small sub finishes..pics - AVS Forum
Old 10-29-2014, 11:07 PM - Thread Starter
tgeorge34's Avatar
Quoted: 21 Post(s)
Liked: 24
Finished my 12" tc sounds ported sub build for the living room. Made it so it would fit in the cabinet, and could open when I really wanna hear it. Put a 3/4 piece of cherry on the front, and used the same stain as my cabinets so it matches.
Just started playing around with getting it dialed in. I haven't run audyssey yet, but I'm not getting much output. I have it running off an inuke 1000dsp, running in bridged mode. I have it at 4ohm, putting out 1000 watts, with a hpf at 30hz, and a Butterworth slope of 12db. I hope that all is correct.
I hardly get the lights to light up on front of the amp. If I was to increase the gain on the dsp portion of the amp is that ok, or is that hard on the amp?..
Any other suggestions?
tgeorge34 is offline
Old 10-29-2014, 11:14 PM - Thread Starter
tgeorge34's Avatar
Quoted: 21 Post(s)
Liked: 24
Some pics
ID:	339921   Click image for larger version
ID:	339929   Click image for larger version
Old 10-29-2014, 11:16 PM - Thread Starter
tgeorge34's Avatar
Quoted: 21 Post(s)
Liked: 24
Pay no attention to the missing screw...I only got 7 out of the 8 special screws that tc sounds sends with their subs...last one is on the way.
How do you edit a title on a post...I am on my phone and just realized I misspelled my title!
Old 10-30-2014, 05:36 AM
tashspop's Avatar
very nice clean little box.
tashspop is offline
Old 10-30-2014, 08:00 AM
Samps's Avatar
Quoted: 102 Post(s)
Liked: 39
Box looks great. Assuming the box is tuned much lower than 30hz, you need to lower the high pass filter to 20hz. Even if you tuned to 21-23. If the tuning is higher than that it will need modeled to safely set the hpf. Hopefully it's tuned in the low 20s.
Samps is online now
Old 10-30-2014, 10:51 AM
Quoted: 38 Post(s)
Crank up the the sub out put from your receiver and see if that helps get the output up.
Pro amps are used to getting a lot of signal.
Yes you can also crank up the gain on the amp and not hurt anything.
Nice looking cabinet!!!
jake515 is offline
Old 10-30-2014, 03:07 PM
squiers007's Avatar
Quoted: 130 Post(s)
Liked: 59
Port tune will determine where to set the HPF. What is the enclosure tuned at?
Check out my End-Table Marty Build
squiers007 is online now
Old 10-30-2014, 03:26 PM - Thread Starter
tgeorge34's Avatar
Quoted: 21 Post(s)
Liked: 24
Thanks for the compliments! I tuned it for 30hz. Thanks @TheGiantPeach for modeling it for me. I have run audyssey, it's sounding much better. But I'm still having a hard time getting the light to come on the front
Old 10-30-2014, 03:30 PM - Thread Starter
tgeorge34's Avatar
Quoted: 21 Post(s)
Liked: 24
I'm thinking this out u may be the issue....I must be just looking right past it. I have a denon x2100. I don't see a "sub out"...I see a subwoofer level?...is this the same thing?
Old 10-30-2014, 03:35 PM
thucker's Avatar
Quoted: 14 Post(s)
What receiver do you have? Maybe you have one of the few that doesn't put out enough voltage to drive pro amps?
It also looks like you have a pretty big room there for a single 12" sub to fill with bass. Nice job on the box though.
Edit:
You posted at the same time I did. Try cranking the subwoofer level up.
I see that you're in Oregon too, if you're close to NW Portland and want to trouble shoot with another Receiver or amp, let me know. I have an Onkyo and a Yamaha receiver and a couple amps sitting around while I reconfigure my theater room.
thucker is online now
Old 10-30-2014, 05:23 PM - Thread Starter
tgeorge34's Avatar
Quoted: 21 Post(s)
Liked: 24
I live in salem, and thank you for the offer, but I have another receiver (denon) from the "movie room" that I could troubleshoot with. I'm getting this thing closer to dialed in. Messing with the subwoofer level helped alot.
Old 10-30-2014, 08:08 PM
kevings's Avatar
Quoted: 112 Post(s)
Liked: 207
tgeorge....
gorgeous job on the sub. Also, the cabinet work, framed in TV, and the way it contrast with the fireplace.....looks great as well.
kevings is offline
Old 10-30-2014, 09:15 PM
sooly1's Avatar
Liked: 27
That's a beautiful sub! Nice work.
sooly1 is offline
Old 10-30-2014, 09:31 PM
Samps's Avatar
Quoted: 102 Post(s)
Liked: 39
Did you photoshop the ottoman in front of the fireplace? It looks like the floor is curved in front of it.
Samps is online now
Old 10-31-2014, 12:14 AM - Thread Starter
tgeorge34's Avatar
Quoted: 21 Post(s)
Liked: 24
Thanks for the compliments guys!
Old 10-31-2014, 12:20 AM - Thread Starter
tgeorge34's Avatar
Quoted: 21 Post(s)
Liked: 24
That is not photoshop. It is a padded cushion we had made. It is for my kids as i have 3 under the age of 4. Didnt want any cracked heads on the rock mantle! Ends up getting used as a seat often lol. I didn't know what you were talking about as I'm sitting in front of it now and couldn't see what you were talking about until I looked back at the picture. The left hand corner was pulled forward, and the flap/cushion that hangs down in the front was caught in the carpet on the left side, making it look funny.
