building my Mini Marty - AVS Forum
 3Likes
  • 2 Post By maddog_1
  • 1 Post By maddog_1
post #1 of 15 Old 09-08-2014, 11:16 PM - Thread Starter
Liked: 5
Red face building my Mini Marty
Hi Guys
I just started to build my mini marty sub. Once finished its going to have the Dayton UM18 in it and going to run off inuke 3000dsp
I havent got a table saw so i have been using a circular saw , some cuts are good some are a bit rough but not out heaps phew
hopefully i have it finished by the weekend so i can sand it down etc
eng-399 and Fattykidd like this.
maddog_1 is online now
post #2 of 15 Old 09-08-2014, 11:17 PM - Thread Starter
Liked: 5
Saved
post #3 of 15 Old 09-14-2014, 05:23 PM - Thread Starter
Liked: 5
Originally Posted by maddog_1 View Post
Saved
Hi Guys
Heres a quick update on the build. Over the weekend i sanded it down , round the edges off and down the first coat of primer .
inside the box all the edges are sealed and siliconed just incase . Cant believe how much it weighs atm :/
post #4 of 15 Old 09-14-2014, 05:43 PM
Gamecock24's Avatar
Quoted: 101 Post(s)
Liked: 24
Looking good
Sent from my iPhone using TheChive - KCCO!
Gamecock24 is offline
post #5 of 15 Old 09-14-2014, 07:57 PM
eng-399's Avatar
Liked: 2
Looks great can't wait to see it painted
eng-399 is offline
post #6 of 15 Old 09-14-2014, 08:39 PM
cessna1466u's Avatar
Liked: 170
Looks great, what are you thinking for paint?
Yamaha RX-V773
Behringer iNuke nu6000dsp
(2) 18" Marty Cubes
Fusion 8 MTM
To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts.
cessna1466u is offline
post #7 of 15 Old 09-14-2014, 09:29 PM - Thread Starter
Liked: 5
Im thinking of going satan or gloss black with a clear coat . Doing a test on a scrap first to see if it works out
post #8 of 15 Old 09-14-2014, 09:49 PM
Bombelman's Avatar
Quoted: 12 Post(s)
Liked: 34
satan ?
Bombelman is offline
post #9 of 15 Old 09-14-2014, 10:05 PM - Thread Starter
Liked: 5
Originally Posted by Bombelman View Post
satan ?
hahaha oops , Satin black
post #10 of 15 Old 09-14-2014, 10:36 PM
Liked: 170
I'm thinking satin as well. Post some pics when you are done, I would love to see how it comes out,
Yamaha RX-V773
(2) 18" Marty Cubes
Fusion 8 MTM
post #11 of 15 Old 09-15-2014, 09:32 AM
kevings's Avatar
Quoted: 107 Post(s)
Liked: 198
nice job. im looking forward to hearing your listening impressions.
kevings is online now
post #12 of 15 Old 09-17-2014, 03:29 AM - Thread Starter
Liked: 5
Hi guys
painting is done , tomorrow i be sanding it with 1500 grit paper before i put the clear coat on
post #13 of 15 Old Today, 08:15 PM - Thread Starter
Liked: 5
ok painting is done and clear coat , just waiting on the driver and amp to come in now
ok there is some small inperfections but for my first build it still looks good
post #14 of 15 Old Today, 08:19 PM
GizzeGutten's Avatar
Quoted: 49 Post(s)
Liked: 32
At least you got the paint on, mine are still in raw mdf, Looking good!
DAC/Preamp: miniDSP 4x10 HD and Mytek 192 Stereo DSD DAC
Speakers: JBL 4343B, JBL 4430 and JBL 120Ti
Amplifiers: Emotiva XPR-1, Denon POA 1500, QSC GX5 and Sanway's LabGruppen FP14000 clone
Sub: DIY LMS Ultra 5400
GizzeGutten is online now
post #15 of 15 Old Today, 08:32 PM - Thread Starter
Liked: 5
make sure you seal the edges good or it will take a lot of paint to cover it , plus with the clear coat dont put it on thick or you get little air bubbles
GizzeGutten likes this.
User Tag List
