So much time spent.... and it doesn't work!
Hello all,
So as many of you have seen in my posts, I've struggled and worked my tail off to build my first minimarty. I went ahead and connected everything up and.... NOTHING.
So, let me clarify - I have a RCA going from the sub out on my receiver, sub is selected on and is at a 80hz, RCA goes to the inuke, which then has a connector end that is RCA to speakon. That connects into channel A of the inuke. To note, you do not twist the connector into place on the input, correct?
Then I have a speakon going from the channel A output (which is twisted in) and goes to my sub connection, which is also twisted in place. +1 and +2 on the connector inside with 12 gauge speaker cable. Speaker cable runs to my ultimax 18, positive on one side and negative on the other. Then I have a wire going from the two remaining + and - terminals to bridge.
I used the app to configure the amp, where it told me it was connected to the amp. Inuke is set to bridge mode and I have the HPF at 20hz. When running, it does not show any movement on the power lights or clip light. Saved the settings. Gains are set to 12 o'clock.
So what else can I do? What else to check. I am pretty certain everything is connected snug inside the box. I will certainly open it up if I must, but I'd rather check on the external factors first. The fact that the power/clipping light isn't lighting makes me feel it is more related to the inuke or RCA to Speakon connection, but you tell me.
Thank you so much for your help. Really let down right now so I hope to get this thing going.
Mike
Hello all,
Mike
