Inuke fan mod test results - AVS Forum
Old 09-15-2014, 02:29 PM - Thread Starter
meeks32's Avatar
I recently built a sub with an SI Ht18 and inuke 3000dsp. I read about how loud stock fans were on numerous pro style amps but never had first hand experience till now and I must say in its stock form it's not suitable for home theater when it's in the same room. I ordered a Noctua NF-r8 off amazon for around $14. I used a spl meter and ran a test with both fans at idle and a test after going through a couple low and loud sign waves. I thought I would post actual readings so people don't have to rely on taking people's word if they want to switch fans.
meeks32 is offline
Old 09-15-2014, 02:30 PM - Thread Starter
meeks32's Avatar
Stock at idle
meeks32 is offline
Old 09-15-2014, 02:31 PM - Thread Starter
meeks32's Avatar
Stock after sign waves
meeks32 is offline
Old 09-15-2014, 02:33 PM - Thread Starter
meeks32's Avatar
Noctua at idle, my spl meter couldn't read that low
meeks32 is offline
Old 09-15-2014, 02:36 PM - Thread Starter
meeks32's Avatar
Noctua after sign waves. Needless to say its a night and day difference and I highly recommend it if you have these amps!
dtsdig likes this.
meeks32 is offline
Old 09-15-2014, 02:55 PM
mlah384's Avatar
Quoted: 172 Post(s)
Liked: 65
Do they cool as well as stock fans? Some people have mentioned that their i nukes (6000 mainly) overheat after fan mod...
mlah384 is online now
Old 09-15-2014, 03:06 PM
dtsdig's Avatar
Quoted: 142 Post(s)
Liked: 138
The Noctua NF-R8 fans move up to 53 m³/h which is plenty for these amps. Some of the bestbuy/radio shack replacements that some folks use provide significantly less airflow than these, and that's where some run into trouble.
These fans are great! I put two of them in my NU4-6000 and they are indeed dead silent. I have run at high volumes for 8-10 hours straight and have never had an issue. Feeling the air coming from the front of the amp after watching a movie at reference, the air is luke warm at most. They are a bit more expensive than others, I paid $24 for a 2-pack, but well worth it IMO.
dtsdig is offline
Old 09-15-2014, 03:49 PM
mlah384's Avatar
Quoted: 172 Post(s)
Liked: 65
Really good to know! Thanks! I'm about to order a 6000dsp for 2 Ultimax 18's and I wanted to do the fan mod but was worried about heat issues....
Also, I guess the mod is pretty easy with these?
Old 09-15-2014, 03:57 PM
Bass Enabler
Scott Simonian's Avatar
Quoted: 858 Post(s)
Liked: 1028
Omg! I need to get these ASAP!
Just to confirm...DTS, are you using the these: http://www.amazon.com/Noctua-NF-R8-P...s=Noctua+NF-R8
My Dual 18" LLT subs 120dB down to 10hz
Plan9Reloaded Co-host
Listen to the Plan9Reloaded Gaming and Technology Podcast (may contain NSFW language)
https://soundcloud.com/plan9reloaded/sets/podcast - direct pod link
http://plan9reloaded.com/site/ - main website
Scott Simonian is online now
Old 09-15-2014, 04:03 PM
randyc1's Avatar
Quoted: 121 Post(s)
Would you happen to have the Link from where you got the 2 pack ?
randyc1 is offline
Old 09-15-2014, 04:07 PM
Bass Enabler
Quoted: 858 Post(s)
Liked: 1028
Yes, please.
Old 09-15-2014, 04:12 PM
chalugadp's Avatar
Quoted: 1196 Post(s)
Liked: 1162
Noctua didn't work for me with 6000. Was getting amp to shut down. There movement is low. Only 20cfm at lower speeds. If your room is hot then it doesn't cool well at lower volumes. Turning the bass up the fan tops out at 35cfm. At higher volumes the fan does ok. The stock fans are 60 cfm. I replaced the noctua with thermaltake duramax. It has constant fan at 39cfm. No issues. Today 30° (90 farenheit)in my living room . I much prefer thermaltake and moves air. Its louder at 30dbs. Any louder and it would be too loud.
LTD02 and Archaea like this.
chalugadp is online now
Old 09-15-2014, 04:20 PM
randyc1's Avatar
Quoted: 121 Post(s)
How do you know if a fan works on 2 speeds or is constant like you say yours is?
Does the 2 speed have 3 wires ?
randyc1 is offline
Old 09-15-2014, 04:28 PM
chalugadp's Avatar
Liked: 1162
Its in product details. Will say constant or variable.
Old 09-15-2014, 04:37 PM
randyc1's Avatar
Quoted: 121 Post(s)
Wonder if it could be wired to run at just highest speed?
randyc1 is offline
Old 09-15-2014, 05:21 PM
dtsdig's Avatar
Quoted: 142 Post(s)
Liked: 138
Yes!
http://www.amazon.com/gp/aw/d/B001QYLOA4?me=&ref=olp_product_details
dtsdig is offline
Old 09-15-2014, 05:34 PM
dtsdig's Avatar
Quoted: 142 Post(s)
Liked: 138
Which specific Noctua model did you try? Did you add any of the "low noise adaptor" wires that they come with? Did you use the 3rd yellow wire (for RPM) or just the positive and negative. I'm just asking because I have never read anyone else having that issue with the NF-R8 80mm fans. They are spec'd at 31.2 cfm if they are hooked up without using the low noise adaptors. Just curious.
dtsdig is offline
Old 09-15-2014, 05:36 PM
Bass Enabler
Quoted: 858 Post(s)
Liked: 1028
Did you use any of the lower noise adapters or just go stock?
Old 09-15-2014, 05:48 PM
andyc56's Avatar
Quoted: 17 Post(s)
Liked: 215
Here's the specs from the Noctua web site. They say it's discontinued, so I wonder how long they'll still be available? There isn't an exact match in their present lineup. There's one that spins a bit faster and one that spins a bit slower. The NF-A8 FLX (the faster one) looks like a better match. Although RPM is faster, airflow is a bit less, and it's a bit quieter.
andyc56 is offline
Old 09-15-2014, 05:57 PM
mlah384's Avatar
Quoted: 172 Post(s)
Liked: 65
I see these Noctua's at Newegg: http://www.newegg.com/Product/Produc...rder=BESTMATCH
What about these fans?
Thermaltake DuraMax 8 AF0058 http://www.newegg.com/Product/Produc...82E16835106180
38.2 CFM
31.3 dBA
Thermaltake Mobilefan II External USB http://www.newegg.com/Product/Produc...82E16811999130
47.28 CFM
31 dBA
Newegg lets you search by Air Flow, Noise Level, Size, etc...
Old 09-15-2014, 06:05 PM
randyc1's Avatar
Quoted: 121 Post(s)
With the stock fans do they run at 2 speeds ?
randyc1 is offline
Old 09-15-2014, 06:22 PM
chalugadp's Avatar
Liked: 1162
31 cfm isn't enough in my hot living room. Tried both noctua fans. Ill sell my two rf8 fans for $2 plus shipping . Shipping would probably be $8, so $10 total
Old 09-15-2014, 06:56 PM
randyc1's Avatar
Quoted: 121 Post(s)
Just to be clear chalugadp , you mentioned that at high vol everything was ok ,... it was at low vol that the amp overheats , so the amp was controlling the fan speed ? If so,.. does your new fan go from low to high speed also??
randyc1 is offline
Old 09-15-2014, 07:14 PM
chalugadp's Avatar
Liked: 1162
My new fan is one speed. My living room is hot in summer. If you have a home theater in the bassment then noctua fine. I also have a parasound amp in the av rack and it throws a lot of heat. I'm in a situation where I need more cooling then average .
Old 09-15-2014, 07:52 PM
randyc1's Avatar
Quoted: 121 Post(s)
You mentioned that at high vol everything was fine with the Noctua
...What im trying to get at is,... that if your noctua fans were wired to just (one speed ,.. top speed) , like when you were at High Vol and everything was fine ,.. then they would also be fine at low vol no??
randyc1 is offline
Old 09-15-2014, 08:12 PM
FriscoDTM's Avatar
Quoted: 13 Post(s)
I have the noctuas on my 6000 with around a month of usage and haven't triggered any thermal protection circuit. The fans only have 2 wires and seem to run at max speed all the time. They are definitely dead silent.
TV 2013 Samsung 75" UN75F6300
AVR 2013 Denon AVR-X2000
7.1 1 Yamaha NSIW960 (C), 4 Yamaha NS-IC600WH + 4 Dayton ME820C (FL,FR, SL, SR), 2 DIY OS-MTM (BL, BR)
Subs Dual Ported UXL-18 subs + iNuke6000DSP
Calibration CALMAN5, REW, UMIK-1
FriscoDTM is online now
Old 09-15-2014, 08:25 PM
chalugadp's Avatar
Liked: 1162
The high fan only kicks in at super high volume . So listening at -10 db's the fan was low.
Again my rack is warm and needs constant cfm of 32 or more.
Old 09-15-2014, 09:37 PM
beefbuzz's Avatar
Liked: 8
I use the NoiseBlocker brand all the time in liquid cooled computer builds in the larger size, love them even more than Noctua. In fact I have 5 of the 120mm model within 2ft of my head on my desk at all times. You can also choose by rpm/cfm. Check out the S1, S2, or S3 on this page:
http://www.frozencpu.com/cat/l3/g/c1...ml?id=3ZQwyCHr
beefbuzz is offline
Old 09-15-2014, 09:38 PM
sslv2pwned's Avatar
Quoted: 101 Post(s)
Liked: 31
I have two Nexus 80mm Real Silent Case Fans in each of my iNuke 6000 DSP's. They have been running about a year without any problems at all.
sslv2pwned is offline
Old 09-15-2014, 10:59 PM
jbrown15's Avatar
Quoted: 1227 Post(s)
Liked: 1195
LOL..... no it's not, I think we proved that in my basement this summer!...lol
jbrown15 is online now
