXL-18s + FP14k Amp + MiniDSP 2x4 Balanced Tactile Crowsons + iNuke 6000DSP
FriscoDTM is offline
Old 08-24-2014, 05:33 PM
Fattykidd's Avatar
Quoted: 561 Post(s)
Liked: 572
Thanks ,
I was planning on doing another pair of IXL's... I tried to contact stereo integrity about two weeks ago for a quote for a pair of theirs but never received a response so guess it'll be mach 5 all the way around.
It'll probably be next weekend though before I get my wood cut now buts that's alright, so I may not be the first to build....
Old 08-24-2014, 05:44 PM - Thread Starter
chalugadp's Avatar
Liked: 1523
I'm sure that someone has built every size out their. I haven't seen a 25.5" wide by 32" high. Wanted to keep the footprint small. Just creating a nice cutlist with drawing makes it easier for some.
Fattykidd likes this.
Old 08-24-2014, 06:16 PM
chrapladm's Avatar
Quoted: 901 Post(s)
Liked: 326
LOL I was just thinking about a 8cuft 16hz cabinet. Pretty darn close to this one. Although you have done that tune in the larger cabinets.
chrapladm is online now
Old 08-24-2014, 06:17 PM - Thread Starter
chalugadp's Avatar
Liked: 1523
Can u model it ?
Old 08-24-2014, 06:26 PM
chrapladm's Avatar
Quoted: 901 Post(s)
Liked: 326
Yes I have been modeling the 8cuft enclosures for a while on a single 18 ZV4 and 15 X subwoofers. And now the HST is coming so I was thinking about the enclosure again. Hardest part was coming up with a port that could handle the velocity of the HST/ZV4. I dont mind designing for 30m/s because I wont be ever pushing the subwoofer that hard. Just trying to find a 120hz resonance also.
Either way another fun build thread from you guys.
Old 08-24-2014, 06:28 PM - Thread Starter
chalugadp's Avatar
Liked: 1523
Just not sure if port height 2" or should be 2.5" and total length to hit 18hz. Si driver.
Old 08-24-2014, 06:40 PM
chrapladm's Avatar
Quoted: 901 Post(s)
Liked: 326
All I see is 45" and 2-2.5", what is the width 20?"
20 x 2.5 x 45" = 18.76hz
20 x 2 x 45" = 16.88hz
Old 08-24-2014, 06:55 PM - Thread Starter
chalugadp's Avatar
Liked: 1523
Same width as cube and minimarty . Isn't it 22.5" of port width ?
Old 08-24-2014, 11:09 PM
chrapladm's Avatar
Quoted: 901 Post(s)
Liked: 326
22.5 x 2 x 45" = 17.85hz
Old 08-24-2014, 11:28 PM
LTD02's Avatar
Quoted: 2385 Post(s)
Liked: 2649
not sure if the name would better be martysub 8.0
a 2.5" x 44" port and about 10% correction yields about 18.5hz tuning. first port resonance is about 140hz, which is pushing it, but should still work. air speed is good. cone excursion is good.
Dayton 18" with 1100 watts. si 18ht will pretty much be identical.
Name:	marty sub 8 point O - 8 cu ft tuned to 18.5 hz.png
chalugadp and SaltyPaws like this.
Listen. It's All Good.
LTD02 is online now
Old 08-24-2014, 11:31 PM
LTD02's Avatar
Liked: 2649
cube - red
8.0 - blue
mini -black
LTD02 is online now
Old 08-24-2014, 11:35 PM - Thread Starter
chalugadp's Avatar
Liked: 1523
si 18ht with 1100 watts.
I knew if I asked you would say name it something else so that's why I didn't ask.
Graph is exactly what I was hoping for. Meets my needs perfectly and I hope a few others as well. I will have the cutlist ready tomorrow.
Thanks again John .
Old 08-25-2014, 06:58 AM
Fattykidd's Avatar
Quoted: 561 Post(s)
Liked: 572
After I build my pair they will be going in my Sig as "johnnysubs"
Thanks again for all the contributions guys.
Old 08-25-2014, 09:32 AM
fishdude's Avatar
Quoted: 13 Post(s)
How well would a UM-18 work here?
fishdude is online now
Old 08-25-2014, 09:35 AM - Thread Starter
chalugadp's Avatar
Liked: 1523
Would be better suited for minimarty . That driver loves space. It would work, just not at its optimum .
Old 08-25-2014, 10:06 AM - Thread Starter
chalugadp's Avatar
Liked: 1523
Here is cutlist
Will add everything to post one. Once the first one is built and confirms that it sounds good I will then add this design to martysub FAQ .
I think I am going to use Dayton 18" ho driver. Ive been running the 15" ho driver with 1500 watts and no issues. The 18" with 1500 watts gives me another db.
Would like to put a uxl18 in there but too costly for me.
LTD02 and Fattykidd like this.
Old 08-25-2014, 11:47 AM
lemonslush's Avatar
Quoted: 827 Post(s)
Liked: 406
I like the idea. These could fit perfectly between my center and mains, in addition to give me some extra DB's. Which we all like extra Db's.
chalugadp likes this.
lemonslush is offline
Old 08-25-2014, 05:01 PM
Fattykidd's Avatar
Quoted: 561 Post(s)
Liked: 572
Here is cutlist
How many sheets do you figure these will take? Do you think I can squeeze them onto 3 sheets?
Old 08-25-2014, 05:17 PM - Thread Starter
chalugadp's Avatar
Liked: 1523
1.5
You can get 6. 32" pieces out of one. Which cover sides , baffle and back. Also port back and rails. Then 1/2 sheet for top and bottom and port bottom and bracing.
3 sheets will make 2 subs. That's why I cut off height at 32".
Old 08-25-2014, 05:21 PM
Fattykidd's Avatar
Quoted: 561 Post(s)
Liked: 572
Thank you.... didn't want to get half way through cutting and run out of wood.
Old 08-25-2014, 05:25 PM - Thread Starter
chalugadp's Avatar
Liked: 1523
I'm joining the darkside of bracing. Going to use dowel type like this
Going to use 1 by 1 and glue and toe nail.
Old 08-25-2014, 05:32 PM
Fattykidd's Avatar
Quoted: 561 Post(s)
Liked: 572
looks simple enough but I'll be a few days before I'm there, you definitely gotta make sure your vertical braces are the right length so your top sits down properly.
And I don't know what driver I'm going to be using anymore either the ixl went up again it's now 350, I currently can't cross the border so dayton's are out of the question.... curious how the new mach 5 ftw-lte is gonna model and what the intro pricing is going to be.
Old 08-25-2014, 05:38 PM - Thread Starter
chalugadp's Avatar
Liked: 1523
Can't cross the border. Mmmmm is that one year less a day issue ...
Old 08-25-2014, 05:45 PM
Fattykidd's Avatar
Quoted: 561 Post(s)
Liked: 572
LOL.... no , we've yet to get passports I've been bugging the wife that we should do it but she doesn't think we need them.
alamez likes this.
