Fusion 12 Tempest Damping - Too much, too little, wrong places? - AVS Forum | Home Theater Discussions And Reviews
 2Likes
  • 1 Post By mtg90
  • 1 Post By Erich H
post #1 of 12 Old 08-31-2014, 12:40 PM - Thread Starter
Blnd2Spll's Avatar
Any thoughts or suggestions on how I'm planning on damping the Fusion 12? I'm leaving some places bare to avoid direct contact with the speaker and ports, and I'm not planning on adding any insulation to the top or bottom, mostly due to space issues.
Name:	2014-08-31 14.14.30.jpg
ID:	238833   Click image for larger version
Name:	2014-08-31 14.14.07.jpg
ID:	238841   Click image for larger version
Name:	2014-08-31 14.13.58.jpg
Blnd2Spll is offline
post #2 of 12 Old 08-31-2014, 02:08 PM
BassThatHz's Avatar
Quoted: 2031 Post(s)
Liked: 1546
I'd add more, you can always take some out.
BassThatHz is offline
post #3 of 12 Old 08-31-2014, 02:46 PM
Bassment's Avatar
Quoted: 904 Post(s)
Liked: 364
Bassment is offline
post #4 of 12 Old 08-31-2014, 06:29 PM
Erich H's Avatar
Quoted: 1406 Post(s)
Liked: 1768
That looks like a lot to me. 1.5" acoustic foam (or similar) is good.
_______________________
The SEOS Waveguide Project
Erich H is offline
post #5 of 12 Old 08-31-2014, 07:51 PM
mtg90's Avatar
Quoted: 412 Post(s)
Liked: 778
That's about how much I would use. You don't want too little, too little can leave you with a muddy midrange because the back wave is not being properly absorbed, too much will only reduce bass output from the ports.
SpinMonster likes this.
mtg90 is online now
post #6 of 12 Old 08-31-2014, 08:32 PM
brian6751's Avatar
Quoted: 878 Post(s)
Liked: 673
Yep. Your good
brian6751 is online now
post #7 of 12 Old 09-01-2014, 09:34 AM - Thread Starter
Blnd2Spll's Avatar
Thanks for the quick responses. I guess I'll stick with what I have for now (3 votes for enough, 1 vote for too much, 1 vote for too little). It's 2"-thick insulation, so I'm limited in where I can put it. Adding more than what's there will mean I'd either have to cut it in half, which is a pain to do, or it will be directly bumping up against the speakers or ports. I'll plan on using minimal adhesive so I can always go back and rip it out if it's too damped.
post #8 of 12 Old 09-01-2014, 09:46 AM
Erich H's Avatar
Liked: 1768
When I asked the designer how much he used, he told me 1.5" acoustic foam (egg crate style) lining the internal walls, but not blocking the ports. He said he also stuck a good handful of pillow stuffing up towards the top of the box.
One of the most important places would be behind the woofer. Not sure I like how your insulation is acting like a 'wall' between the waveguide and woofer area.
kingpin111 likes this.
Erich H is offline
post #9 of 12 Old 09-01-2014, 09:52 AM
Jeff in Canada's Avatar
Quoted: 167 Post(s)
Liked: 61
I'd remove the material between the woofer and waveguide. I'd stuff that with dacron firm but not overly stuffed behind the waveguide up to the woofer. I asked Jeff and I went with 1 1/2" egg crate on the outside walls staying clear of the ports. I then used the pillow material around the waveguide. I pulled apart the pillow stuffing a bit to thin it out but put it in there and then behind the woofer. Worked out well.
Audio: Denon AVR-4520, Fusion 12 Tempest (LCR), Fusion 8 Alchemy (4xSurrounds+2xWides+2xHeights),4 x 15" Dayton Ultimax
Video: Sony VPL-HW40ES, Darbee Darblet, SMX 2.35:1 Screen
Seating: Fusion Lagoon Chairs
Theater Build
DIY Speaker / Sub Build
Jeff in Canada is offline
post #10 of 12 Old 09-01-2014, 02:13 PM - Thread Starter
Blnd2Spll's Avatar
The separation between the woofer and waveguide is basically at the suggestion of Wayne Parham at Pi speakers. I realize that this is a totally different speaker, but the idea being "It sort of partitions the cabinet into upper and lower sections. Bass passes right through, but midrange is attenuated" (to quote Wayne).
But, I can be convinced to take it out if this recommendation seems really wrong or if there's a reason why it won't work as well given this speaker design.
post #11 of 12 Old 09-01-2014, 03:50 PM
Quoted: 167 Post(s)
Liked: 61
Message Jeff Bagby. I stuffed mine the way he told me to. He designed the speaker and tested it. Your call. I can't say that I did it correctly for certain. When I go to Indiana for work I'll drop one of mine off to be tested to see if I did them all correctly.
Theater Build
post #12 of 12 Old 09-01-2014, 05:30 PM
WereWolf84's Avatar
Quoted: 224 Post(s)
Liked: 85
I built mine with 1.5" egg crate foam lining all the internal walls only, not stuffing any polyfill, should I stuffing? would it improves a lot after stuffing?
WereWolf84 is offline
