Dual Opposed Subwoofers - how is the performance compared to a ported sub? - AVS Forum | Home Theater Discussions And Reviews
 2Likes
  • 2 Post By mtg90
post #1 of 10 Old 09-04-2014, 04:40 PM - Thread Starter
video1's Avatar
Quoted: 124 Post(s)
I've read a few reviews of speakers using dual opposed woofers. The reviewers stated that while they could feel "chest slam" they felt almost no vibration when placing their hand on a the speaker due to the wave canceling effect of the opposing woofers.
So is there any benefit to a dual opposed subwoofer, especially as it pertains to minimizing vibration effects and improving the efficiency of sound isolation?
And how is the performance of such a design compared to a vented design like a mini-marty?
video1 is offline
post #2 of 10 Old 09-04-2014, 05:02 PM
tuxedocivic's Avatar
Quoted: 1907 Post(s)
Liked: 1726
As you note, dual opposing drivers reduces cab vibrations. This isn't the same as panel resonances, as Bill F rightly points out often. Thankfully panel resonances aren't an issue with subs usually. So what it is doing is reducing/eliminating the shaking and rocking and vibrations that the driver puts into the cab. For myself, I found this to be quite significant as my sub cabs were fairly light.
Dual opposed isn't a box alignment like ported is. You can have a dual opposed ported sub if you want. It's just more common with sealed as the box size for sealed can often accommodate two drivers. This is what I do myself.
tuxedocivic is online now
post #3 of 10 Old 09-04-2014, 08:08 PM
BassThatHz's Avatar
Quoted: 2032 Post(s)
Liked: 1555
Dual opposed is great for stacking sonotubes in the corners (boundary gain), or when mechanical vibrations need to be zero,
or in cases where space is tight and high SPL is needed; the disadvantage is that they usually rolloff higher because their boxes aren't ideally-sized.
BassThatHz is offline
post #4 of 10 Old 09-04-2014, 09:57 PM - Thread Starter
video1's Avatar
Quoted: 124 Post(s)
So the benefit is mainly for the other drivers if any within the speaker cabinet.
Are there any benefits as far as limiting the amount of low bass that passes through the walls to outside of the HT?
video1 is offline
post #5 of 10 Old 09-04-2014, 10:00 PM - Thread Starter
video1's Avatar
Quoted: 124 Post(s)
Does this means less low bass leaks out of the HT?
As for rolloff, how bad is it? Are we talking about rolling at 25 Hz down to the point that there is no performance or are we talking about it rolling off as compared to the mega subs that the DIYers are used to building here?
video1 is offline
post #6 of 10 Old 09-04-2014, 10:12 PM
mtg90's Avatar
Quoted: 413 Post(s)
Liked: 783
The only real difference between a cabinet with dual opposed drivers and one of identical volume and dual front firing woofers would be the forces exerted on the cabinet by the moving woofers. In each designs the woofers both move in and out together, displacing the same amount of air and generating the same SPL, so there would be no difference in how the subwoofer sounds or how the bass waves move through (or out of) a room.
LTD02 and chalugadp like this.
mtg90 is offline
post #7 of 10 Old 09-04-2014, 10:48 PM - Thread Starter
video1's Avatar
Quoted: 124 Post(s)
Got it. That makes sense.
video1 is offline
post #8 of 10 Old 09-04-2014, 10:53 PM
MDST's Avatar
Quoted: 32 Post(s)
With dual opposed: More down low SPL and more upper SPL?? Or I'm wrong??
MDST is offline
post #9 of 10 Old 09-05-2014, 12:10 AM
LTD02's Avatar
Quoted: 2340 Post(s)
Liked: 2576
as matt (mtg90) just said, dual opposed is simply an arrangement of drivers. functionally, the performance is identical to two independent subwoofers built large enough not to vibrate when bass is played, placed back-to-back. no more or less upper or lower bass spl than would occur with two independent subs.
Listen. It's All Good.
LTD02 is offline
post #10 of 10 Old 09-05-2014, 06:46 AM
Bill Fitzmaurice's Avatar
Liked: 4631
+1. You'll often see it claimed that dual opposed cancels out the internal pressures that cause the panels of the cab to vibrate. It doesn't. The only way that would happen is if the drivers were wired with reverse polarity. That would eliminate panel flexing, but it would also eliminate sound output. What dual opposed does eliminate is the actual movement of the speaker across the floor, commonly referred to as dancing.
Bill Fitzmaurice is offline
