Measuring Amplifiers - Page 2 - AVS Forum | Home Theater Discussions And Reviews
 605Likes
post #31 of 1332 Old 11-30-2014, 06:51 PM
BassThatHz's Avatar
Quoted: 2296 Post(s)
Liked: 2038
Oh, almost forgot. REW can calculate THD too.
You should be able to use that, once you find a way to get 14,000watts into a soundcard. hehe
BassThatHz is offline
post #32 of 1332 Old 11-30-2014, 06:53 PM - Thread Starter
notnyt's Avatar
Quoted: 2651 Post(s)
Liked: 2426
Voltage divider, don't need full signal to calculate thd.
notnyt is offline
post #33 of 1332 Old 12-01-2014, 05:16 AM
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2693
What amps specifically do you want to measure ?
Mfusick is offline
post #34 of 1332 Old 12-01-2014, 05:57 AM - Thread Starter
notnyt's Avatar
Liked: 2426
As many as I can. Going to create a database of it. I will have a standardized testing procedure outlined as well so others can contribute data.
Also going to measure idle current draw, noise at 1 foot, and possibly RF noise.
notnyt is offline
post #35 of 1332 Old 12-01-2014, 06:07 AM
TCARCIO's Avatar
Quoted: 110 Post(s)
Liked: 95
Would love to see the QSC g-5 and g-7 measured......
TCARCIO is offline
post #36 of 1332 Old 12-01-2014, 08:25 AM
Bass Enabler
Scott Simonian's Avatar
Quoted: 5830 Post(s)
Liked: 4830
If there is anything I (or we) can do to help, you let us know.
Fatshaft, popalock and GizzeGutten like this.
Scott Simonian is online now
post #37 of 1332 Old 12-01-2014, 08:27 AM - Thread Starter
notnyt's Avatar
Liked: 2426
Going to solicit feedback once I have some preliminary tests assembled. Then I'll just need gear to test
notnyt is offline
post #38 of 1332 Old 12-01-2014, 08:29 AM
desertdome's Avatar
Quoted: 1267 Post(s)
Liked: 1453
Looking at the scarlett 2i2 for audio interface. Would pref something cheaper, but don't see anything that measures better for the price. The balanced io is necessary here.
Tascam US-366
15% off at Musician's Friend
$50 MIR
Final price: $119
I own it and really like it. I use it as a mic preamp for REW, as a multi-channel DAC, for testing unbalanced/balanced connections to amps, for testing optical, coax, and AES digital inputs/outputs, as a headphone amp, and as a mixer for the kids skits.
Edit: The 15% off at Musician's Friend would also apply to the Scarlett 2i2 making it $127.50.
desertdome is offline
post #39 of 1332 Old 12-01-2014, 11:10 AM
BassThatHz's Avatar
Liked: 2038
I amended my post here to include idle fan noise now, in addition to the temp.
I measured both the front and the back @ 1ft. (They were all different so I figured that capturing both sides might be important to someone).
BassThatHz, Fluke 43B O-Scope Adventures, Thread
All of the amps I measured drew about 100-300watts @ idle, with the average being about 200watts;
and that power draw didn't change by very much until the output power rose above 80watts per side or the -20db lights (whichever is the most.)
I wasn't able to detect any RF noise in any of the amps. (Only a few microvolts up near the 1Mhz range.)
Even the newage switcher amps were only a few micro/milli volts in the 300khz-1000khz range.
[and that was after travelling through 40ft of unshielded speaker cable and hundreds of miles of unshielded transmission lines too!!!]
Hardly worth worrying about considering that nobody can hear above 30khz, nor can few tweeters even play it. (if any at all!)
and under any load it would be drowned out by the music signal and speaker distortions to boot (and XO and coil inductance too.)
There is probably more Nyquist distortions coming off the audio CD @ 10khz, than RF noise coming out of amps @ 400khz.
post #40 of 1332 Old 12-01-2014, 02:11 PM
MKtheater's Avatar
Quoted: 1706 Post(s)
Liked: 1238
I have a peavey IPR2 3000 just sitting here.
Marantz 7702 Atmos
Outlaw 7140 and 5000
Speakers- DIY mini arrays for fronts and BFM TLAH for surrounds
subs 2 XXX ported SLLT powered by IPR2-7500.
MKtheater is offline
post #41 of 1332 Old 12-01-2014, 04:20 PM
Shreds's Avatar
Quoted: 336 Post(s)
Liked: 268
I've experimented with Rew V5.0's THD measurements for small signals and found it to be kind of squirrelly. It would increase and decrease in value by orders of magnitude when only changing the frequency in small increments. I have a good soundcard and have put different preamps in the loop with it but the results don't make sense to me.
I'm not saying don't use it. REW beta is supposed to be better in that regard and as an amp approaches it's limits it will have way more measureable distortion than what I was trying to look at. I just wouldn't take it's numbers to the bank without something else to compare to.
Shreds is offline
post #42 of 1332 Old 12-01-2014, 07:00 PM - Thread Starter
notnyt's Avatar
Liked: 2426
I'll be evaluating different software to see which works best for the job. Hopefully next weekend I can get some interesting data posted.
notnyt is offline
post #43 of 1332 Old 12-01-2014, 10:35 PM
BassThatHz's Avatar
Liked: 2038
REW's math seems correct. These settings seem to work best.
But finding a soundcard with sufficiently low noise to do THD calcs above 300hz could be very challenging indeed.
This is my Asus Xonar HDAV1.3; which cost me $180 like 8 years ago...
1% distortion is 1V RMS of 2nd or 3rd harmonic out of a 100V RMS sinewave.
For 1V into a soundcard, that works out to be just 0.01volts.
i.e. -40db.
post #44 of 1332 Old 12-01-2014, 11:33 PM
BassThatHz's Avatar
Liked: 2038
Here is what 10% harmonic distortion looks like on a scope:
(1% was pretty much invisible on a scope, so I had to make it 10 times worse.)
1.4% 2nd+3rd
10% 2nd
10% 3rd
LTD02 and notnyt like this.
post #45 of 1332 Old 12-02-2014, 03:14 PM - Thread Starter
notnyt's Avatar
Liked: 2426
Got some parts... Will end up about 4.5 ohms per channel.
notnyt is offline
post #46 of 1332 Old 12-03-2014, 07:16 PM - Thread Starter
notnyt's Avatar
Liked: 2426
Got my audio interface. Scarlett 2i2. Measures well. I should be able to sufficiently test amps with this.
Sweep, nice and flat..
Intermodular distortion nice and low
Waveform from IMD test
Square waves
CEA 2010 burst
notnyt is offline
post #47 of 1332 Old 12-03-2014, 08:24 PM
Bass Enabler
Liked: 4830
F**k yeh.
notnyt likes this.
post #48 of 1332 Old 12-03-2014, 08:26 PM - Thread Starter
notnyt's Avatar
Liked: 2426
F**k yeh.
Now I just need a garbage pail and some time
edit: and some parts to setup a voltage divider to feed back to the interface. Need some TLR inputs.
PC -> 2i2 via usb -> AMP via TRS to TRS/XLR
AMP -> heating elements via speaker level outputs.
Need to make some cables with speakon connectors that can feed a voltage divider at the same time, then from there to TRS back to the 2i2. Will have some exposed leads on that board for jumpering in connections from amps that don't have speakon outputs.
notnyt is offline
post #49 of 1332 Old 12-03-2014, 08:27 PM
Bass Enabler
Liked: 4830
The first one should be easy to acquire.
Look forward to how things go.
post #50 of 1332 Old 12-04-2014, 01:03 AM - Thread Starter
notnyt's Avatar
Liked: 2426
STEPS vs REW for FR and THD, thoughts?
notnyt is offline
post #51 of 1332 Old 12-04-2014, 02:37 AM
A9X-308's Avatar
Quoted: 1506 Post(s)
Liked: 1139
Try both and see if there are any differences. ARTA in the free version only disallows saving the results, but you can save screenshots initially so testing it will cost you nothing.
A9X-308 is offline
post #52 of 1332 Old 12-04-2014, 05:31 AM
BassThatHz's Avatar
Liked: 2038
What about FR sweeps down to 2hz? Would be good to compare the single digit -3db roll-offs under a light load, say 100watts.
post #53 of 1332 Old 12-04-2014, 05:37 AM
jpmst3's Avatar
Quoted: 97 Post(s)
Liked: 233
Awesome! This will be a fantastic contribution!
Joe = LFE Addict
Joe's LOWARHORN build
jpmst3 is offline
post #54 of 1332 Old 12-04-2014, 06:26 AM
Shreds's Avatar
Quoted: 336 Post(s)
Liked: 268
Yeah, yeah, yeah. Throw us sealed subbers a bone.
Shreds is offline
post #55 of 1332 Old 12-04-2014, 10:12 AM - Thread Starter
notnyt's Avatar
Liked: 2426
I'll run sweeps from DC....
REW doesn't generate burst tones under 10hz. Wonder if I can modify it. Otherwise I'll just have to find a 5hz cea 2010 burst.
notnyt is offline
post #56 of 1332 Old 12-04-2014, 07:19 PM
Shreds's Avatar
Quoted: 336 Post(s)
Liked: 268
Cool. I was messin' around in one of my DAW's and I created this one at 5Hz. I tried to match the length of the waveform and amplitude of the other bursts I saw REW making in the lower frequencies. PM me your address if you want me to email you the .wav.
Shreds is offline
post #57 of 1332 Old 12-04-2014, 07:49 PM
Ricci's Avatar
Quoted: 240 Post(s)
Liked: 566
Cool...Been hoping somebody would get this going. I don't know of any program which has a 5Hz Keele burst built in. You'll probably have to make one and sample it. Might be a bit cludgy.
Are you going to do unloaded FR vs 2, 4, 8 ohm?
I would probably just do something like 10, 20, 40, 1kHz, 10Khz and 20Khz for the burst tests. 5Hz would be interesting if it isn't too much of a hassle to generate.
I used to use NCH tone generator to produce some signals I couldn't get like 10 non harmonically related sines all at the same time. I haven't looked at it in a while but it may be able to offer something for 5Hz, IMD or spectral contamination.
Pros for REW. Free, measures down to 2Hz, faster measurements. Can do distortion through the 10th harmonic. STEPS only goes down to 5Hz and lumps the harmonics above the 5th all together. If you set up the STEPS FR measurements for high resolution they can take awhile to run so REW probably makes more sense there. STEPS also has possibilities that REW doesn't though. Whatever you do the first couple of amp tests will probably help you make up your mind on what makes sense and what doesn't and the easiest and most practical way to make it repeatable.
Ricci is offline
post #58 of 1332 Old 12-04-2014, 08:15 PM
A9X-308's Avatar
Liked: 1139
There's no point really. The determinant for the LF roll off is a coupling cap and the speaker load isn't going to change it.
A9X-308 is offline
post #59 of 1332 Old 12-04-2014, 08:19 PM - Thread Starter
notnyt's Avatar
Liked: 2426
Yep.. will be doing unloaded vs different loaded sweeps.
I may poke the REW author to add 5hz capability to signal generator if possible, or dig into the code. That would be ideal. If I'm reading right, STEPS has the benefit of delays between measurements, so you're not depleting the power with a high level swept sine wave right away.
Thanks for the feedback, much appreciated.
REW also does dual test tones now so I'll be posting IMD data as well. Once I get my electronics all setup (l-pad components coming tomorrow) I'll outline full test procedure, go through a test, post the data, and seek feedback.
notnyt is offline
post #60 of 1332 Old 12-04-2014, 08:20 PM - Thread Starter
notnyt's Avatar
Liked: 2426
FR from amps, especially on the high end, will change based on the impedance of the load.
notnyt is offline
