AMP to run Fusion 8's on computer - AVS Forum | Home Theater Discussions And Reviews
post #1 of 9 Old 09-21-2014, 11:38 PM - Thread Starter
sslv2pwned's Avatar
Quoted: 127 Post(s)
Liked: 33
I want to use a pair of Fusion 8's on my computer. I need an amp to do so. What do you think of the following? Is there something else you would recommend?
http://www.parts-express.com/lepai-l...upply--310-298
Sent from my Nexus 7 using Tapatalk
sslv2pwned is offline
post #2 of 9 Old 09-22-2014, 02:42 PM
absolootbs's Avatar
Quoted: 18 Post(s)
Liked: 27
Unless the bluetooth or better/prettier case are important to you, I'd save the $75 and go with the lp-2020 (http://www.parts-express.com/lepai-l...upply--310-300). It's basically the "industry standard" mini amp. Sure you'll only get about 8 clean watts into an 8 ohm load, but when powering 90+ db efficiency speakers in a nearfield situation, that's about 7.9 watts more than you need.
absolootbs is offline
post #3 of 9 Old 09-22-2014, 02:46 PM - Thread Starter
sslv2pwned's Avatar
Quoted: 127 Post(s)
Liked: 33
Excellent! Thank you for saving me $75!!!
post #4 of 9 Old 09-22-2014, 04:15 PM
Quoted: 109 Post(s)
Liked: 30
I use the little Dayton brand model that puts out 15 watts x2 and can run off batteries and it is more than enough power for near field listening. I love this little amp I can take it with me when I go to buy speakers second hand and can see if the speakers are working correctly or not no matter where I am.
https://www.parts-express.com/dayton...5-wpc--300-380
jake515 is offline
post #5 of 9 Old 09-22-2014, 04:39 PM
Audio Geek's Avatar
Quoted: 91 Post(s)
Liked: 42
That's just what I would've suggested as well. I hooked up my Tempest speakers to the LP-2020A+ to test and they were incredibly loud, even in the next room, and had a lot more room to get louder. Near field should be no problem for any of the SEOS designs.
Audio Geek is offline
post #6 of 9 Old 09-25-2014, 03:25 PM - Thread Starter
sslv2pwned's Avatar
Quoted: 127 Post(s)
Liked: 33
I got the amp in today. At normal listening levels it sounds great. However, I was disappointed when I tried to crank it. Once the AMP is turned up past 2 o'clock, it starts clipping. This causes some serious speaker distortion.
That said, for $20 shipped I cannot complain.
post #7 of 9 Old 09-25-2014, 10:11 PM
Audio Geek's Avatar
Quoted: 91 Post(s)
Liked: 42
I keep mine at 12 o'clock and it gets plenty loud--my speakers (Classix II) aren't high efficiency. But it does distort if I turn it up too high.
If you're looking to wring every last but of performance out of it, see if you can upgrade the power supply (2A -> 5A). http://techtalk.parts-express.com/sh...e-Lepai-T2020A
Though, if it's loud enough for you then I wouldn't bother.
post #8 of 9 Old 09-25-2014, 10:13 PM
Audio Geek's Avatar
Quoted: 91 Post(s)
Liked: 42
You're trying to crank it listening to it near field?
post #9 of 9 Old 09-26-2014, 01:13 AM - Thread Starter
sslv2pwned's Avatar
Quoted: 127 Post(s)
Liked: 33
I may try the power supply just to play around. But I don't need it. Originally they weren't near field. However, I brought them in a bit closer and it's much better.
I took some readings and it looks like they max out at about 88dB. The meter bit 90 very briefly. This will be more than plenty. It's when I want the sound to fill the room that I want more.
The main issue is that I know what they can sound like. When played on my AVR they sound awesome and get very loud.
