Help - Ultimax 18 and iNuke 3000 DSP -> very low volume? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 14 Old 09-04-2014, 02:47 AM - Thread Starter
Quoted: 28 Post(s)
I just about finished with my Ultimax 18 in 4 cu ft sealed subwoofer. I just hooked it up and barely any sound is coming out of it on settings which I would expect to shake everything in my room. I am wondering if I messed up the wiring or the setup somehow.
I would really appreciate any trouble shooting help. Having a party this Friday and would love to have the sub operational. Been trying really hard to finish it the past few weeks and now really bummed I can't get it to work.
My setup:
Emotiva USP-1
-sub XLR Out to XLR Ch A In (crossovers set at 80)
-speakers set to full range for now
iNuke
-set to Bridge mode
-gain on DSP on the comp set to 0
-i have the knob on channel A pointing straight up - when i turn it all the way to the right, i start seeing clipping lights at low volumes
Wiring (iNuke to Ultimax 18)
-Using output channel A
-Speakon 1+ (positive) and 2+ (negative)
Wiring inside sub
-positive (1+) from iNuke to positive (red) terminal on one voice coil
-from same voice coil, i have a jumper from the negative (black) to positive (red) on second voice coil
-from second voice coil, i connected the negative (black) terminal to the negative (2+) on speakon
Is this correct configuration?
Mtrc808 is offline
post #2 of 14 Old 09-04-2014, 08:04 AM
FriscoDTM's Avatar
Quoted: 261 Post(s)
Liked: 243
try turning the gain up?
Display 2013 Samsung 75" UN75F6300 TV Media Xbox One S, Dune Solo, QNAP TS-453A NAS
Pre/Amp Marantz 7702mk2 Processor + DIY 11ch Icepower 50ASX2BTL Monoblock Amp Amp Build Link
7.2.4 Speakers DIYSG 1099s (LCR), Volt 10LX (SL, SR), Volt 8LX (BL, BR), Volt 10LX (TF, TR) Volt Build Link
Subs Dual 19Hz DIY Ported UXL-18s + FP14k Amp + MiniDSP 2x4 Balanced Tactile Crowsons + iNuke 6000DSP
FriscoDTM is offline
post #3 of 14 Old 09-04-2014, 08:49 AM
DevonDeyholos's Avatar
Quoted: 185 Post(s)
Liked: 180
First thought: What happens if you take your speakers off of full range? I know with my old Pioneer receiver if I had the front speakers set to large it automatically killed the signal to the sub. My fronts had to be set to small for the sub to get a signal.
Second thought: I use a peavey as my sub amp and it has 3 modes on the channel inputs. (1) highpass (2) full range (3) subwoofer. If I had it set to high pass and was feeding it a sub 80Hz signal I would get very little sound out of it, if any.
Hope this helps!
DevonDeyholos is offline
post #4 of 14 Old 09-04-2014, 10:27 AM - Thread Starter
Quoted: 28 Post(s)
When I turn the gain up, it does get a bit louder, but the clipping lights start coming on although it is audable, it is very very quiet. I've owned an 18 inch sub before and by comparison, it sounded like it was at 5% volume.
Mtrc808 is offline
post #5 of 14 Old 09-04-2014, 10:29 AM - Thread Starter
Quoted: 28 Post(s)
Hope this helps!
I will try when I get home in a few hours. However, I am pretty sure on my preamplifer (its just a stereo setup), I am able to pass speakers full range and have a sub out at the same time.
I will double check the other setting on the iNuke, but I curently am not using any high pass filters. Crossover is set by my preamp. I am not sure if I have a subwoofer setting, but I have not heard of one from my reading.
Mtrc808 is offline
post #6 of 14 Old 09-04-2014, 10:42 AM
Quoted: 185 Post(s)
Liked: 180
If you're getting the clip lights on then you're definitely getting a good signal to the Amp so it won’t be my first suggestion.
It sounds like you have the sub wired properly to 4ohm so should be no problem for the Inuke. I would try running each channel on its own and see what happens. Just do 1+,1- on your speakon connector and you can swap it back and forth between the 2 channels to see if one of them is dead or something.
Another thought, and maybe you have already tried this, but I just noticed in your description of the setup that you only said that you have channel A on the Inuke turned up. I'm not familiar with how bridging works but if you're using both channels wouldn’t you need to have B turned up to the same level? Maybe it's as simple as turning up channel B
post #7 of 14 Old 09-04-2014, 11:01 AM
Samps's Avatar
Quoted: 787 Post(s)
Liked: 410
In bridged mode the channel B knob does not need to be turned up.
Screen shots of each of the inuke tabs would help. When listening to music with a computer hooked up to the inuke, do you see the two output indicators (A&B) on the computer bouncing up and down in sync with the input indicator (A)?
Samps is offline
post #8 of 14 Old 09-04-2014, 11:08 AM
Andy611's Avatar
test 1
put some leads on the speaker terminals. tap the leads to a 1.5 volt battery. should definitely get an audible boom boom boom with each tap
Andy611 is offline
post #9 of 14 Old 09-04-2014, 12:38 PM
BassThatHz's Avatar
Quoted: 2031 Post(s)
Liked: 1547
Post a video of the inukeDSP software reaching clipping on the inputs and outputs and of the woofer excursion.
Make sure everything is well lit and in focus so that we can see what you are getting.
BassThatHz is offline
post #10 of 14 Old 09-04-2014, 08:08 PM
rhodesj's Avatar
Quoted: 852 Post(s)
Liked: 470
You should see the yellow lights lit; they indicate level below clipping. The red light is what indicates clipping, so it sounds like you can turn the gain up more.
rhodesj is online now
post #11 of 14 Old 09-04-2014, 10:20 PM - Thread Starter
Quoted: 28 Post(s)
Got stuck at work really late. Will trouble shoot with everyones suggestions tomorrow and post results. Thanks you.
Mtrc808 is offline
post #12 of 14 Old 09-05-2014, 07:59 AM
LTD02's Avatar
Quoted: 2340 Post(s)
Liked: 2574
with mains set to large, there may not be anything going to your sub with music.
not sure if the avr has something called "plus mode" or something like that which allows mains to run full range AND sends the bass under the crossover point to the sub.
Listen. It's All Good.
LTD02 is offline
post #13 of 14 Old 09-05-2014, 08:33 AM
splotten's Avatar
Quoted: 268 Post(s)
Liked: 108
Its only the top light that indicates clipping. The lower ones are just signal indicators.
splotten is offline
post #14 of 14 Old 09-08-2014, 07:26 PM - Thread Starter
Quoted: 28 Post(s)
Thank you all again for your help. Just got back into town and decided to try replacing the iNuke since it seemed everything was set correctly. Also called Emotiva and was told that the pre-amp was also set correctly.
Plugged in the new iNuke and everything works perfectly. I don't know if I accidentally dialed in some setting that made it behave weird or if something was actually wrong with the first unit.
Lots of bass --> makes you wonder what the Ultimax 18 would do in a Marty cube.
Mtrc808 is offline
